multiplus_faq
multiplus_faq [2019-01-07 21:32] – guy_stewart | multiplus_faq [2024-07-17 06:57] (current) – [4.1 PowerAssist] guy_stewart | ||
Line 10: | Line 10: | ||
Line 35: | Line 35: | ||
If your generator is smaller than the recommended size for your inverter/ | If your generator is smaller than the recommended size for your inverter/ | ||
Line 45: | Line 52: | ||
Line 59: | Line 66: | ||
Line 82: | Line 89: | ||
Line 95: | Line 109: | ||
+ | **Disabling LOM** | ||
- | + | ====== 2. In the “General” tab of VEConfigure: ====== | |
- | ====== 2. In the “General” tab of VE-Configure: ====== | + | |
Line 125: | Line 150: | ||
Line 146: | Line 171: | ||
Line 157: | Line 182: | ||
+ | Effectively, | ||
+ | The [[https:// | ||
+ | There is an additional configurable parameter of PowerAssist called "Boost factor" | ||
+ | When the Multi is charging from the generator, and the current required exceeds the AC input current limit (due to a sudden additional load) then the Multi will switch to PowerAssist mode. | ||
+ | At that moment the precise current needed is unknown. The Multi uses the " | ||
+ | In some cases this multiple is either too high, or too low. This would most likely present as the generator unable to stay connected, or fluctuations to the frequency and voltage. | ||
+ | The fastest way to diagnose if setting may be interfering with your specific generator and load operation is to disable power assist entirely. If that resolves the issue, then try reducing the Assist current boost factor down until it works reliably and still getting the benefit of the feature without the interference. The optimal value for this will depend on the size of the inverter, the size of the generator, and the size of the load. | ||
+ | https:// | ||
Line 171: | Line 255: | ||
[[https:// | [[https:// | ||
Line 178: | Line 264: | ||
- | ===== Disqus ===== | ||
multiplus_faq.1546893123.txt.gz · Last modified: 2019-01-07 21:32 by guy_stewart
