vrm_portal:change_log
vrm_portal:change_log [2024-09-03 14:38] – aleximb | vrm_portal:change_log [2024-09-25 15:34] (current) – aleximb | ||
+ | === 2024-09-25 === | ||
+ | * Custom widgets: Fix icon for ' | ||
+ | * Teams: Show team admins directly on the page, instead of hidden in a modal | ||
+ | * Installation Users: Users are now sorted alphabetically | ||
+ | * VRM Updates: Remove green "Your page was reloaded because a new version of the VRM portal was available" | ||
+ | * Admin: Remove the duplicate admin diagnostics page in favour of the installation diagnostics page | ||
+ | * Login: Fix language always being set to English after using the demo account | ||
+ | * Dynamic ESS: Make sure users can continue with the form after changing bidding zone | ||
+ | === 2024-09-18 === | ||
+ | * Accesstokens: | ||
+ | * Dynamic ESS: Allow users to toggle if their Octopus Energy prices are including VAT | ||
+ | === 2024-09-17 === | ||
+ | * Dashboard: Fix graphs getting cropped and zoom issue on smaller devices. | ||
+ | * GUI-v2: Hide GUI-v2 menu entry when Two-way communication is Off or use the VRM Portal Mode is Off. | ||
+ | * Dynamic ESS: Add Octopus Energy as an energy provider for United Kingdom. | ||
+ | * Installation groups: Add Technician role for teams and installation groups. | ||
+ | * Installation groups: Make it clear which users have access to a site through an installation group. | ||
+ | * Economic report: Allow downloading the report in CSV, in addition to XLSX. | ||
+ | * Custom widgets: Connect the dots for DESS Scheduled SoC data points in a line. | ||
+ | * Fix missing translations for the error modals of reset password and registration flows. | ||
+ | === 2024-09-12 === | ||
+ | * Dashboard: Fix EVCS summary blocks staying visible when EVCS graph is not selected anymore. | ||
+ | === 2024-09-11 === | ||
+ | * Advanced: Add new widget types for Energy Meter: Grid Meter Summary, Grid Meter Energy Summary, Grid Meter Voltage and Current, Grid Meter Combined, PV Inverter Voltage and Current, PV Inverter Combined. | ||
+ | === 2024-09-10 === | ||
+ | * Installations overview: Improve performance by incrementally loading the installations list. | ||
+ | * Installations overview: Show all tank levels in installations overview map tooltip. | ||
+ | * Advanced: Fix wrong color for some widgets in the " | ||
+ | * Dashboard: Add a datepicker for the DESS graphs | ||
+ | * Device controls: Add solar and wind priority. Read more on that [[https:// | ||
+ | * Dashboard: Fix access to `/ | ||
+ | * Dynamic ESS: Improve consumption forecast, prevent peaks to have too much influence on minimum/ | ||
+ | * Dashboard: Prevent calling `/ | ||
+ | * Dashboard: Change how the total forecasted solar and consumption is calculated in cards under the | ||
+ | system overview chart. | ||
+ | === 2024-09-06 === | ||
+ | * Teams: Allow creating a team with users without specifying their names. | ||
=== 2024-09-03 === | === 2024-09-03 === | ||
* Advanced: SoC graphs now have the y-axis go from 0 to 100 by default | * Advanced: SoC graphs now have the y-axis go from 0 to 100 by default |
vrm_portal/change_log.1725367102.txt.gz · Last modified: 2024-09-03 14:38 by aleximb
