multiplus_faq
multiplus_faq [2018-12-16 23:43] – guy_stewart | multiplus_faq [2024-07-17 06:57] (current) – [4.1 PowerAssist] guy_stewart | ||
Line 10: | Line 10: | ||
Line 24: | Line 24: | ||
==== Generator Sizing ==== | ==== Generator Sizing ==== | ||
+ | It is possible to overload generators with the power demanded by the Multi' | ||
- | It is possible to overload generators with the power demanded by the Multi' | + | ^ Inverter Charger Size ^ Minimum Recommended Generator Size ^ 240V AC Input Current Limit ^ |
- | ^ Inverter/Charger Size ^ Recommended Generator Size ^ | + | If your generator is smaller than the recommended size for your inverter/charger, you will definitely need to adjust the settings on the inverter/ |
- | | 800VA | 2 kVa | | + | |
- | | 1200VA | 2.5 kVa | | + | |
- | | 1600VA | 3 kVa | | + | |
- | | 3000VA | 5 kVa | | + | |
- | | 5000VA | 8 kVa | | + | |
- | If your generator is smaller than the recommended size for your inverter/ | + | If you do want an inverter |
Line 46: | Line 52: | ||
Line 60: | Line 66: | ||
Line 83: | Line 89: | ||
Line 96: | Line 109: | ||
- | For Full information | + | This part is only applicable |
- | ==== What is LOM detection? ==== | + | Loss of mains detection |
- | LOM is an automatic process that detects a change | + | For large and stable Generators Type B LOM will work, and is safer. |
+ | However, if you are experiencing issues with voltage, | ||
- | ==== Why is LOM detection required? ==== | + | **Disabling |
- | The purpose of LOM is to detect that the Multi is no longer | + | Disabling the LOM on an input connected |
+ | Disabling the LOM on an input connected to generator can be done, but then other methods / warning signs / physical lockout safety measures must be provided. Ensuring | ||
- | ==== How does LOM detection | + | For Full information on Loss of Mains detection, |
- | To detect a loss of mains, the inverter/ | + | |
- | When connected to a generator, with a long extension cable or long ‘last mile’ cable, the pushing and pulling on the grid does create high currents, and as a result the inverter/ | + | |
- | ==== LOM detection | + | |
- | LOM detection comes in two flavours: **Type A** and **Type B**. | + | |
- | **Type A** is the strongest form LOM detection, which results in the quickest detection time. It requires a low impedance connection to the grid (short, well sized cables). LOM **Type A** will not work with generators. | + | |
- | **Type B** has a more soft approach. Resulting in a slightly longer detection time. Still acceptable in several countries (South-Africa, | + | |
- | For generators on which also **Type B** does not work, see Disabling LOM. | + | |
- | ==== Disabling LOM ==== | + | |
- | Besides choosing Type A and B, it is also possible to disable the LOM entirely. | + | |
- | Note disabling the LOM on an input connected to the grid is only allowed when other external safety equipment is installed. | + | |
- | Disabling the LOM on an input connected to generator can be done, but then other methods / warning signs must be provided. Ensuring that any installer that will work on the generator will make sure to also switch off or otherwise disconnect the Inverter/ | + | |
- | {{ : | + | **Example configuration in VEConfigure** |
- | ===== Example configuration in VEConfigure | + | |
- | ===== Questions ===== | ||
- | ==== Q1: Where can I get the password? ==== | ||
- | A: From your dealer. | + | ====== 2. In the “General” tab of VEConfigure: ====== |
- | ==== Q2: Can I use ESS in a vehicle or a boat? ==== | + | |
- | A: No you cannot. After unplugging the shore cord it can take up to a few seconds for the system to detect the loss of mains and open the back-feed relay. During those seconds, the shore power plug will be `live`: there is 230 Volts AC on the terminals. The exact number of seconds differs per country and depends on the local requirements. | + | |
- | The same applies to other solution where the wiring is not protected against accidental removing, for example a simple cable with end-user removable plug, such as a portable power supply. | + | |
- | ==== Q3: Can I use ESS with a generator? ==== | + | |
- | A: Yes you can. Note that the only installation type where that makes sense is a land based installation (no boat, and no vehicle). A Quattro must be used with AC input 1 connected to the generator, and AC input 2 connected to the grid. The role of the generator will be to provide power during a long grid failure. | + | |
- | Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | + | |
- | ==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | + | |
- | A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | + | |
- | ====== 2. In the “General” tab of VE-Configure: ====== | + | |
Line 178: | Line 150: | ||
Line 199: | Line 171: | ||
Line 210: | Line 182: | ||
+ | Effectively, | ||
+ | The [[https:// | ||
+ | There is an additional configurable parameter of PowerAssist called "Boost factor" | ||
+ | When the Multi is charging from the generator, and the current required exceeds the AC input current limit (due to a sudden additional load) then the Multi will switch to PowerAssist mode. | ||
+ | At that moment the precise current needed is unknown. The Multi uses the " | ||
+ | In some cases this multiple is either too high, or too low. This would most likely present as the generator unable to stay connected, or fluctuations to the frequency and voltage. | ||
+ | The fastest way to diagnose if setting may be interfering with your specific generator and load operation is to disable power assist entirely. If that resolves the issue, then try reducing the Assist current boost factor down until it works reliably and still getting the benefit of the feature without the interference. The optimal value for this will depend on the size of the inverter, the size of the generator, and the size of the load. | ||
+ | https:// | ||
Line 224: | Line 255: | ||
[[https:// | [[https:// | ||
Line 229: | Line 262: | ||
- | ===== Disqus ===== | ||
multiplus_faq.1545000200.txt.gz · Last modified: 2018-12-16 23:43 by guy_stewart
