Installing CCGX functionality on a raspberry pi
(in progress, everybody reading this page, feel free too add and improve)
Steps
1. Install daemontools
Daemontools is a set of tools to run services: it runs an executable, and when it fails it will start it again. To see some commonly used commands, like starting and stopping a service, or seeing status of all services, check the CCGX command-line introduction.
To install daemontools follows the instructions on its install page, with one addition: right before running /package install, there is one change that is necessary to make it compile:
open conf-cc in ./src, and add the following parameter to the gcc call:
-include /usr/include/errno.h
Daemontools will now be running, to make sure check the processlist:
pi@raspberrypi ~ $ ps ax | grep svscan 2171 ? Ss 0:00 /bin/sh /command/svscanboot 2173 ? S 0:00 svscan /service 2260 pts/0 S+ 0:00 grep --color=auto svscan
But is not doing anything yet, as there are no services setup in /service yet.
