mppt-error-codes
mppt-error-codes [2022-12-21 15:53] – [Err 80 to Err 87 - PV Input shutdown] tabreu | mppt-error-codes [2025-03-17 16:46] (current) – [Err 76 - Insufficient inverters] rvanzundert | ||
Line 154: | Line 154: | ||
If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | ||
- | ==== Err 38, Err 39 - PV Input shutdown ==== | + | ==== Err 38, Err 39 and Err 80 to Err 87 - PV Input shutdown ==== |
- | When these error show, the PV Input is internally shorted in order to protect the battery from over-charging | + | When these errors |
Prior to any other trouble shooting, make sure to update to the latest firmware version. | Prior to any other trouble shooting, make sure to update to the latest firmware version. | ||
Line 162: | Line 162: | ||
* The Battery voltage (12/ | * The Battery voltage (12/ | ||
- | * There is another | + | * There is another |
- | * The battery is disconnected using a manual switch, without first disconnecting the PV array. Which is not ideal but otherwise harmless. If necessary the voltage trip-level for the PV Short protection can be increased by raising the Equalization voltage set-point; which works even when Equalization itself is not enabled . | + | |
- | * The battery is disconnected using a Lithium charge relay connected to the “allow-to-charge” output of a BMS. Consider wiring this signal to the Remote terminal of the charger instead. This shuts down the charger gracefully. | + | |
Line 219: | Line 218: | ||
Re-charge the battery or reduce the AC loads to continue operation. | Re-charge the battery or reduce the AC loads to continue operation. | ||
- | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | + | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken |
==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ||
The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | ||
Line 230: | Line 229: | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | ||
Line 237: | Line 240: | ||
+ | This error also appears if MPPTs are connected to a GX device while configured for a VE.Smart network. Disable the VE.Smart networking features and use DVCC on the GX instead. | ||
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages | + | |
+ | This error shows when the charger is configured to be controlled by a BMS, but does not receive any BMS control messages. | ||
Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | ||
- | Check the connection between the charger and the BMS. | + | Solution: check the connection between the charger and the BMS. |
__How to reconfigure the charger to standalone mode__ | __How to reconfigure the charger to standalone mode__ | ||
Line 251: | Line 260: | ||
Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | ||
- | Here is what needs to be done to make the charger | + | When removing |
* Chargers with LCD display: go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | * Chargers with LCD display: go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
Line 275: | Line 285: | ||
This error indicates an issue in the configuration. There are units present on the same can bus that have different system configurations. | This error indicates an issue in the configuration. There are units present on the same can bus that have different system configurations. | ||
- | Please ensure that all units are set to either " | + | Please ensure that all units are set to either " |
All units will remain off until the configuration is fixed, after which the units will resume operation. | All units will remain off until the configuration is fixed, after which the units will resume operation. | ||
Line 281: | Line 291: | ||
Applies to Inverter RS models. Firmware versions 1.11 and higher. | Applies to Inverter RS models. Firmware versions 1.11 and higher. | ||
- | The Inverter RS model used cannot be paired with a Multi RS and/or Transfer Switch. | + | Inverter RS units cannot be paired with a Multi RS and/or Transfer Switch. |
- | Only Inverter RS models with a production code newer than HQYYWW can be used for this purpose. | + | |
- | Only the incompatible Inverter RS units will remain off. | + | |
==== Err 71 - Network misconfigured ==== | ==== Err 71 - Network misconfigured ==== | ||
Line 291: | Line 299: | ||
All units will remain off until the until the firmwares are updated, after which the units will resume operation. | All units will remain off until the until the firmwares are updated, after which the units will resume operation. | ||
- | ==== Err 80 to Err 87 - PV Input shutdown | + | ==== Err 72 - Phase rotation |
- | When these error show, the PV Input is internally shorted in order to protect | + | Check the if the phase order is correct L1-> |
- | Prior to any other trouble shooting, make sure to update | + | The inverters remain operational, they won't connect |
- | Possible reasons for this error to occur: | + | ==== Err 73 - Multiple AC inputs ==== |
- | * The Battery voltage (12/ | + | Applies |
- | * There is another charger connected to the battery, which chargers at a higher voltage. The solution is to make sure that charge voltages configured in the MPPT match the other chargers in the system. In case equalisation is set in one of the other chargers, especially at higher | + | |
- | Error recovery: | + | Per phase only one active connection |
- | * Errors 80 to 83: First disconnect | + | |
- | * Errors 84 to 87: First disconnect the solar panels and disconnect the battery. Wait for 1 minute, then reconnect the battery first and next the panels. | + | |
- | If the error persists | + | The inverters remain operational, |
+ | ==== Err 75 - Network misconfigured ==== | ||
+ | Applies to Multi RS models. Firmware versions 1.19 and higher. | ||
+ | Three phase operation is not yet certified in combination with the selected grid code. | ||
+ | ==== Err 76 - Network incomplete ==== | ||
+ | Applies to Inverter RS and Multi RS models. | ||
+ | The inverters shut down because there are insufficient units to operate a networked setup. Check if all required units are powered on and that the CAN interface cables are connected properly. | ||
+ | All units remain off until the installation is fixed, after which the units resume operation. | ||
+ | Related configuration settings in VictronConnect are " | ||
Line 327: | Line 357: | ||
To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | ||
- | When your Venus GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. | + | When your GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. |
The procedure to add the file to VictronConnect and start the update is described here: [[https:// | The procedure to add the file to VictronConnect and start the update is described here: [[https:// | ||
Line 353: | Line 383: | ||
==== Err 201 - Internal DC voltage error ==== | ==== Err 201 - Internal DC voltage error ==== | ||
- | Applies to the MPPT RS, Inverter RS and Multi RS | + | Applies to the MPPT RS, Inverter RS and Multi RS. |
- | Internal DC voltage measurement error, is raised in case an internal (high-) voltage measurement does not match certain criteria. And it means that a measurement circuit inside the unit is broken. | + | This “Internal DC voltage measurement error”, is raised in case an internal (high-) voltage measurement does not match certain criteria. |
- | Make sure to update the firmware to at least v1.08, in previous firmwares the limits were too strict. And it could trigger falsely during MPPT start-up in the morning and MPPT shutdown in the evening. | + | First, make sure to update the firmware to v1.08 or later. The limits were too strict |
- | The unit might have seemingly worked fine before | + | If the error still occurs after updating to v1.08 or later, then it means that a measurement circuit inside the unit is broken. |
- | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists the unit is probably | + | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists, even after above mentioned firmware update, |
==== Err 202 - Internal GFCI sensor error ==== | ==== Err 202 - Internal GFCI sensor error ==== |
mppt-error-codes.1671634396.txt.gz · Last modified: 2022-12-21 15:53 by tabreu
