venus-os:large
venus-os:large [2024-04-03 19:07] – [5.1 Introduction] mvader | venus-os:large [2024-07-14 16:53] (current) – [8.1 Disk space issues / data partition full] mvader | ||
Line 120: | Line 120: | ||
===== 5. Node-RED ===== | ===== 5. Node-RED ===== | ||
Line 184: | Line 184: | ||
==== 5.4 Controlling relays ==== | ==== 5.4 Controlling relays ==== | ||
+ | For a relay to be controllable via Node-RED, it needs to be switched to manual control first. In most cases this needs to be done by using [[https:// | ||
Line 200: | Line 206: | ||
=== SolarCharger MPPT Relay === | === SolarCharger MPPT Relay === | ||
- | Currently it is not possible | + | In order to switch |
Line 208: | Line 214: | ||
=== RS series (inverter, multi) relays === | === RS series (inverter, multi) relays === | ||
- | Currently not controllable. Will be controllable in the future. | + | First set the relay to //manual control// using VictronConnect. Once that has been done, the relay can be controlled using Node-RED. |
=== Charger relays === | === Charger relays === | ||
Line 343: | Line 349: | ||
And restart Node-RED. | And restart Node-RED. | ||
+ | === Q11: Is there a way to have the context survive reboots? === | ||
+ | By default the context is stored in memory of the GX device only. If the GX device gets rebooted, the | ||
+ | content of the memory gets reset and you loose the context information. | ||
+ | In order to keep the context data, it is needed to [[https:// | ||
+ | module.exports = { | ||
+ | contextStorage: | ||
+ | default: { | ||
+ | module: " | ||
+ | config: { | ||
+ | flushInterval: | ||
+ | With the above settings, context files will get created periodically in ''/ | ||
Line 394: | Line 420: | ||
- | * [[http://slack-invite.signalk.org/|Signal K Slack]] - a real time chat group including a special Victron channel. | + | * [[https://discord.gg/uuZrwz4dCS |
Line 593: | Line 619: | ||
- Do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz; | - Do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz; | ||
- | - Remove all Signal K Server log files. In case you're using SignalK, then we recommend to try that option first. See next chapter on how to do that (requires a USB stick or SD Card), and once done make sure to double check you're Signal K log setup; Most importantly, | + | - Remove all Signal K Server log files. In case you're using SignalK, then we recommend to try that option first. See next chapter on how to do that (requires a USB stick or SD Card), and once done make sure to double check you're Signal K log setup; Most importantly, |
- | - A more detailed approach is logging | + | - A more detailed approach is logging |
**Tips and tricks to login a diagnose disk space** | **Tips and tricks to login a diagnose disk space** | ||
Line 650: | Line 676: | ||
See [[https:// | See [[https:// |
venus-os/large.1712164079.txt.gz · Last modified: 2024-04-03 19:07 by mvader
