open_source:ccgx:bitbake
Bitbake: making and managing recipes for CCGX
To build all the CCGX rootfs or images with all the existing recipes, see instructions here: https://github.com/victronenergy/venus/blob/master/README.
Below guide is an introduction on how to add recipes and create/debug them.
Start bitbake:
make bb
Build a single recipe:
bitbake -b dbus-modbustcp_0.7.2.bb
That probably didn't work, because dependencies are missing. To build the recipe including dependencies, do:
bitbake dbus-modbustcp
when changing the source code that is fetched by the recipe, make sure to do a cleanall before running the recipe again (note I changed from the dbus-modbustcp example to vrmportal:
bitbake -c cleanall vrmportal
To see what happened, and where all the source files are, see here (replace vrmportal with the recipe you are working on):
/media/venusbuilds/venus/build/tmp-eglibc/work/armv7a-vfp-neon-ve-linux-gnueabi/vrmportal-0.01-r0/
After successfully building a package, it is somewhere in the deploy folder. In above case it is here:
matthijs@matthijs-VirtualBox:/media/venusbuilds/venus/deploy/ipk/armv7a-vfp-neon$ ls -al vrm*
-rw-r--r-- 1 matthijs matthijs 18381088 sep 20 13:19 vrmportal_0.01-r0_armv7a-vfp-neon.ipk
-rw-r--r-- 1 matthijs matthijs      818 sep 20 13:19 vrmportal-dbg_0.01-r0_armv7a-vfp-neon.ipk
-rw-r--r-- 1 matthijs matthijs      828 sep 20 13:19 vrmportal-dev_0.01-r0_armv7a-vfp-neon.ipk
As you can see there is a dbg and dev as well, see internet for more explanation on those. Now, to test the package on a ccgx, copy the package to it: scp vrmportal_0.01-r0_armv7a-vfp-neon.ipk root@192.168.51.67:~/
and then login with ssh and install it:
root@ccgx:~# opkg install vrmportal_0.01-r0_armv7a-vfp-neon.ipk
open_source/ccgx/bitbake.1442756533.txt.gz · Last modified: by mvader
