venus-os:remote_ve.bus_firmware_updates [2023-06-15 15:00] – Add Error 733 desciption jpasopvenus-os:remote_ve.bus_firmware_updates [2024-11-15 10:37] (current) – [1.2 Limitations and requirements] guy_stewart
Line 22: Line 22:
   * In case of another GX Device, ie. a Cerbo, Venus GX, or otherwise, there is no minimum hardware version - they all meet the requirements.    * In case of another GX Device, ie. a Cerbo, Venus GX, or otherwise, there is no minimum hardware version - they all meet the requirements.
   * Venus OS firmware must be 2.65 or later.    * Venus OS firmware must be 2.65 or later.
-  * Two Way Communication must be enabled in the VRM menu of the GX device+  * The ''Full'' access setting, which is on the [[venus-os:start|GX device]] menu -> Settings -> VRM Online Portal -> VRM Portal must be enabled.
 ===== 2. Preparations ===== ===== 2. Preparations =====
Line 37: Line 37:
 ==== 2.2 Disconnect VE.Bus BMS and/or Digital Multi Control ==== ==== 2.2 Disconnect VE.Bus BMS and/or Digital Multi Control ====
-It is not possible to update a VE.Bus inverter, or inverter/charger in case there is also a VE.Bus BMS or Digital Multi Control (DMC) connected to the VE.Bus network.+It is not possible to update a VE.Bus inverter, or inverter/charger in case there is also a VE.Bus BMS or Digital Multi Control (DMC) connected to the VE.Bus network.
 +This exception does not apply to a MultiPlus or Quattro with VE.Bus BMS V2. In such systems, a remote firmware update of the VE.Bus inverter or inverter/charger is possible.
 Error 734, “Cannot update with DMC or VE.Bus BMS connected” will be shown during the process when attempting to update such system. No settings or firmware is altered at the time, the system will remain operational. Error 734, “Cannot update with DMC or VE.Bus BMS connected” will be shown during the process when attempting to update such system. No settings or firmware is altered at the time, the system will remain operational.
Line 119: Line 120:
 The most common reasons are: The most common reasons are:
 ^ Message ^ Description ^  ^ Message ^ Description ^
-| vbdup failed with exit code 54  | Failed to start Update. The file has an incompatible version number. \\ Please make sure you selected a valid update file or update Venus OS to the latest version | +| vbdup failed with exit code 54  | Failed to start Update. The file has an incompatible version number. \\ Please update your Venus OS version to the latest version |
 | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. | | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. |
venus-os/remote_ve.bus_firmware_updates.1686834033.txt.gz · Last modified: 2023-06-15 15:00 by jpasop
