mppt-error-codes
mppt-error-codes [2023-01-02 14:33] – [Err 201 - Internal DC voltage error] mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
Line 154: | Line 154: | ||
If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | ||
- | ==== Err 38, Err 39 - PV Input shutdown ==== | + | ==== Err 38, Err 39 and Err 80 to Err 87 - PV Input shutdown ==== |
- | When these error show, the PV Input is internally shorted in order to protect the battery from over-charging | + | When these errors |
Prior to any other trouble shooting, make sure to update to the latest firmware version. | Prior to any other trouble shooting, make sure to update to the latest firmware version. | ||
Line 162: | Line 162: | ||
* The Battery voltage (12/ | * The Battery voltage (12/ | ||
- | * There is another | + | * There is another |
- | * The battery is disconnected using a manual switch, without first disconnecting the PV array. Which is not ideal but otherwise harmless. If necessary the voltage trip-level for the PV Short protection can be increased by raising the Equalization voltage set-point; which works even when Equalization itself is not enabled . | + | |
- | * The battery is disconnected using a Lithium charge relay connected to the “allow-to-charge” output of a BMS. Consider wiring this signal to the Remote terminal of the charger instead. This shuts down the charger gracefully. | + | |
Line 219: | Line 218: | ||
Re-charge the battery or reduce the AC loads to continue operation. | Re-charge the battery or reduce the AC loads to continue operation. | ||
- | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | + | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken |
==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ||
The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | ||
Line 230: | Line 229: | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | ||
Line 237: | Line 240: | ||
Line 277: | Line 280: | ||
This error indicates an issue in the configuration. There are units present on the same can bus that have different system configurations. | This error indicates an issue in the configuration. There are units present on the same can bus that have different system configurations. | ||
- | Please ensure that all units are set to either " | + | Please ensure that all units are set to either " |
All units will remain off until the configuration is fixed, after which the units will resume operation. | All units will remain off until the configuration is fixed, after which the units will resume operation. | ||
Line 283: | Line 286: | ||
Applies to Inverter RS models. Firmware versions 1.11 and higher. | Applies to Inverter RS models. Firmware versions 1.11 and higher. | ||
- | The Inverter RS model used cannot be paired with a Multi RS and/or Transfer Switch. | + | Inverter RS units cannot be paired with a Multi RS and/or Transfer Switch. |
- | Only Inverter RS models with a production code newer than HQYYWW can be used for this purpose. | + | |
- | Only the incompatible Inverter RS units will remain off. | + | |
==== Err 71 - Network misconfigured ==== | ==== Err 71 - Network misconfigured ==== | ||
Line 293: | Line 294: | ||
All units will remain off until the until the firmwares are updated, after which the units will resume operation. | All units will remain off until the until the firmwares are updated, after which the units will resume operation. | ||
- | ==== Err 80 to Err 87 - PV Input shutdown | + | ==== Err 72 - Phase rotation |
- | When these error show, the PV Input is internally shorted in order to protect | + | Check the if the phase order is correct L1-> |
- | Prior to any other trouble shooting, make sure to update | + | The inverters remain operational, they won't connect |
- | Possible reasons for this error to occur: | + | ==== Err 73 - Multiple AC inputs ==== |
- | * The Battery voltage (12/ | + | Applies |
- | * There is another charger connected to the battery, which chargers at a higher voltage. The solution is to make sure that charge voltages configured in the MPPT match the other chargers in the system. In case equalisation is set in one of the other chargers, especially at higher | + | |
- | Error recovery: | + | Per phase only one active connection |
- | * Errors 80 to 83: First disconnect | + | |
- | * Errors 84 to 87: First disconnect the solar panels and disconnect the battery. Wait for 1 minute, then reconnect the battery first and next the panels. | + | |
- | If the error persists | + | The inverters remain operational, |
Line 329: | Line 337: | ||
To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | ||
- | When your Venus GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. | + | When your GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. |
The procedure to add the file to VictronConnect and start the update is described here: [[https:// | The procedure to add the file to VictronConnect and start the update is described here: [[https:// |
mppt-error-codes.1672666431.txt.gz · Last modified: 2023-01-02 14:33 by mvader
