victronconnect:beta
victronconnect:beta [2024-05-01 02:09] – [v6.10beta2] jperez | victronconnect:beta [2024-09-24 10:05] (current) – [v6.09.1 (Released officially)] jperez | ||
Line 11: | Line 11: | ||
(Currently available betas are on top. See further below for official releases.) | (Currently available betas are on top. See further below for official releases.) | ||
- | ==== v6.10beta3 | + | ==== v6.10beta13 |
- | ** 2024-05-01 ** | + | ** 2024-09-11 ** |
+ | __Download links:__ | ||
+ | * iOS: Join TestFlight https:// | ||
+ | * [[https:// | ||
+ | Notes: | ||
+ | __Changes__ | ||
+ | * Add Korean translation | ||
+ | Energy Meter: | ||
+ | * Hide L2-L3 line voltage in split phase configuration | ||
+ | * This was introduced in v1.07, which was only in VictronConnect beta. | ||
+ | * Improve VE.Can communication; | ||
+ | Solar Chargers: | ||
+ | * Fix the issue where "Load output configuration" | ||
+ | ==== v6.10beta12 ==== | ||
+ | ** 2024-09-07 ** | ||
+ | VE.Bus Inverter/ | ||
+ | * Fix error 122 when updating VE.Bus BMS V2 based systems | ||
+ | * Fix system configuration missing phase selection buttons | ||
+ | SmartShunt: | ||
+ | Lynx Smart BMS: | ||
+ | * Improve mode button visibility | ||
+ | * Fix maximum starter voltage value for BMV & SmartShunt demos | ||
+ | ==== v6.10beta11 ==== | ||
+ | ** 2024-08-30 ** | ||
+ | * Restore the " | ||
+ | Orion XS: | ||
+ | * Add firmware v1.05 update (mandatory) | ||
+ | * Improve non-volatile memory management by fixing a bug that could cause memory corruption when flashing the history or settings data. This is yet another improvement on top of what was done previously on v1.04. | ||
+ | * Fix operation time count when Orion XS is not charging (Off state) | ||
+ | * Fix phase configuration setting (issue introduced in beta10) | ||
+ | * Energy counters renaming/ | ||
+ | EVCS: | ||
+ | * Network settings rewording | ||
+ | * Add new settings | ||
+ | GlobalLink: | ||
+ | * Add support for new model | ||
+ | MultiHS | ||
+ | * Add ESS Settings (now similar to the InverterRS family) | ||
+ | * Removed the solar data section | ||
+ | * Fix System configuration does not show Phase selection buttons | ||
+ | * Improve behaviour when scrolling solar history graphs. | ||
+ | ==== v6.10beta10 ==== | ||
+ | ** 2024-08-09 ** | ||
+ | Android: Fix firmware and settings files are not added to the library when opening from a file manager while VictronConnect is not already running | ||
+ | GX products: | ||
+ | * Better handle local MQTT connection for Venus versions supportin secured profiles | ||
+ | * Add firmware v1.07: | ||
+ | * Add line-to-line voltages | ||
+ | * Add neutral current | ||
+ | * Add split phase support (L1/L2) | ||
+ | * Add energy registration method | ||
+ | * Users can choose between vector (default), arithmetic and absolute | ||
+ | * Add roles for EV charger, heat pump, water pump and water heater | ||
+ | * Fix missing messages/ | ||
+ | * Fix Ethernet state being invalid in VictronConnect | ||
+ | **Below changes are already included in v6.08** | ||
+ | Lynx SmartBMS: | ||
+ | * Add firmware v1.11 | ||
+ | * Fix bug that prevented the device from automatically switching on after a low cell voltage. The Lynx BMS now switches on again when a charge voltage is detected on the system side. This bug was only in the NG versions. | ||
+ | * Add support for the " | ||
+ | * v1.10: | ||
+ | * Support for parallel BMS systems, which adds redundancy to a system. Detect other BMSs & optimize behavior for that case - implemented such that in case of no functional CAN-bus communication between the BMSs everything also works. No user setting is required for parallel support. Use in combination with Venus OS v3.40 or later, since that includes the new feature about combining the data into one total " | ||
+ | * Add 3 seconds delay to start-up procedure, for all system types, to detect parallel BMSs. | ||
+ | * Peukert adjusted to 1.02 and charge-efficiency to 99.5% for more accurate SoC calculation. | ||
+ | * VE.Bus firmware update: Fix error 123 when updating MultiPlus-II 48/ | ||
+ | * Add firmware v552 | ||
+ | ==== v6.10beta9 ==== | ||
+ | ** 2024-08-02 ** | ||
+ | * Fix connection to local MQTT via when Venus " | ||
+ | Orion XS: | ||
+ | * Fix Orion XS page does not open when selecting it on the devices list. This bug also affects the demo product. | ||
+ | * On remote connections, | ||
+ | ==== v6.10beta8 ==== | ||
+ | ** 2024-08-01 ** | ||
+ | * Improve the layout of the main settings page | ||
+ | * Various fixes and improvements | ||
+ | * Fix connection to local MQTT via WebSocket Secure is broken | ||
+ | * Fix live data values of products freeze after 30 seconds when connected via local MQTT | ||
+ | Orion XS: | ||
+ | * Bug fixes | ||
+ | * Start displaying warning #67 BMS Connection lost. Previous fw version (v1.03) was not displaying the warning, even though the warning was internally activated. While active, the charger will be kept at " | ||
+ | * Improve non-volatile memory management by fixing a bug that could potentially cause memory corruption when flashing the history or settings data. | ||
+ | * Improvements | ||
+ | * Remove auto equalisation support. On previous FW versions, when equalisation was enabled, the charger would perform equalisation every charge cycle, which is not healthy for the battery. Now only the manual equalisation is supported. | ||
+ | * Allow VE.Smart Networking to be configured over VE.Direct. | ||
+ | * Add error #67 | ||
+ | Multi RS: | ||
+ | * Rename " | ||
+ | * Fix live data on remote connections when working as PV iverter | ||
+ | MPPT Solar Chargers: | ||
+ | * Make firmware v1.64 mandatory for the following models | ||
+ | * SmartSolar Charger MPPT 75/10 (A074) | ||
+ | * SmartSolar Charger MPPT 75/15 (A075) | ||
+ | * BlueSolar Charger MPPT 75/10 (A07C) | ||
+ | * BlueSolar Charger MPPT 75/15 (A07D) | ||
+ | * Add firmware v1.65 for SmartSolar 100/30-12V (A07E) | ||
+ | * Extend internal improvements made on v1.64 for all SmartSolar 100/30-12V models. | ||
+ | * Add firmware v3.16: | ||
+ | * Fix bug on synchronize charging over CAN when two or more MPPTs are connected. This could potentially cause the charger to jump absorption every day. | ||
+ | ==== v6.10beta7 ==== | ||
+ | ** 2024-07-13 ** | ||
+ | * Various fixes and improvemente for QR quick connect | ||
+ | * Show detailed information if a product is shown as an unknown product in the devices list | ||
+ | * Fix an issue where avatar pictures in certain VRM installations are shown rotated | ||
+ | * Make L1, L2 & L3 instant readout always visible | ||
+ | * Add support for security profiles (feature not released yet) | ||
+ | * Make possible to change security profile and set a password via Bluetooth | ||
+ | * Support connection to local MQTT via WebSocket Secure | ||
+ | * Do not show the GX in the product info page of attached products | ||
+ | MPPT chargers: | ||
+ | Multi RS: | ||
+ | * Make the " | ||
+ | * Add extra settings needed for the Without batteries mode | ||
+ | * Improve the overview main widget | ||
+ | * Add phase rotation settings | ||
+ | * Show the AC Input connection status in the overview main widget | ||
+ | * Add "Low SOC" alarm | ||
+ | * Move mode setting to the general settings menu. | ||
+ | * Improbe " | ||
+ | * Instant readout: Fix AC In & AC Out now working on remote connections when phase is not L1. | ||
+ | * Fixes on NS Log | ||
+ | * Fix mode button is sometimes misplaced | ||
+ | ==== v6.10beta6 ==== | ||
+ | ** 2024-06-28 | ||
__Download links:__ | __Download links:__ | ||
* iOS: Join TestFlight https:// | * iOS: Join TestFlight https:// | ||
Line 27: | Line 245: | ||
Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | ||
+ | * Fix app unresponsiveness for VRM users with a large number of installations | ||
+ | * Make settings lock feature more visible; a lock icon is shown in the settings page even when lock is not set. | ||
+ | * Various UI fixes | ||
+ | * Enable MQTT on LAN: | ||
+ | * When connected to a GX device on LAN, you can now access attached products to monitor and configure them. | ||
+ | * Enable MQTT on LAN and MQTT (Plain text) on the GX device to activate this feature. These settings are located in the Settings -> Services menu | ||
+ | * Future Venus versions will change how this feature can be enabled | ||
+ | * Add firmware v1.09: (Including changes from v1.08 & v1.07) | ||
+ | * v1.09 | ||
+ | * The problem with the 1000A models that a pre-charge error occurred when pre-charging large capacities at 48V has been solved. | ||
+ | * Improved pre-charge performance for all voltages. | ||
+ | * v1.08 | ||
+ | * Initial version for Lynx Smart BMS 500-NG and 1000-NG that supports the Lithium-NG batteries. | ||
+ | * The issue of the BMS waking up from sleep mode when battery is completely discharged has been fixed. | ||
+ | * ATC contact opens during updates. This is to prevent potentially dangerous situations if an overvoltage occurs during an update. | ||
+ | * The issue where the LED and AUX outputs were occasionally turned on for a second in sleep mode has been fixed. | ||
+ | * v1.07 | ||
+ | * Support for Lynx Smart BMS 1000A which includes following improvements: | ||
+ | * Improved current measurement for low currents. | ||
+ | * Variable fan speed based on BMS temperature and contactor dissipation. | ||
+ | MPPT RS: | ||
+ | * Add isolation resistance value to the demo product | ||
+ | Multi RS: | ||
+ | * Add new grid code related settings | ||
+ | * Fix the issue where feed-in disabled reasons do not update on remote connections. | ||
+ | * Add sustain voltage settings | ||
+ | * Add ESS Ac Power setpoint setting | ||
+ | ==== v6.10beta5 ==== | ||
+ | ** 2024-06-03 ** | ||
+ | Notes: | ||
+ | * Fix crashes when connecting a product via VE.Direct USB. Issue introduced in v6.10beta2 | ||
+ | * Fix firmware update notification is not cleared after updating the firmware on remote connections. | ||
+ | * Correct the issue where the selection dialog occasionally displays large gaps between options. | ||
+ | * Show profile pictures in the VRM installations list | ||
+ | * Fix issues when switching between landscape and portrait modes. | ||
+ | * VictronConnect now scales properly on Android when in floating window mode | ||
+ | * Make it possible to restore settings after a firmware update | ||
+ | * Fix number of phases on instant readout | ||
+ | Lynx SmartBMS NG: | ||
+ | * Fix battery tab show a white empty page on tablets in portrait mode. | ||
+ | * Hide batteries cells details on remote connections, | ||
+ | Multi HS: | ||
+ | * Mayour improvements in the main overall widget and in the detailed view. | ||
+ | * Update alarms and their icons | ||
+ | Phoenix & SUN Inverter: | ||
+ | * Add firmware v1.36: | ||
+ | * Add settings lock support | ||
+ | ==== v6.10beta4 ==== | ||
+ | ** 2024-05-01 ** | ||
+ | * Fix Role, Phase Configuration, | ||
+ | ==== v6.10beta3 ==== | ||
__Changes__ | __Changes__ | ||
Line 100: | Line 415: | ||
* Add Grid Code support. (Requires new firmware not available yet) | * Add Grid Code support. (Requires new firmware not available yet) | ||
- | ==== v6.05 (Released officially) ==== | + | ==== v6.09.1 (Released officially) ==== |
- | ** 2023-04-25 ** | + | ** 2024-09-24 ** |
+ | * iOS: [[https:// | ||
+ | * macOS [[https:// | ||
+ | Phoenix Smart Inverters: | ||
+ | * Fix Bluetooth firmware update problem for a recently shipped batch of Phoenix Smart Inverters. Note that this change unfortunately disables the Settings Lock feature. A new update that re-adds Settings Lock for the Phoenix Smart Inverters is expected soon. | ||
+ | ==== v6.09 (Released officially) ==== | ||
+ | ** 2024-09-10 ** | ||
+ | Orion XS: | ||
+ | * Fix bug on synchronize charging over CAN when two or more MPPTs are connected. In some rare situations this could potentially cause the charger to jump absorption. | ||
+ | * Improve behaviour when scrolling 30 day history bar graph | ||
+ | * Fix voltage between PE and Neutral is not shown. | ||
+ | ==== v6.08 (Released officially) ==== | ||
+ | ** 2024-08-07 ** | ||
+ | Orion XS: | ||
+ | * v1.10: | ||
+ | * Add firmware v1.36 | ||
+ | * Add support for settings lock | ||
+ | ==== v6.07 (Released officially) ==== | ||
+ | ** 2024-06-07 ** | ||
Line 109: | Line 510: | ||
* macOS [[https:// | * macOS [[https:// | ||
* Android: If you can't open the downloaded file from the downloads list try using a file browser. | * Android: If you can't open the downloaded file from the downloads list try using a file browser. | ||
+ | * Lynx Smart BMS 1000 NG:Add battery details page | ||
+ | ==== v6.06 (Released officially) ==== | ||
+ | ** 2024-06-06 ** | ||
+ | * Add firmware v1.64: | ||
+ | * Internal improvements for 100/30-12V model. | ||
+ | * Improve robustness of SmartSolar 75/10 and 75/15 during shutdown and startup. | ||
+ | * Improve robustness of SmartSolar 100/20 startup under high solar potential. | ||
+ | * Make firmware v3.15 update mandatory for SmartSolar 250/100 rev2 | ||
+ | * Add LED pulse output to indicate energy flow. Default the LED pulses every 10Wh. | ||
+ | * Several ethernet related improvements that should help streamlining the firmware update procedure. | ||
+ | * Update the bootloader to v1.04 to benefit from the same ethernet improvements as mentioned above. | ||
+ | * Add settings lock exceptions | ||
+ | * Add support for SmartShunt 300A model | ||
+ | ==== v6.05 (Released officially) ==== | ||
+ | ** 2023-04-25 ** | ||
Line 174: | Line 614: | ||
==== v6.00 (Released officially) ==== | ==== v6.00 (Released officially) ==== | ||
- | ** 2023-03-13 ** | + | ** 2024-03-13 ** |
victronconnect/beta.1714522193.txt.gz · Last modified: 2024-05-01 02:09 by jperez
