victronconnect:beta
victronconnect:beta [2024-09-11 17:00] – [v6.10beta12] jperez | victronconnect:beta [2024-09-24 10:05] (current) – [v6.09.1 (Released officially)] jperez | ||
Line 17: | Line 17: | ||
* iOS: Join TestFlight https:// | * iOS: Join TestFlight https:// | ||
Line 39: | Line 39: | ||
Solar Chargers: | Solar Chargers: | ||
- | * "Fix the issue where "Load output configuration" | + | * Fix the issue where "Load output configuration" |
==== v6.10beta12 ==== | ==== v6.10beta12 ==== | ||
Line 415: | Line 415: | ||
* Add Grid Code support. (Requires new firmware not available yet) | * Add Grid Code support. (Requires new firmware not available yet) | ||
- | ==== v6.09 (Released officially) ==== | + | ==== v6.09.1 (Released officially) ==== |
- | ** 2024-09-10 ** | + | ** 2024-09-24 ** |
__Download links:__ | __Download links:__ | ||
Line 422: | Line 422: | ||
* iOS: [[https:// | * iOS: [[https:// | ||
- | * [[http:// | ||
* macOS [[https:// | * macOS [[https:// | ||
* Android: If you can't open the downloaded file from the downloads list try using a file browser. | * Android: If you can't open the downloaded file from the downloads list try using a file browser. | ||
+ | __Changes__ | ||
+ | Phoenix Smart Inverters: | ||
+ | * Fix Bluetooth firmware update problem for a recently shipped batch of Phoenix Smart Inverters. Note that this change unfortunately disables the Settings Lock feature. A new update that re-adds Settings Lock for the Phoenix Smart Inverters is expected soon. | ||
+ | ==== v6.09 (Released officially) ==== | ||
+ | ** 2024-09-10 ** | ||
__Changes__ | __Changes__ |
victronconnect/beta.1726066849.txt.gz · Last modified: 2024-09-11 17:00 by jperez
