victronconnect:start
victronconnect:start [2019-07-30 11:08] – [9.1 Cannot find my device (Bluetooth)] evandromr | victronconnect:start [2021-01-11 13:04] (current) – link was incorrect boekel | ||
- | Welcome | + | |
- | *For a list of products compatible with VictronConnect please see section: | + | |
- | * Click [[https:// | + | |
- | VictronConnect can be used on devices running on Android, iOS, Windows, and macOS X. | + | |
- | ===== 2. Connecting ===== | + | |
- | ^ Method | + | |
- | | [[ve.direct: | + | |
- | | [[https:// | + | |
- | Use the [[# | + | |
- | ==== 2.1 Bluetooth Smart - Pairing and Connecting ==== | + | |
- | - Enable the Bluetooth setting on your device, but do not pair outside of VictronConnect. | + | |
- | ==== 2.2 Changing the Bluetooth Smart PIN code ==== | + | |
- | **To prevent unauthorised connections to your device we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456.** | + | |
- | To change the PIN code: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | + | |
- | If the dongle PIN code is lost, it can be reset to 000000. The way you reset depends on which product you are using: | + | |
- | === Blue Smart Solar Charger === | + | |
- | The minimum required Android version to run VictronConnect is 4.1. | + | |
- | The minimum required Android version to connect to a Victron product via Bluetooth is 4.3. | + | |
- | Required hardware is ARMv7 and later, as well as x86. | + | |
- | === Android 4.1 and 4.2 === | + | |
- | You may find that USB On-The-Go (USB OTG) does work on devices with Android 4.1 or 4.2. | + | |
- | Even though some devices have Bluetooth 4.0 aka Bluetooth Smart hardware, Android versions earlier than 4.3 are not implemented such that they can be used by VictronConnect. If you are using a device running on version before 4.3, VictronConnect will not be able to see, nor connect to Victron Bluetooth Smart products. | + | |
- | === Android 4.3 and 4.4 === | + | |
- | No known issues. | + | |
- | === Android 5 === | + | |
- | === Access to location services required? === | + | |
- | | Huawei | + | |
- | | Lenovo | + | |
- | | Samsung | + | |
- | ==== 3.4 Apple iOS iPhones and iPads === | + | |
- | VictronConnect works on the following iPhones and iPads, which have Bluetooth 4.0 (BT LE).\\ (iOS 8 or later required): | + | |
- | * iPhone 4S and later (due to Bluetooth Low Energy support) | + | |
- | * iPad, 3rd generation and later | + | |
- | ===== 4. Application overview ===== | + | |
- | ==== 4.1 Screenshots (click to enlarge) ==== | + | |
- | **Device list**\\ | + | |
- | Clicking on ' | + | |
- | *To access ' | + | |
- | From ' | + | |
- | The ' | + | |
- | From ' | + | |
- | **Windows**\\ | + | |
- | **macOS X**\\ | + | |
- | ==== 4.2 Videos ==== | + | |
- | {{youtube> | + | |
- | ==== 4.3 Renaming your devices ==== | + | |
- | ==== 4.4 Importing and converting a GX Product Family database File ==== | + | |
- | This feature is not available in the iOS mobile version of VictronConnect. | + | |
- | ===== 5. Product alarms & errors ===== | + | |
- | ===== 6. Settings files ===== | + | |
- | This constraint only applies when opening files from the settings file manager for inspection. Loading files from a product settings page to restore it is always possible as long as VictronConnect version is equal or greater than the one used to create the settings file. | + | |
- | ===== 8. Firmware updates===== | + | |
- | ==== 8.1 Introduction & automatic updates ==== | + | |
- | ==== 8.2 Updating to a self-supplied firmware file ==== | + | |
- | **iOS**: The current version of Google Chrome for iOS fails to download " | + | |
- | Go to the app that contains the firmware file, tap on it, and open it with VictronConnect. | + | |
- | Go to the " | + | |
- | ==== 8.3 Troubleshooting firmware updates ==== | + | |
- | A troubleshooting guide relevant to firmware updates can be found in chapter 9.3 | + | |
- | ==== 8.4 Error codes ==== | + | |
- | ^Error | + | |
- | | 3 | No VE.Direct product(s) found. | | + | |
- | | 4 | Unknown error occurred. Try again and check the product settings once updated. | | + | |
- | | 10 | Error closing com port. | | + | |
- | | 20 | Could not start updating, no updatable product found. | | + | |
- | | 26 | Updating failed, communication lost. Product might be unusable. Check connection and power supply.\\ Try again and check the product settings once updated. | | + | |
- | | 29 | Could not start updating, the firmware file is corrupt. | | + | |
- | | 31 | Updating failed, product is unusable. Try again and check the product settings once updated. | | + | |
- | | 32 | Could not start updating, entering boot mode failed. | | + | |
- | | 33 | Could not start updating, the firmware file is not found. | | + | |
- | | 90 | Could not start updating, firmware is not for this product. | | + | |
- | | 91 | Could not start updating, unknown product found. | | + | |
- | | 92 | Updating failed, erasing firmware failed. Product might be unusable. Try again and check the product settings once updated. | | + | |
- | | 93 | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. | | + | |
- | | 94 | Could not start updating, error reading configuration. | | + | |
- | | 95 | Product updated successfully, | + | |
- | | 96 | Updating failed due to version mis-match. Power cycle (off/on) your product and if that does not help try\\ updating again, and check the product settings once updated. | | + | |
- | | 97 | Dup executable too old. | | + | |
- | | 98 | Firmware file is not a valid dup file. | | + | |
- | | 99 | Product updated successfully, | + | |
- | | 100 | Cannot migrate settings because the application is not active. Manual action required. | | + | |
- | | 1 | Error reading file. | | + | |
- | | 2 | Victron BLE service not found. Please remove the product from the list of paired devices and retry. | | + | |
- | | 3 | Dfu BLE service not found. Please remove the product from the list of paired devices and retry. | | + | |
- | | 4 | The product disconnected unexpectedly. Perhaps the bond information is no longer valid? Please remove\\ | + | |
- | | 5 | A write to the device failed. | | + | |
- | | 6 | The product did not activate its bootloader - although it should have. | | + | |
- | | 7 | The product did not disconnect - although it should. | | + | |
- | | 8 | Timeout waiting for access to the Victron BLE service. | | + | |
- | | 9 | Timeout waiting for access to the Dfu BLE service. | | + | |
- | | 10 | Timeout waiting for a response. | | + | |
- | | 11 | Timeout while writing to product. Perhaps a pairing dialog is shown? Please retry. | | + | |
- | | 96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. | | + | |
- | | 97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. | | + | |
- | | 98 | An internal error occured (Data size exceeds limits). Please send a service report to Victron Energy. | | + | |
- | | 99 | The product could not store the firmware in its memory. Please retry, and if the problem persists, please contact Victron Energy. | | + | |
- | | 100 | An internal error occurred (CRC error). Please send a service report to Victron Energy. | | + | |
- | | 101 | An internal error occurred (Data length error). Please send a service report to Victron Energy. | | + | |
- | | 102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. | | + | |
- | ===== 9. Troubleshooting ===== | + | |
- | ==== 9.1 Cannot find my device (Bluetooth) === | + | |
- | * Only one device can be connected to a product. Make sure that no other device: phone/ | + | |
- | If none of the above helps, and if your device is already paired to a product, remove the pairing completely from your phone/ | + | |
- | See section [[# | + | |
- | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. Keep your mobile device as close to the product as possible. If the update fails even after many attempts, try using another phone or tablet ...if possible an Apple iOS device - they usually work without any issues. After the update, you may find you can use the phone with which you were having difficulty. | + | |
- | ==== 9.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== | + | |
- | cd / | + | |
- | http:// | + | |
- | ==== 9.5 VictronConnect on Windows doesn' | + | |
- | ==== 9.6 VictronConnect on Android doesn' | + | |
- | ==== 9.7 How to create a VictronConnect Service Report ==== | + | |
- | To do this, | + | |
- | - Select Settings | + | |
- | ===== 10. Compatible Victron products ===== | + | |
- | | MPPT 100/ | + | |
- | | MPPT 150/ | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | (*) Note that we have two different models of 150/70 and 150/85 Solar Chargers: | + | |
- | For systems with a [[venus-os: | + | |
victronconnect/start.1564477737.txt.gz · Last modified: 2019-07-30 11:08 by evandromr
