venus-os:large
venus-os:large [2023-12-21 10:42] – external edit 127.0.0.1 | venus-os:large [2024-06-24 21:08] – dfaber | ||
Line 120: | Line 120: | ||
===== 5. Node-RED ===== | ===== 5. Node-RED ===== | ||
Line 129: | Line 129: | ||
A good tutorial on how to work with Node-RED is here: https:// | A good tutorial on how to work with Node-RED is here: https:// | ||
- | There is also a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel: | + | ==== 5.2 Three part introductory webinar ==== |
[[https:// | [[https:// | ||
Line 142: | Line 144: | ||
The Node-RED editor can be accessed from your LAN at https:// | The Node-RED editor can be accessed from your LAN at https:// | ||
- | __Standard nodes + Victron nodes__ | + | ==== 5.3 Node specifications ==== |
Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | ||
Line 181: | Line 184: | ||
==== 5.4 Controlling relays ==== | ==== 5.4 Controlling relays ==== | ||
+ | For a relay to be controllable via Node-RED, it needs to be switched to manual control first. In most cases this needs to be done by using [[https:// | ||
Line 197: | Line 206: | ||
=== SolarCharger MPPT Relay === | === SolarCharger MPPT Relay === | ||
- | Currently it is not possible | + | In order to switch |
Line 205: | Line 214: | ||
=== RS series (inverter, multi) relays === | === RS series (inverter, multi) relays === | ||
- | Currently not controllable. Will be controllable in the future. | + | First set the relay to //manual control// using VictronConnect. Once that has been done, the relay can be controlled using Node-RED. |
=== Charger relays === | === Charger relays === | ||
Line 325: | Line 334: | ||
export NODE_EXTRA_CA_CERTS=/ | export NODE_EXTRA_CA_CERTS=/ | ||
=== Q9: How often do the Victron input nodes send a msg? === | === Q9: How often do the Victron input nodes send a msg? === | ||
The input nodes send out a message on each value change. If the ‘//only changes// | The input nodes send out a message on each value change. If the ‘//only changes// | ||
+ | module.exports = { | ||
+ | === Q11: Is there a way to have the context survive reboots? === | ||
+ | By default the context is stored in memory of the GX device only. If the GX device gets rebooted, the | ||
+ | content of the memory gets reset and you loose the context information. | ||
+ | In order to keep the context data, it is needed to [[https:// | ||
+ | contextStorage: | ||
+ | default: { | ||
+ | module: " | ||
+ | config: { | ||
+ | flushInterval: | ||
+ | With the above settings, context files will get created periodically in ''/ | ||
Line 381: | Line 420: | ||
- | * [[http://slack-invite.signalk.org/|Signal K Slack]] - a real time chat group including a special Victron channel. | + | * [[https://discord.gg/uuZrwz4dCS |
Line 404: | Line 443: | ||
Line 417: | Line 455: | ||
Line 422: | Line 461: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 552: | Line 616: | ||
Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | ||
- | The easy solution | + | Depending on what the issue is, there are a few things you can do: |
- | A more detailed approach is logging in on SSH, and checking for disk space. Here are a few useful commands. | + | - Do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz; |
The '' | The '' | ||
Line 600: | Line 670: | ||
744 / | 744 / | ||
+ | * [[https:// | ||
+ | See [[https:// |
venus-os/large.txt · Last modified: 2024-08-04 16:01 by mvader
