multiplus_faq
multiplus_faq [2020-10-06 02:15] – [3.1 Derating of the power factor] guy_stewart | multiplus_faq [2024-07-17 06:57] (current) – [4.1 PowerAssist] guy_stewart | ||
Line 57: | Line 57: | ||
Line 109: | Line 109: | ||
Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | ||
Line 191: | Line 193: | ||
===== 4.1 PowerAssist ===== | ===== 4.1 PowerAssist ===== | ||
The [[https:// | The [[https:// | ||
Line 196: | Line 200: | ||
If you have a small generator and have trouble getting connected or staying connected, Disable PowerAssist to allow the device to reduce the AC input current limit. | If you have a small generator and have trouble getting connected or staying connected, Disable PowerAssist to allow the device to reduce the AC input current limit. | ||
+ | There is an additional configurable parameter of PowerAssist called "Boost factor" | ||
+ | When the Multi is charging from the generator, and the current required exceeds the AC input current limit (due to a sudden additional load) then the Multi will switch to PowerAssist mode. | ||
+ | At that moment the precise current needed is unknown. The Multi uses the " | ||
+ | In some cases this multiple is either too high, or too low. This would most likely present as the generator unable to stay connected, or fluctuations to the frequency and voltage. | ||
+ | The fastest way to diagnose if setting may be interfering with your specific generator and load operation is to disable power assist entirely. If that resolves the issue, then try reducing the Assist current boost factor down until it works reliably and still getting the benefit of the feature without the interference. The optimal value for this will depend on the size of the inverter, the size of the generator, and the size of the load. | ||
+ | https:// | ||
====== Still not connecting? ====== | ====== Still not connecting? ====== | ||
Line 241: | Line 266: | ||
[[https:// | [[https:// | ||
multiplus_faq.1601943352.txt.gz · Last modified: 2020-10-06 02:15 by guy_stewart
