Smart Battery Sense manual
1. Introduction
The Smart Battery Sense is a wireless battery voltage- and temperature- sensor for Victron MPPT Solar Chargers.
The Solar Charger uses these measurements to optimize its charge parameters. This will improve charging-efficiency and prolong battery life.
The connection between the Smart Battery Sense and the Solar Charger(s) wireless: VE.Smart Network, a wireless technology that is based on Bluetooth Smart.
Simple to install & configure, the Smart Battery Sense comes with an inline fuse and pre-crimped eyelets. And adhesive tape on the back, to mount it on the battery.
System design & component selection
- Check the VE.Smart Networking compatible products list for compatible Solar Chargers.
- The Smart Battery Sense is not needed, nor allowed, in systems that also have a Color Control GX or Venus GX, see FAQ Q6 for more info.
- The Smart Battery Sense is not needed for installations that already have a BMV-712 with its temperature sensor accessory.
- For installations with a BMV-702 + temperature sensor accessory, consider adding a VE.Direct Bluetooth Smart dongle instead of a Smart Battery Sense.
2. Installation
Connect the unit's two eyelets to your battery terminals and attach it directly onto the battery-body using its self-adhesive strip.
For battery banks consisting of multiple individual batteries, connect the Smart Battery Sense unit on any one of the batteries.
In case the supplied bat+ and bat- cables are not long enough, their length can be increased. Make sure to use the same, or thicker, gauge cable.
4. Configuration
See this below video. Also, see the step by step procedure as documented in the ve-smart-networking manual.
5. LED Status codes
The Smart Battery Sense has two LEDs, a Bluetooth status LED (blue), and an error LED (red).
On power-up, the Bluetooth LED will be slow blinking indicating that the device is ready to accept a Bluetooth connection.
When both LEDs stay on, something is wrong with the Smart Battery Sense (hardware error).
When the LEDs are alternating quickly for more than 30 seconds, the Smart Battery Sense is in firmware update mode and needs to be updated before it can be used. After connecting with VictronConnect, a firmware update can be performed.
Blue LED | Red LED | Smart Battery Sense state | Connection State | Remark |
On | On | Not functional | Disabled | Hardware error. The Smart Battery Sense will not advertise itself so it will not be visible in VictronConnect. Also, it will not participate in any configured VE.Smart Networking anymore. |
Slow blinking | Off | Measuring V/T | Not connected | When VE.Smart Networking is configured, the device will be broadcasting the voltage and temperature data in the VE.Smart network. |
On | Off | Measuring V/T | Connected | When VE.Smart Networking is configured, the device will be broadcasting the voltage and temperature data in the VE.Smart network. |
Fast blinking | Fast blinking | Firmware update | Not connected | Red and Blue LED Alternating |
On | Slow blinking | Firmware update | Connected | |
On | Faster blinking | Firmware update | Uploading | |
Fast blinking | Off | Firmware update | Programming |
6. Trouble shooting
See both the VictronConnect manual and the VE.Smart Network manual.
