open_source:ccgx:ccgx_traffic_counting
open_source:ccgx:ccgx_traffic_counting [2019-01-22 10:43] – external edit 127.0.0.1 | open_source:ccgx:ccgx_traffic_counting [2021-03-20 02:48] (current) – guystewart | ||
====== Traffic counting on the CCGX ====== | ====== Traffic counting on the CCGX ====== | ||
- | There are situation in which it is interesting to know the traffic usage of the color control. This can be done on the CCGX using [[http:// | + | There are situation in which it is interesting to know the traffic usage of the color control. This can be done on the GX device |
==== The rules ==== | ==== The rules ==== | ||
Line 194: | Line 194: | ||
When the traffic counting is stopped in this way, the current count values are stored together with the rules, allowing it to continue in the state it was stopped. | When the traffic counting is stopped in this way, the current count values are stored together with the rules, allowing it to continue in the state it was stopped. | ||
- | When the traffic counting should be started and stopped on startup and reboot of the CCGX, the following commands should also be executed: | + | When the traffic counting should be started and stopped on startup and reboot of the GX device, the following commands should also be executed: |
ln -s / | ln -s / | ||
Line 329: | Line 329: | ||
show the incoming and outgoing traffic (in bytes) that is not for the local LAN. This is roughly the traffic that would normally be counted by the provider. | show the incoming and outgoing traffic (in bytes) that is not for the local LAN. This is roughly the traffic that would normally be counted by the provider. | ||
- | The lines under < | + | The lines under < |
The following line also resets the counters (besides showing the current values): | The following line also resets the counters (besides showing the current values): |
open_source/ccgx/ccgx_traffic_counting.1548150218.txt.gz · Last modified: by 127.0.0.1
