venus-os:mfd-raymarine
venus-os:mfd-raymarine [2020-06-25 17:34] – mbosma | venus-os:mfd-raymarine [2023-06-22 19:32] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | https:// |
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. | + | |
- | The integration technology used is called [[http:// | + | |
- | Note that there is an alternative method to connect, which is NMEA2000. See the [[https://www.victronenergy.com/ | + | |
- | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | + | |
- | Raymarine MFDs need at least LightHouse v3.11 for compatibility, | + | |
- | The MFD needs to be connected to the [[https:// | + | |
- | The RayNet adapters can be purchased from Raymarine: | + | |
- | * A62360 | + | |
- | * A80151 - RayNet (F) to RJ45 (M) - 3m | + | |
- | * A80159 - RayNet (F) to RJ45 (M) - 10m | + | |
- | * A80247 - RayNet (F) to RJ45 (F) Adapter | + | |
- | * A80513 - RayNet male to RJ45 adaptor cable | + | |
- | To connect the [[https:// | + | |
- | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | + | |
- | :!: It is not possible to use a [[https:// | + | |
- | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
- | Next, go to //Settings → System Setup → Scroll to the bottom → Marine MFD App configuration// | + | |
- | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | + | |
- | ===== 5. Configuring Multiple Battery Measurements ===== | + | |
- | This video explains how to setup multiple battery measurements, | + | |
- | {{youtube> | + | |
- | ===== 6. Step by Step ===== | + | |
- | ===== 7. NMEA 2000 ===== | + | |
- | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | + | |
- | In order to properly display the NMEA 2000 data from Victron equipment, you need to change the data instances of the PGNs that are sent out. See [[https:// | + | |
- | To setup the data sources on the MFD, go to //Settings > Network > Sources > Advanced...// | + | |
- | The following Victron related PGNs are supported: | + | |
- | * 127505 - Fluid level (tanks) | + | |
- | * 127506 - DC Detailed Status; State-of-charge, Time-to-go | + | |
- | * 127508 | + |
venus-os/mfd-raymarine.1593099275.txt.gz · Last modified: 2020-06-25 17:34 by mbosma
