the Multi or Quattro needs to run the latest 4xx firmware. Contact your Victron representative for the firmware files. Update instructions are [[updating_firmware:updating_ve.bus_products|here]].
===== 3. Battery, inve... m Configurator for this.
* Update all Multis to firmware 405 or newer
* Install the Hub4 Assistant in al
C power setpoint continuously. Starting from CCGX firmware version 1.70, you can disable this behavior in //... an extra ValueB. This is a feature of newer Multi firmware versions. Because the IDs range from 0..255 the H
start.txt ยท Last modified: 2023-05-06 02:21 by guy_stewart
