open_source:ccgx:start
CCGX
CCGX Hardware and software introduction
Hardware
The CCGX is based on the Technexxion board TAM-3517, which is using the Texas Instruments Sitara AM3517 ARM processor:
Software
Linux
CCGX image / distro is based on Poky.
Poky can be thought of as a reference distribution. It is maintained by an organisation called the Yocto Project and based on Open Embedded.
Taken directly from the Yocto Project website (www.yoctoproject.org): “…The Yocto Project™ is an open source collaboration project that provides templates, tools and methods to help you create custom Linux-based systems for embedded products regardless of the hardware architecture“. Some of their projects that are relevant to the CCGX are Poky and Bitbake.
Open Embedded is a build environment for embedded linux, and has all kinds of tools, mechanisms and recipes to build the Linux kernel and make a full embedded Linux rootfs. Maintained version are listed here, https://wiki.yoctoproject.org/wiki/Releases.
Angström, a well known linux distribution for embedded, is built using Open Embedded, and also related to Poky. Victron is not using Angström.
For more introduction, refer to the websites of Poky and Open Embedded. And this blog is also interesting: http://blogs.mentor.com/chrishallinan/blog/2012/04/13/yocto-versus-poky-versus-angstrom-etc/
To build the distro yourself, see: https://github.com/victronenergy/venus
Victron software
we are using a mixture of C, C++, QML (for the user interface) and Python. As a main data exchange, to share values such as voltages, as well as settings and other data, we use D-Bus. D-bus is for inter process communication, see google and the D-Bus page on wikipedia for more information. This diagram gives a good overview of the whole thing:
Product processes
Processes that interface to products, using the different protocols. These processes make the information available on the D-Bus.
  • VE.Can to dbus
    written in C, reads and writes to the VE.Can comm. port.
  • mk2dbus
    written in C, reads and write to VE.Bus (Victron inverter/charger protocol).
  • VE.Direct to D-Bus
    written in C, reads/writes to serial connected devices, such as the BMV and MPPT solar chargers.
  • gps_dbus
    also written in C. Open source: https://github.com/victronenergy/dbus_gps.
  • dbus_qwacs
    C++, using the QT library. Reads data from wireless AC sensors connected via an Ethernet-DECT gateway. Open source: https://github.com/victronenergy/dbus_qwacs
  • dbus-fronius
    writeen in C++, communications to Fronius PV inverters via LAN/Ethernet. Open source: https://github.com/victronenergy/dbus-fronius
Other processes
Source code
As visible in above project list, part of the sources is already available. All that is open source is available on https://github.com/victronenergy/. The rest is still on Victrons internal git servers, and where possible slowly being moved to github.
Plans currently being worked on
Future plans
Functionality wise, the plans are (in random order):
  • Make support for more types of sensors (temp sensors etc)
  • Be able to use BMV's to read current from for example a dc wind generator, and show on overview and VRM portal
  • Make more of the project open source
  • Further mature alarms, and add SMS and email notifications
  • Make it usable as a UPS-replacement. local website, emailalerts, battery minutes remaining, etc.
  • Add SNMP (UPS-MIB)
Other tips
  • to make a screenshot, first press and hold the down button, and then press the up button. The screenshot will be saved to /opt/color-control/gui/. It will overwrite the previous one.
And see color_control_gx for more CCGX development information
open_source/ccgx/start.1424872528.txt.gz · Last modified: by mvader
