ESS Quick Installation Guide
UNDER CONSTRUCTION
This quick installation guide lists all the steps that are needed to install and configure a Victron Energy ESS system. It briefly explains each step. It also provides links to locations where more in depth information about each step can be found. The full ESS manual can be found here: design-installation-manual
Step 1 - Understand how a Victron Energy ESS system works.
Familiarize yourself with the Victron Energy ESS system.
A good place to start is to watch this video:
Step 2 - Decide what type of ESS
There are a few different ways to set an ESS system up. A combination of these are possible as well:
- DC coupled ESS
- AC coupled ESS
- Energy meter is used
- Grid parallel
- Essential loads are used
These are the basic wiring diagrams for each type:
insert images
Step 3 - Select the system hardware
Please see below lists. links are provided to the relevant equipment product pages
You will need:
- Victron inverter/charger(s): https://www.victronenergy.com/inverters-chargers
- Victron Interface MK3-USB: https://www.victronenergy.com/accessories/interface-mk3-usb
- Victron CCGX or Venus GX: https://www.victronenergy.com/panel-systems-remote-monitoring
- RJ45 UTP cable(s): https://www.victronenergy.com/cables/rj45-utp-cable
- Batteries
For a DC coupled ESS you will also need:
- Victron MPPT solar chargers: https://www.victronenergy.com/solar-charge-controllers
- Victron VE.direct cable(s): https://www.victronenergy.com/cables/ve.direct.cable
- Solar panels
For an AC coupled ESS you will also need:
- Grid tied inverter
- Solar panels
If the ESS needs an energy meter you might need:
- Victron Power meters: https://www.victronenergy.com/accessories/energy-meter
- Victron ASS030572018 - RS485 to USB interface 1.8m
- Victron Zigbee to USB and RS485 converter: https://www.victronenergy.com/accessories/zigbee-converters
- Victron Current transformer: https://www.victronenergy.com/accessories/current-transformer-for-multiplus-ii
To measure PV from an non Fronius , SMA or Solar edge you might need:
- Victron Current sensor: https://www.victronenergy.com/accessories/ac-current-sensor
To equip a CCGX or Venus GX with WiFi you will need:
- Victron WiFi module: BPP900100200 or BPP900200200
In case of a smart battery you might need:
- VE.Can to CAN-bus BMS cable: https://www.victronenergy.com.au/cables/ve-can-to-can-bus-bms
Step 4 - Install all equipment
- Install and wire all system parts according to their manuals.
- Do not connect communication cables between the various parts, this will be done at later stage
To find the applicable installation manuals see the links in the prevision steps. These links will direct you to the relevant product section. Then click on a the applicable product. On the product page scroll down to “Downloads”, and then select “manuals” from the drop down box.
Step 5 - Update firmware of all Victron EES equipment
- Update Victron equipment to the most recent firmware version
Instructions on how to update:
CCGX or Venus GX
The easiest way is to let the CCGX or Venus GX do an automatic update. This can be selected from its menu, once it is connected to the internet. Alternatively update via a SD card
For instructions how to update see: How to update a GX device
MPPTs
MPPT solar charger - Via VictronConnect
For instructions how to do a firmware update with VE.Connect this link: firmware_updates
VE.bus
Firmware files and firmware change logs can be found on Victron professional
Instructions how to update firmware:
Step 6 - Set up parallel and/or 3 phase inverter/chargers
(skip this step if only a single inverter/charger is used)
If the ESS system contains multiple inverter/chargers, they first will need to be set up to run in parallel and/or 3 phase.
For instructions on how to do that see this manual: Parallel, split- and three-phase VE.Bus systems
Step 7 - Configure the inverter/charger(s)
The inverter needs to be configured
- Download and install the VE.configuration tools software package from here:
- Connect computer via MK3 interface to the inverter/charger
The following settings are important:
- Battery monitor settings
- Charger settings
- AC input limit settings
- Grid settings
- add more?
See this video on how to use VE.Configure:
- Add ESS assistant to the Inverter/charger(s)
- If more assistants are needed, like …. add these as well, after the ESS assistant
Step 8 - Connect all communication cables
- Connect CCGX to inverter/chargers use RJ45 cable
- Connect MPPT to CCGX use VE.direct cable
- Connect energy meters to CCGX use USB to RS485 interface or Zigbee units
- Connect current sensor or current transformer to inverter/charger use regular signal cables
- Connect smart battery to CCGX, use special RJ45 cable
- Connect CCGX to internet via Ethernet cable or WiFi module
Step 9 - Make CCGX settings
- Go to ESS settings on CCGX, make ESS settings
- Go to CanBus, select smart battery
- Find Fronius, SMA or Solar edge on CCGX. assign correct role
- Find current sensor on CCGX, assign correct role
- Find Energy meter(s) on CCGX, assign correct role
Step 10 - Set up VRM
- Go to Victron VRM
- Make account (in case you do not yet have account)
- Add CCGX to account
- Check if logging is correct
Step 11 - Commissioning
- Comission system, see ESS manual
- Consider limiting access to end-user
- consider turning automatic firmware updates off
