Traffic counting on the CCGX
There are situation in which it is interesting to know the traffic usage of the color control. This can be done on the CCGX using iptables. To do so requires a number of changes on the CCGX, which are described here.
The rules
The following commands clear the existing rules from iptables and add rules for counting specific traffic.
#Flush all iptables -F #Delete all user defined chains iptables -X #ACCEPT traffic to local host iptables -I INPUT -s 127.0.0.0/8 -j ACCEPT iptables -I OUTPUT -d 127.0.0.0/8 -j ACCEPT #ACCEPT traffic to the local LAN iptables -I INPUT -s 10.0.0.0/8 -j ACCEPT iptables -I OUTPUT -d 10.0.0.0/8 -j ACCEPT iptables -I INPUT -s 172.16.0.0/12 -j ACCEPT iptables -I OUTPUT -d 172.16.0.0/12 -j ACCEPT iptables -I INPUT -s 192.168.0.0/16 -j ACCEPT iptables -I OUTPUT -d 192.168.0.0/16 -j ACCEPT #ACCEPT multicast traffic iptables -I INPUT -d 224.0.0.0/4 -j ACCEPT iptables -I OUTPUT -d 224.0.0.0/4 -j ACCEPT #ACCEPT broadcast traffic (dhcp) iptables -I INPUT -d 255.255.255.255 -j ACCEPT iptables -I OUTPUT -d 255.255.255.255 -j ACCEPT #Send all remaining traffic to OTHER_IN/OUT and log iptables -N OTHER_IN #The following line can oly be used when the xt_limit kernel module is available #iptables -A OTHER_IN -j LOG -m limit --limit 10/hour --log-prefix "IPTables-OTHER_IN: " --log-level 7 iptables -A OTHER_IN -j ACCEPT iptables -N OTHER_OUT #The following line can oly be used when the xt_limit kernel module is available #iptables -A OTHER_OUT -j LOG -m limit --limit 10/hour --log-prefix "IPTables-OTHER_IN: " --log-level 7 iptables -A OTHER_OUT -j ACCEPT iptables -A INPUT -g OTHER_IN iptables -A OUTPUT -g OTHER_OUT iptables -N REMOTE_SUPPORT_IN iptables -I REMOTE_SUPPORT_IN -j ACCEPT iptables -N REMOTE_SUPPORT_OUT iptables -I REMOTE_SUPPORT_OUT -j ACCEPT iptables -I OTHER_IN -s supporthost.victronenergy.com -g REMOTE_SUPPORT_IN iptables -I OTHER_OUT -d supporthost.victronenergy.com -g REMOTE_SUPPORT_OUT iptables -N VRM_IN iptables -I VRM_IN -j ACCEPT iptables -N VRM_OUT iptables -I VRM_OUT -j ACCEPT iptables -I OTHER_IN -s ccgxlogging.victronenergy.com -g VRM_IN iptables -I OTHER_OUT -d ccgxlogging.victronenergy.com -g VRM_OUT iptables -N UPDATE_IN iptables -I UPDATE_IN -j ACCEPT iptables -N UPDATE_OUT iptables -I UPDATE_OUT -j ACCEPT iptables -I OTHER_IN -s updates.victronenergy.com -g UPDATE_IN iptables -I OTHER_OUT -d updates.victronenergy.com -g UPDATE_OUT iptables -N PUBNUB_IN iptables -I PUBNUB_IN -j ACCEPT iptables -N PUBNUB_OUT iptables -I PUBNUB_OUT -j ACCEPT iptables -I OTHER_IN -s 54.246.196.128/26 -g PUBNUB_IN iptables -I OTHER_OUT -d 54.246.196.128/26 -g PUBNUB_OUT iptables -I OTHER_IN -s 54.93.127.192/26 -g PUBNUB_IN iptables -I OTHER_OUT -d 54.93.127.192/26 -g PUBNUB_OUT iptables -N NTP_IN iptables -I NTP_IN -j ACCEPT iptables -N NTP_OUT iptables -I NTP_OUT -j ACCEPT iptables -I OTHER_IN -p udp --sport 123 -g NTP_IN iptables -I OTHER_OUT -p udp --dport 123 -g NTP_OUT iptables -N DNS_IN iptables -I DNS_IN -j ACCEPT iptables -N DNS_OUT iptables -I DNS_OUT -j ACCEPT iptables -I OTHER_IN -p tcp --sport domain -g DNS_IN iptables -I OTHER_IN -p udp --sport domain -g DNS_IN iptables -I OTHER_OUT -p tcp --dport domain -g DNS_OUT iptables -I OTHER_OUT -p udp --dport domain -g DNS_OUT #Connman online check iptables -N CONNMAN_IN iptables -I CONNMAN_IN -j ACCEPT iptables -N CONNMAN_OUT iptables -I CONNMAN_OUT -j ACCEPT iptables -I OTHER_IN -s ipv4.connman.net -g CONNMAN_IN iptables -I OTHER_OUT -d ipv4.connman.net -g CONNMAN_OUT
Scripts
The configuration of iptables is normally lost between reboots. The following code should be placed in the file /etc/init.d/iptables.sh
#!/bin/sh ### BEGIN INIT INFO # Provides: iptables # Required-Start: $syslog # Required-Stop: $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Set up iptables ### END INIT INFO PATH=/sbin:/bin:/usr/sbin:/usr/bin NAME=iptables.sh DESC="iptables" case "$1" in start) echo -n "Starting $DESC: " if [ -e /var/run/iptables ]; then echo "iptables is already started!" exit 1 else touch /var/run/iptables fi # Load saved rules if [ -f /etc/iptables/rules ]; then iptables-restore -c < /etc/iptables/rules fi echo "$NAME." ;; stop) echo -n "Stopping $DESC: " if [ ! -e /var/run/iptables ]; then echo "iptables is already stopped!" exit 1 else rm /var/run/iptables fi mkdir -p /etc/iptables # Backup old rules if [ -f /etc/iptables/rules ]; then cp /etc/iptables/rules /etc/iptables/rules.bak fi # Save new rules iptables-save -c > /etc/iptables/rules # Revert to Default Policy iptables -P INPUT ACCEPT iptables -P OUTPUT ACCEPT iptables -P FORWARD ACCEPT # Flush all rules and delete all custom chains iptables -F iptables -X echo "$NAME." ;; restart|force-reload) echo -n "Restarting $DESC: " $0 stop $0 start echo "$NAME." ;; backup) mkdir -p /etc/iptables # Backup old rules if [ -f /etc/iptables/rules ]; then cp /etc/iptables/rules /etc/iptables/rules.bak fi # Save new rules iptables-save -c > /etc/iptables/rules ;; log-reset) mkdir -p /log/iptables/ iptables -L -v -x -n -Z > /log/iptables/iptables-"$2" ;; *) N=/etc/init.d/$NAME echo "Usage: $N {start|stop|restart|force-reload|backup|log-reset}" >&2 exit 1 ;; esac exit 0
Then also execute the following command to make the script executable:
chmod +x /etc/init.d/iptables.sh
This allows shutting down the traffic counting using
/etc/init.d/iptables.sh stop
and start it using
/etc/init.d/iptables.sh start
When the traffic counting is stopped in this way, the current count values are stored together with the rules, allowing it to continue in the state it was stopped.
When the traffic counting should be started and stopped on startup and reboot of the CCGX, the following commands should also be executed:
ln -s /etc/init.d/iptables.sh /etc/rc5.d/S10iptables ln -s /etc/init.d/iptables.sh /etc/rc6.d/K50iptables
By adding the following line to /etc/crontab, the current rules and counts will be backed up every 10 minutes, protecting them more or less from hard resets:
*/10 * * * * root /etc/init.d/iptables.sh backup
Viewing the data
After executing these commands, the traffic is counted by iptables. The data can be viewed by giving the command
iptables -L -x -v -n
The following is an example output:
Chain INPUT (policy ACCEPT 0 packets, 0 bytes) pkts bytes target prot opt in out source destination 78 25590 ACCEPT all -- * * 0.0.0.0/0 255.255.255.255 1033 141226 ACCEPT all -- * * 0.0.0.0/0 224.0.0.0/4 0 0 ACCEPT all -- * * 192.168.0.0/16 0.0.0.0/0 15848 1778034 ACCEPT all -- * * 172.16.0.0/12 0.0.0.0/0 0 0 ACCEPT all -- * * 10.0.0.0/8 0.0.0.0/0 8438 660949 ACCEPT all -- * * 127.0.0.0/8 0.0.0.0/0 13432 2313739 OTHER_IN all -- * * 0.0.0.0/0 0.0.0.0/0 [goto] Chain FORWARD (policy ACCEPT 0 packets, 0 bytes) pkts bytes target prot opt in out source destination Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 255.255.255.255 173 33763 ACCEPT all -- * * 0.0.0.0/0 224.0.0.0/4 0 0 ACCEPT all -- * * 0.0.0.0/0 192.168.0.0/16 16646 4024183 ACCEPT all -- * * 0.0.0.0/0 172.16.0.0/12 0 0 ACCEPT all -- * * 0.0.0.0/0 10.0.0.0/8 8438 660949 ACCEPT all -- * * 0.0.0.0/0 127.0.0.0/8 24853 7624844 OTHER_OUT all -- * * 0.0.0.0/0 0.0.0.0/0 [goto] Chain CONNMAN_IN (1 references) pkts bytes target prot opt in out source destination 11 960 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain CONNMAN_OUT (1 references) pkts bytes target prot opt in out source destination 10 758 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain DNS_IN (2 references) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain DNS_OUT (2 references) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain NTP_IN (1 references) pkts bytes target prot opt in out source destination 3 228 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain NTP_OUT (1 references) pkts bytes target prot opt in out source destination 39 2964 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain OTHER_IN (1 references) pkts bytes target prot opt in out source destination 11 960 CONNMAN_IN all -- * * 87.106.208.187 0.0.0.0/0 [goto] 0 0 DNS_IN udp -- * * 0.0.0.0/0 0.0.0.0/0 [goto] udp spt:53 0 0 DNS_IN tcp -- * * 0.0.0.0/0 0.0.0.0/0 [goto] tcp spt:53 3 228 NTP_IN udp -- * * 0.0.0.0/0 0.0.0.0/0 [goto] udp spt:123 0 0 PUBNUB_IN all -- * * 54.93.127.192/26 0.0.0.0/0 [goto] 0 0 PUBNUB_IN all -- * * 54.246.196.128/26 0.0.0.0/0 [goto] 0 0 UPDATE_IN all -- * * 185.24.223.128 0.0.0.0/0 [goto] 11808 2161730 VRM_IN all -- * * 46.19.32.79 0.0.0.0/0 [goto] 1610 150821 REMOTE_SUPPORT_IN all -- * * 77.72.145.194 0.0.0.0/0 [goto] 0 0 LOG all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 10/hour burst 5 LOG flags 0 level 7 prefix "IPTables-OTHER_IN: " 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain OTHER_OUT (1 references) pkts bytes target prot opt in out source destination 10 758 CONNMAN_OUT all -- * * 0.0.0.0/0 87.106.208.187 [goto] 0 0 DNS_OUT udp -- * * 0.0.0.0/0 0.0.0.0/0 [goto] udp dpt:53 0 0 DNS_OUT tcp -- * * 0.0.0.0/0 0.0.0.0/0 [goto] tcp dpt:53 39 2964 NTP_OUT udp -- * * 0.0.0.0/0 0.0.0.0/0 [goto] udp dpt:123 0 0 PUBNUB_OUT all -- * * 0.0.0.0/0 54.93.127.192/26 [goto] 0 0 PUBNUB_OUT all -- * * 0.0.0.0/0 54.246.196.128/26 [goto] 0 0 UPDATE_OUT all -- * * 0.0.0.0/0 185.24.223.128 [goto] 21431 7309572 VRM_OUT all -- * * 0.0.0.0/0 46.19.32.79 [goto] 3373 311550 REMOTE_SUPPORT_OUT all -- * * 0.0.0.0/0 77.72.145.194 [goto] 0 0 LOG all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 10/hour burst 5 LOG flags 0 level 7 prefix "IPTables-OTHER_IN: " 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain PUBNUB_IN (2 references) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain PUBNUB_OUT (2 references) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain REMOTE_SUPPORT_IN (1 references) pkts bytes target prot opt in out source destination 1610 150821 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain REMOTE_SUPPORT_OUT (1 references) pkts bytes target prot opt in out source destination 3373 311550 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain UPDATE_IN (1 references) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain UPDATE_OUT (1 references) pkts bytes target prot opt in out source destination 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain VRM_IN (1 references) pkts bytes target prot opt in out source destination 11808 2161730 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 Chain VRM_OUT (1 references) pkts bytes target prot opt in out source destination 21431 7309572 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0
The second column of the lines
and
show the incoming and outgoing traffic (in bytes) that is not for the local LAN. This is roughly the traffic that would normally be counted by the provider.
The lines under
Chain OTHER_IN
and
Chain OTHER_OUT
show the amount of traffic used by the different services running on the CCGX.
The following line also resets the counters (besides showing the current values):
iptables -L -x -v -n -Z
Warning: The current values are not stored anywhere and thus are lost!
By adding the following line to /etc/crontab, the overview is stored per day in /log/iptables/iptables-YYYY-MM-DD-HH-MM-SS and the counters reset, giving a traffic counting per day:
@daily root /etc/init.d/iptables.sh log-reset $(date +\%F-\%H-\%M-\%S)
