open_source:ccgx:installing_ccgx_func_on_raspberry_pi
open_source:ccgx:installing_ccgx_func_on_raspberry_pi [2015-02-27 21:27] – [2. Install the dbus-cli] mvader | open_source:ccgx:installing_ccgx_func_on_raspberry_pi [2019-06-22 15:47] (current) – mvader | ||
====== Installing CCGX functionality on a raspberry pi ====== | ====== Installing CCGX functionality on a raspberry pi ====== | ||
- | (in progress, everybody reading | + | The contents of this page were moved to the Venus OS wiki: |
- | ===== Steps ===== | + | https:// |
- | ==== 1. Install daemontools ==== | ||
- | [[http:// | ||
- | To install daemontools follows [[http:// | ||
- | open conf-cc in ./src, and add the following parameter to the gcc call: | ||
- | -include / | ||
- | Daemontools will now be running, to make sure check the processlist: | ||
- | pi@raspberrypi ~ $ ps ax | grep svscan | ||
- | 2171 ? Ss 0:00 /bin/sh / | ||
- | 2173 ? S 0:00 svscan /service | ||
- | 2260 pts/0 S+ 0:00 grep --color=auto svscan | ||
- | But is not doing anything yet, as there are no services setup in /service yet. | ||
- | ==== 2. Install the dbus-cli ==== | ||
- | [[https:// | ||
- | First, get the code from above, and put it somewhere in the path. | ||
- | Then, get some dependencies, | ||
- | sudo apt-get install python-pip | ||
- | Then install lxml, which is needed by dbus-cli: | ||
- | sudo apt-get install libxml2-dev libxslt1-dev python-dev | ||
- | sudo pip install lxml | ||
- | Done! If all works, you'll be able to run dbus -y from the commandline: | ||
- | pi@raspberrypi ~ $ dbus -y | ||
- | org.freedesktop.DBus | ||
- | ==== 3. Install dbus-modbustcp ==== | ||
- | [[https:// | ||
- | Install the qt libraries: | ||
- | sudo apt-get install libqt4-dev | ||
open_source/ccgx/installing_ccgx_func_on_raspberry_pi.1425068864.txt.gz · Last modified: by mvader
