venus-os:mfd-garmin
Garmin MFD integration
1. Introduction
The integration technology used is called Garmin OneHelm.
2. Compatibility
OneHelm is currently available for the GPSMAP® 8400/8600 MFD series.
3. Wiring
The Garmin needs to be connected to the Venus-device using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Garmin adapter is required:
- Marine Network Cables - 6ft - PART NUMBER 010-10550-00
- Marine Network Cables - 20ft - PART NUMBER 010-10551-00
- Marine Network Cables - 40ft - PART NUMBER 010-10552-00
- Marine Network Cables - 500ft - PART NUMBER 010-10647-01
4. Configuration
Venus-device settings
- Go to Settings → Services, and there enable MQTT.
- Go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name.
Networking
No settings are necessary. The Garmin MFDs run a DHCP server; and the Venus-devices are by default configured to use DHCP. After plugging in the cable, the Victron icon will show up after 10 to 30 seconds.
How to connect to both a Garmin and Internet? That is unclear as of now.
5. Usage
TBD add screenshots and so forth.
venus-os/mfd-garmin.1552950705.txt.gz · Last modified: 2019-03-19 00:11 by mvader
