VRM Portal Alarms and monitoring
The VRM Portal constantly watches over your system and can inform by email if something is amiss. There are four categories of monitoring:
- The no data alarm: monitors connection between the Portal and the Victron installation
- Automatic alarm monitoring: monitors a predefined list of parameters on all connected products
- Geofence: monitors location (requires a Color Control GX with USB-GPS)
- User configurable alarms
No data alarm
Monitors a predefined list of parameters on all connected products. With this feature, it is no longer necessary to manually configure alarm rules for all the different parameters. An email will be sent if any of below list of parameters enters an Alarm state, and optionally also for Warnings. A recovery email will be sent if the parameter returns to its normal value.
You can set the monitor to send an email alert for alarms only, for warnings and alarms, or disable it entirely“. The default for new sites is Only alarms:
Predefined list of monitored parameters
VE.Bus products (Multi, Inverter and Quattro)
- VE.Bus state
- VE.Bus Error
- Temperature alarm
- Low battery alarm
- Overload alarm
BMV and Lynx Shunt VE.Can
- High voltage alarm
- Low voltage alarm
- High starter-voltage alarm
- Low state-of-charge alarm
- Low battery temperature alarm (BMV-702 only)
- High battery temperature alarm (BMV-702 only)
- Mid-voltage alarm (BMV-702 only)
- Low fused-voltage alarm (Lynx Shunt only)
- High fused-voltage alarm (Lynx Shunt only)
- Fuse blown alarm (Lynx Shunt only)
- High internal-temperature alarm (Lynx Shunt only)
- Low starter-voltage alarm (Lynx Shunt only)
Solar charger
- Charger fault
- Charge state
- Equalization pending
- Alarm condition
- Low voltage alarm
- Error code
Skylla-i charger
- Charger fault
- Charge state
- Error
- Low voltage alarm
Lynx Ion BMS
- Error code
- Error
Advanced rules, including hysteresis can be configured for all parameters available in the VRM database.
Geofence
Typically used for rental vehicles and boats. Below examples shows a geofence that will give an alert when the user of the boat leaves the lake. An alarm will also be generated when the location data is no longer coming in, for example when the user removed the GPS. Use this in combination with the No data alarm for full coverage.
