mppt-error-codes
mppt-error-codes [2017-04-28 09:43] – [Err 38 - Input shutdown due to battery over-voltage] rvanzundert | mppt-error-codes [2024-10-03 00:16] (current) – [Information 66 - Incompatible device] guy_stewart | ||
+ | Detailed error codes can be read with: | ||
+ | * Remote panel, such as the Color Control GX or the MPPT Control. | ||
Line 23: | Line 40: | ||
Line 29: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists | + | Possible causes for an over-current on the battery terminals: |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
+ | Disconnect all wires, and then reconnect all wires, to make restart the charger. Also, make sure the minus on the MPPT charge controller | ||
+ | This error indicates that the fan is powered on but the circuit does not measure any current draw by the fan. Most likely its either broken or obstructed. | ||
Line 53: | Line 116: | ||
+ | Possible causes: | ||
Line 58: | Line 143: | ||
+ | ==== Err 35 - PV over-power ==== | ||
+ | Error recovery: | ||
- | ==== Err 38 - Input shutdown due to battery over-voltage ==== | ||
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | ||
- | This error can also occur if the battery voltage is set to a lower voltage than the actual battery voltage. | ||
Line 71: | Line 240: | ||
+ | This error also appears if MPPTs are connected to a GX device while configured for a VE.Smart network. Disable the VE.Smart networking features and use DVCC on the GX instead. | ||
- | ==== Err 114 - CPU temperature | + | When removing charger from such system, and reusing it in a system without BMS, that setting needs to be cleared. |
+ | __Background__ | ||
Line 94: | Line 330: | ||
- | The unit is faulty, contact Victron. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact |
Line 100: | Line 350: | ||
mppt-error-codes.1493365427.txt.gz · Last modified: 2017-04-28 09:43 by rvanzundert
