open_source:ccgx:ccgx_traffic_counting
open_source:ccgx:ccgx_traffic_counting [2015-04-01 08:46] – [Scripts] thiemovanengelenopen_source:ccgx:ccgx_traffic_counting [2021-03-20 02:48] (current) guystewart
 ====== Traffic counting on the CCGX ====== ====== Traffic counting on the CCGX ======
-There are situation in which it is interesting to know the traffic usage of the color control. This can be done on the CCGX using [[http://en.wikipedia.org/wiki/Iptables|iptables]]. To do so requires a number of changes on the CCGX, which are described here.+There are situation in which it is interesting to know the traffic usage of the color control. This can be done on the GX device using [[http://en.wikipedia.org/wiki/Iptables|iptables]]. To do so requires a number of changes on the GX device, which are described here.
 ==== The rules ==== ==== The rules ====
Line 190: Line 190:
 <code>chmod +x /etc/init.d/iptables.sh</code> <code>chmod +x /etc/init.d/iptables.sh</code>
-This allows shutting down the traffic counting using <code>/etc/init.d/iptables.sh stop</code> and start it using <code>/ec/init.d/iptables start</code>.+This allows shutting down the traffic counting using <code>/etc/init.d/iptables.sh stop</code> and start it using <code>/etc/init.d/iptables.sh start</code>.
 When the traffic counting is stopped in this way, the current count values are stored together with the rules, allowing it to continue in the state it was stopped. When the traffic counting is stopped in this way, the current count values are stored together with the rules, allowing it to continue in the state it was stopped.
-When the traffic counting should be started and stopped on startup and reboot of the CCGX, the following commands should also be executed:+When the traffic counting should be started and stopped on startup and reboot of the GX device, the following commands should also be executed:
 <code> <code>
-ln -s /etc/init.d/iptables.sh /etc/rc5.d/S21iptables+ln -s /etc/init.d/iptables.sh /etc/rc5.d/S04iptables
 ln -s /etc/init.d/iptables.sh /etc/rc6.d/K50iptables ln -s /etc/init.d/iptables.sh /etc/rc6.d/K50iptables
 </code> </code>
Line 329: Line 329:
 show the incoming and outgoing traffic (in bytes) that is not for the local LAN. This is roughly the traffic that would normally be counted by the provider. show the incoming and outgoing traffic (in bytes) that is not for the local LAN. This is roughly the traffic that would normally be counted by the provider.
-The lines under <code>Chain OTHER_IN</code> and <code>Chain OTHER_OUT</code> show the amount of traffic used by the different services running on the CCGX.+The lines under <code>Chain OTHER_IN</code> and <code>Chain OTHER_OUT</code> show the amount of traffic used by the different services running on the GX device.
 The following line also resets the counters (besides showing the current values): The following line also resets the counters (besides showing the current values):
open_source/ccgx/ccgx_traffic_counting.1427870787.txt.gz · Last modified: by thiemovanengelen
