victronconnect:beta
victronconnect:beta [2024-08-09 15:35] – [v6.10beta10] jperez | victronconnect:beta [2024-09-24 10:05] (current) – [v6.09.1 (Released officially)] jperez | ||
Line 11: | Line 11: | ||
(Currently available betas are on top. See further below for official releases.) | (Currently available betas are on top. See further below for official releases.) | ||
- | ==== v6.10beta10 | + | ==== v6.10beta13 |
- | ** 2024-08-09 ** | + | ** 2024-09-11 ** |
__Download links:__ | __Download links:__ | ||
* iOS: Join TestFlight https:// | * iOS: Join TestFlight https:// | ||
Line 27: | Line 27: | ||
Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | ||
+ | __Changes__ | ||
+ | * Add Korean translation | ||
+ | Energy Meter: | ||
+ | * Hide L2-L3 line voltage in split phase configuration | ||
+ | * This was introduced in v1.07, which was only in VictronConnect beta. | ||
+ | * Improve VE.Can communication; | ||
+ | Solar Chargers: | ||
+ | * Fix the issue where "Load output configuration" | ||
+ | ==== v6.10beta12 ==== | ||
+ | ** 2024-09-07 ** | ||
+ | VE.Bus Inverter/ | ||
+ | * Fix error 122 when updating VE.Bus BMS V2 based systems | ||
+ | * Fix system configuration missing phase selection buttons | ||
+ | SmartShunt: | ||
+ | Lynx Smart BMS: | ||
+ | * Improve mode button visibility | ||
+ | * Fix maximum starter voltage value for BMV & SmartShunt demos | ||
+ | ==== v6.10beta11 ==== | ||
+ | ** 2024-08-30 ** | ||
+ | * Restore the " | ||
+ | Orion XS: | ||
+ | * Add firmware v1.05 update (mandatory) | ||
+ | * Improve non-volatile memory management by fixing a bug that could cause memory corruption when flashing the history or settings data. This is yet another improvement on top of what was done previously on v1.04. | ||
+ | * Fix operation time count when Orion XS is not charging (Off state) | ||
+ | * Fix phase configuration setting (issue introduced in beta10) | ||
+ | * Energy counters renaming/ | ||
+ | EVCS: | ||
+ | * Network settings rewording | ||
+ | * Add new settings | ||
+ | GlobalLink: | ||
+ | * Add support for new model | ||
+ | MultiHS | ||
+ | * Add ESS Settings (now similar to the InverterRS family) | ||
+ | * Removed the solar data section | ||
+ | * Fix System configuration does not show Phase selection buttons | ||
+ | * Improve behaviour when scrolling solar history graphs. | ||
+ | ==== v6.10beta10 ==== | ||
+ | ** 2024-08-09 ** | ||
__Changes__ | __Changes__ | ||
Line 348: | Line 415: | ||
* Add Grid Code support. (Requires new firmware not available yet) | * Add Grid Code support. (Requires new firmware not available yet) | ||
- | ==== v6.08 (Released officially) ==== | + | ==== v6.09.1 (Released officially) ==== |
- | ** 2024-08-07 ** | + | ** 2024-09-24 ** |
Line 355: | Line 422: | ||
* iOS: [[https:// | * iOS: [[https:// | ||
- | * [[http:// | ||
* macOS [[https:// | * macOS [[https:// | ||
* Android: If you can't open the downloaded file from the downloads list try using a file browser. | * Android: If you can't open the downloaded file from the downloads list try using a file browser. | ||
+ | Phoenix Smart Inverters: | ||
+ | * Fix Bluetooth firmware update problem for a recently shipped batch of Phoenix Smart Inverters. Note that this change unfortunately disables the Settings Lock feature. A new update that re-adds Settings Lock for the Phoenix Smart Inverters is expected soon. | ||
+ | ==== v6.09 (Released officially) ==== | ||
+ | ** 2024-09-10 ** | ||
+ | Orion XS: | ||
+ | * Add firmware v3.16: | ||
+ | * Fix bug on synchronize charging over CAN when two or more MPPTs are connected. In some rare situations this could potentially cause the charger to jump absorption. | ||
+ | * Improve behaviour when scrolling 30 day history bar graph | ||
+ | * Fix voltage between PE and Neutral is not shown. | ||
+ | ==== v6.08 (Released officially) ==== | ||
+ | ** 2024-08-07 ** | ||
Line 447: | Line 548: | ||
* Add settings lock exceptions | * Add settings lock exceptions | ||
+ | * Add support for SmartShunt 300A model | ||
==== v6.05 (Released officially) ==== | ==== v6.05 (Released officially) ==== | ||
** 2023-04-25 ** | ** 2023-04-25 ** |
victronconnect/beta.1723210500.txt.gz · Last modified: 2024-08-09 15:35 by jperez
