mppt-error-codes
mppt-error-codes [2022-12-14 12:37] – [Err 38, Err 39 - PV Input shutdown] mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
Line 153: | Line 153: | ||
If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | ||
- | ==== Err 38, Err 39 - PV Input shutdown ==== | ||
- | To protect the battery from over-charging the panel input is shorted. | ||
- | Possible reasons for this error to occur: | + | ==== Err 38, Err 39 and Err 80 to Err 87 - PV Input shutdown ==== |
- | * The Battery voltage (12/24/48V) is set, or auto-detected, | + | |
- | * There is another device connected to the battery, which is configured to a higher voltage. For example a MultiPlus, configured to equalise at 17 Volts, while in the MPPT this is not configured. Solution: configure the same equalisation level in the MPPT, even when normally running the equalisation on the MultiPlus. | + | |
Line 215: | Line 218: | ||
Re-charge the battery or reduce the AC loads to continue operation. | Re-charge the battery or reduce the AC loads to continue operation. | ||
- | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | + | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken |
==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ||
The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | ||
Line 226: | Line 229: | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | ||
Line 233: | Line 240: | ||
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages | + | |
+ | This error shows when the charger is configured to be controlled by a BMS, but does not receive any BMS control messages. | ||
Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | ||
- | Check the connection between the charger and the BMS. | + | Solution: check the connection between the charger and the BMS. |
__How to reconfigure the charger to standalone mode__ | __How to reconfigure the charger to standalone mode__ | ||
Line 247: | Line 255: | ||
Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | ||
- | Here is what needs to be done to make the charger | + | When removing |
* Chargers with LCD display: go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | * Chargers with LCD display: go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
Line 271: | Line 280: | ||
This error indicates an issue in the configuration. There are units present on the same can bus that have different system configurations. | This error indicates an issue in the configuration. There are units present on the same can bus that have different system configurations. | ||
- | Please ensure that all units are set to either " | + | Please ensure that all units are set to either " |
All units will remain off until the configuration is fixed, after which the units will resume operation. | All units will remain off until the configuration is fixed, after which the units will resume operation. | ||
Line 277: | Line 286: | ||
Applies to Inverter RS models. Firmware versions 1.11 and higher. | Applies to Inverter RS models. Firmware versions 1.11 and higher. | ||
- | The Inverter RS model used cannot be paired with a Multi RS and/or Transfer Switch. | + | Inverter RS units cannot be paired with a Multi RS and/or Transfer Switch. |
- | Only Inverter RS models with a production code newer than HQYYWW can be used for this purpose. | + | |
- | Only the incompatible Inverter RS units will remain off. | + | |
==== Err 71 - Network misconfigured ==== | ==== Err 71 - Network misconfigured ==== | ||
Line 286: | Line 293: | ||
There are units present with incompatible firmware on the can bus. Make sure that all units are updated to the same firmware version. | There are units present with incompatible firmware on the can bus. Make sure that all units are updated to the same firmware version. | ||
All units will remain off until the until the firmwares are updated, after which the units will resume operation. | All units will remain off until the until the firmwares are updated, after which the units will resume operation. | ||
Line 305: | Line 337: | ||
To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | ||
- | When your Venus GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. | + | When your GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. |
The procedure to add the file to VictronConnect and start the update is described here: [[https:// | The procedure to add the file to VictronConnect and start the update is described here: [[https:// | ||
Line 331: | Line 363: | ||
==== Err 201 - Internal DC voltage error ==== | ==== Err 201 - Internal DC voltage error ==== | ||
- | Applies to the MPPT RS, Inverter RS and Multi RS | + | Applies to the MPPT RS, Inverter RS and Multi RS. |
- | Internal DC voltage measurement error, is raised in case an internal (high-) voltage measurement does not match certain criteria. And it means that a measurement circuit inside the unit is broken. | + | This “Internal DC voltage measurement error”, is raised in case an internal (high-) voltage measurement does not match certain criteria. |
- | Make sure to update the firmware to at least v1.08, in previous firmwares the limits were too strict. And it could trigger falsely during MPPT start-up in the morning and MPPT shutdown in the evening. | + | First, make sure to update the firmware to v1.08 or later. The limits were too strict |
- | The unit might have seemingly worked fine before | + | If the error still occurs after updating to v1.08 or later, then it means that a measurement circuit inside the unit is broken. |
- | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists the unit is probably | + | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists, even after above mentioned firmware update, |
==== Err 202 - Internal GFCI sensor error ==== | ==== Err 202 - Internal GFCI sensor error ==== |
mppt-error-codes.1671017844.txt.gz · Last modified: 2022-12-14 12:37 by mvader
