ve.can:updating_firmware
How to update firmware - VE.Can
This page explains the procedure to update firmware for products that have a VE.Can port. There are two ways:
- Remotely via internet - applies to systems that have a Venus-device, and are internet-connected.it can be done remotely.
- Locally, using a CANUSB interface.
Updating the firmware of a VE.Can product is typically most convenient by using the remote option. Its then not necessary to obtain the CANUSB adapter. In case you do need, but don't have the CANUSB, contact your dealer; they'll be able to help you in most cases; by lending one or by doing the update for you if you send them the product.
Method 1: Remotely via internet
Method 2: Locally, using the CANUSB interface
ve.can/updating_firmware.1542147030.txt.gz · Last modified: 2018-11-13 23:10 by mvader
