energy-meters:et112
energy-meters:et112 [2018-11-08 03:12] – [Option B: Wired connection to CCGX] robduthie | energy-meters:et112 [2022-07-15 10:58] (current) – Removed and linked to new manuals stefanie | ||
- | ====== | + | The old Energy Meter manuals have been removed. You can find the new manuals here: [[https://www.victronenergy.com/accessories/ |
- | This document is the manual for the single phase max 100 A Energy Meter. | + | |
- | - Grid meter, and used as control input for an [[assistants:ess-assistant|ESS System]] (1). | + | |
- | Victron part number REL300100000 is the ET112-DIN.AV01.X.S1.X from Carlo Gavazzi. And that is the model we keep in stock. | + | |
- | Other ET112 models from Carlo Gavazzi can also be used, as the communication is the same. | + | |
- | ===== 2. AC Wiring ===== | + | |
- | Wiring when used as a grid meter. | + | |
- | === Step 1. === | + | |
- | === Step 2. === | + | |
- | Connect the Zigbee to RS485 converter to the ET112 energy meter: | + | |
- | | GND | Terminal 6 | | + | |
- | | A | Terminal 4 | | + | |
- | | B | Terminal 5 | | + | |
- | === Step 3. === | + | |
- | === Step 4. === | + | |
- | Connect the Energy Meter to the CCGX using the USB to RS485 cable. The RS485 to USB interface cable between the CCGX and the Energy Meter can be extended up to 100 meters; make sure that the extensions of the Data+ (orange) and Data- (yellow) wires form a twisted pair. | + | |
- | | Yellow (Data-) | + | |
- | | Orange (Data+) | + | |
- | | Black (GND) | Terminal 6 | | + | |
- | The red, green and brown wire coming out of the USB to RS485 cable are not used. | + | |
- | Note: You can wire on a RJ45 plug which can plug into the front of either RJ45 socket of the Energy meter, it has the same pin out. | + | |
- | {{ :energy-meters: | + | |
- | ==== 4. Multiple ET112 Meters in one system ==== | + | |
- | To connect multiple Energy Meters, wire each meter to a separate RS485-USB converter. Which are then each plugged into a separate USB socket on the CCGX. | + | |
- | Connecting multiple ET112 meters to the same RS485-USB cable is not possible: the ET112 meter has no display and its Modbus address can therefor not be changed. | + | |
energy-meters/et112.1541643163.txt.gz · Last modified: 2018-11-08 03:12 by robduthie
