venus-os:gx_solaredge
GX SolarEdge Manual
1. Introduction
You can connect your GX Device with a SolarEdge PV solution, using the ModbusTCP Sunspec protocol. Sunspec is an industry standard protocol for exchanging PV Inverter yield information.
- Zero Feed-in for SolarEdge is not available when used with a Victron System,
- Frequency shift power control, as required in a AC-Coupling system might work, but has not been tested.
With those limitations, it is possible for the SolarEdge to be used in ESS systems where feed-in to the grid is allowed, but only when connecting the SolarEdge to the AC-input of the Victron inverter/charger. In other sorts of systems, for example Off-grid systems, or ESS systems in areas where grid feed-in is not allowed, using a SolarEdge PV solution is not supported by Victron.
2. How to configure
- Ensure that the GX Device and the SolarEdge system are both on the same LAN or WiFi network.
- Enable ModbusTCP support on your SolarEdge system. Consult the SolarEdge documentation for that.
- On the GX Device, navigate to Settings → PV Inverters. Search for the Solar Edge and complete the configuration.
Details:
- The SE2200H - SE6000H range (HD-wave) was specifically tested, though others may work too.
- The unit id is 126.
- During testing, we found that the SolarEdge PV Inverter accepts just one concurrent TCP connection. Additional connections are rejected.
venus-os/gx_solaredge.1558476196.txt.gz · Last modified: 2019-05-22 00:03 by mvader
