Open source
Victron Energy has committed itself to make certain of its projects open source. On this page you'll find more information about available sources and projects.
Below some of our own projects, you'll also find a list of other people's open source projects that work with Victron equipment. See bottom of this page.
Note that all this information is made available as is, for free, without any warranty and we do not commit to giving support. Although ofcourse we like to help out where possible.
Looking for Victron protocol documentation? Read our Data communication whitepaper as well.
Color Control GX, BBB, RaspberryPi: the Venus OS
Venus OS is the Victron Energy Unix like distro with a linux kernel. Its the heart of our Color Control GX and Venus GX two very successful central and remote monitoring systems.
While being a very successful project for us in its standard configuration, the Venus OS, and compatible hardware platforms can also be the perfect platform for many other projects. Such as:
- Add drivers for certain products, if interesting enough we will add transmission and readout of that data on the VRM Portal. Adding generators readout and start/stop, and also temperature sensors for example would be very interesting!
- Add logic on the product, for example to control the relay, or do other things.
Full information about the Venus OS; and compatible boards and hardware is here: https://github.com/victronenergy/venus/wiki
In case you want to develop something, please share your thoughts with us. We want to help making it a success, and preferably also include it in our main repositories and images.
More information
- developers mailing list: https://groups.google.com/forum/m/#!forum/victron-dev-venus
VRM Portal (https://vrm.victronenergy.com/)
Other Victron related open source projects
Many, many people all over the world are writing code to integrate Victron products and protocols into their systems. Below a list of public projects, aiming to help each other.
Tip: makre sure to search for 'Victron' on Github and other open source hubs, or for 'Victron git' in Google. That is how I found below links .
Want to list your project here? Please go ahead and change this page yourself! See Login on upper right.
Multis / Quattros / MK2
- https://github.com/hpdvanwyk/invertergui: A primitive HTTP based monitor for a Victron Multiplus inverter. Uses https://github.com/ncthompson/inverter_monitor as a data source.
- Fabien Fleutot made a monitoring system for his beautiful old Belgian barge called Elorn
- Github source for controlling Victron BMV and inverters on a raspberry pi.
- Michel Kuenemann transformed his house, using 1 X RPi B and 4 X LPC1769 Cortex M3 :
- Python library for MK2 (Izak Burger)
- EMDO can do! Energy manager to increase self-consumption quote, switch loads when energy is available. Programmable over BASIC interpreter (MM-BASIC).
- want to list your project here? Please go ahead and change this page yourself!
VE.Direct (MPPT Solar Chargers and BMV Battery Monitors)
Arduino:
Other:
- Use VE.Direct compatible Victron equipment with EMON (Open Energy Monitor) https://github.com/openenergymonitor/emonhub/tree/emon-pi/conf/interfacer_examples/vedirect
- PvMonit : small real-time web interface and export to emonCMS for history (Brick from OpenEnergyMonitor)
- Nodejs monitor Raspberry PI https://github.com/Moki38/vedirect
- pgf's client/server bash script for access to VE.Direct: https://github.com/foxharp/ve.direct
- Raspberry Pi / PHP Victron Data Logger (Text-Mode) Open Source: https://github.com/oekoluk/Victron-Data-Reader-and-Logger
- SignalK: https://github.com/sbender9/vedirect
- victronPi: a Raspberry Pi driven graphical display of data from Victron equipment installed in a campervan http://www.chronicle.me.uk/victronPi
