updating_firmware:updating_ve.bus_products [2018-03-21 12:13] – [Warning: This operation must only be carried out by Victron-trained Engineers, Installers and Dealers, and must not be attempted by system Owners and Users.] justin_tyers_live_a_c | updating_firmware:updating_ve.bus_products [2023-06-29 10:48] (current) – [Notes] marianka | ||
- | ==== Warning: This operation must only be carried out by Victron-trained Engineers, Installers and Dealers, and must not be attempted by system Owners and Users. | + | ===== VEFlash is deprecated in favour of VictronConnect ====== |
+ | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// | ||
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
- | * All settings will be lost. | + | * All settings will be lost - [[https:// |
* Assistants and parallel or three-phase configuration will be lost. | * Assistants and parallel or three-phase configuration will be lost. | ||
Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible to update [[https:// | ||
- | * To update | + | * Updating |
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
* To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
* There are different firmware types available. Read our PDF [[https:// | * There are different firmware types available. Read our PDF [[https:// | ||
Line 17: | Line 26: | ||
* After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | ||
- | + | * It is not required | |
- | Instruction video explaining how to update | + | |
- | {{youtube> | + | |
Line 57: | Line 64: | ||
- | ~~DISQUS~~ | ||
Line 67: | Line 73: | ||
+ | ~~DISQUS~~ |
updating_firmware/updating_ve.bus_products.1521630793.txt.gz · Last modified: 2018-03-21 12:13 by justin_tyers_live_a_c
