vrm_portal:change_log
VRM Portal Changelog
2024-09-18
- Accesstokens: Stop storing JWT data unnecessarily when using accesstokens for authentication
2024-09-17
- Dashboard: Fix graphs getting cropped and zoom issue on smaller devices.
- GUI-v2: Hide GUI-v2 menu entry when Two-way communication is Off or use the VRM Portal Mode is Off.
- Dynamic ESS: Add Octopus Energy as an energy provider for United Kingdom.
- Installation groups: Add Technician role for teams and installation groups.
- Installation groups: Make it clear which users have access to a site through an installation group.
- Economic report: Allow downloading the report in CSV, in addition to XLSX.
- Custom widgets: Connect the dots for DESS Scheduled SoC data points in a line.
- Fix missing translations for the error modals of reset password and registration flows.
2024-09-12
- Dashboard: Fix EVCS summary blocks staying visible when EVCS graph is not selected anymore.
2024-09-11
- Advanced: Add new widget types for Energy Meter: Grid Meter Summary, Grid Meter Energy Summary, Grid Meter Voltage and Current, Grid Meter Combined, PV Inverter Voltage and Current, PV Inverter Combined.
2024-09-10
- Installations overview: Improve performance by incrementally loading the installations list.
- Installations overview: Show all tank levels in installations overview map tooltip.
- Advanced: Fix wrong color for some widgets in the “Total” tooltip item.
- Dashboard: Add a datepicker for the DESS graphs
- Device controls: Add solar and wind priority. Read more on that here
- Dashboard: Fix access to `/dynamic-ess-settings` endpoint for siteshare users
- Dynamic ESS: Improve consumption forecast, prevent peaks to have too much influence on minimum/maximum consumption levels
- Dashboard: Prevent calling `/cache-location` twice on dashboard load to reduce unnecessary load
- Dashboard: Change how the total forecasted solar and consumption is calculated in cards under the
system overview chart.
2024-09-06
- Teams: Allow creating a team with users without specifying their names.
2024-09-03
- Advanced: SoC graphs now have the y-axis go from 0 to 100 by default
- Replaced Google Maps with Mapbox implementation
2024-08-30
- Installation overview: Add new filter options to the installation overview map based on the installation status
- Installation overview: Long names have '…' at the end so it doesn't overflow
- Installation overview: Faster load time
- Dashboard: Installation graph legends are now persisted throughout devices
- Dashboard: Only show DESS related alarms when DESS is (still) enabled on an installation
- DESS: Be able to change DESS settings so that when prices are negative, they are counted as 0
- Application: Prepare for new (authenticated) Redis instance
2024-08-26
- Firmware update: Prevent empty error modal from showing after updating firmware.
2024-08-23
- Installations overview: Fixed all downloads for users that have above a certain amount of sites.
2024-08-20
- Installations overview: When downloading the production report, only include the installations filtered on in the overview.
- Dynamic ESS: Switch order of dashboard tabs to most used first.
- Event log: Log “generator reset interval” event to the site's event log.
- Screensaver: Fix recognising special characters, removing conflict with screenshot on Windows shortcuts.
- Dynamic ESS: Fix configuration wizard showing error when toggling Dynamic ESS off without configuring it.
- Dynamic ESS: Fix configuration wizard not accepting comma as a decimal separator on Step 2.
- Advanced: Fix tooltip color for the Total not matching the legend color.
2024-08-17
- Dashboard: fix forecasted battery disappears from installation graph.
2024-08-15
- Replace GX: allow searching for replacement sites.
2024-08-15
- Alarms: fix validation issue causing users to not be able to edit alarm rules.
2024-08-14
- Event log: Fix empty language updates.
- Event log: Fix storing a settings update entry when opening the Advanced page.
2024-08-13
- Installation overview: Show alarms in map tooltips.
- Installation overview: Tag filter condition changed from union to intersection (e.g. sites with a certain tag and active alarms)
- Dashboard: Improve contrast for icons and units.
- General: Redirect users with one installation to dashboard after login.
- Advanced: Fix race condition in loading 3 phase widgets.
- GUI-v2: Reuse the same instance of the application for the same site every time it's open, fixing iOS crashing.
- GUI-v2: Fix bug where after opening gui-v2 copying, pasting and cutting would not work in VRM.
2024-08-09
- Add installation: re-direct user to installation when the identifier is already linked to the account.
2024-08-06
- Dashboard: Remove tags from a site when deleting or unlinking the team or installation group.
- API Docs: Add short explanation on how ratelimiting works.
- Internal: Added E2E tests for Dashboard Controls.
- Update translations
2024-07-30
- Dashboard: Rename EV Charging station to EVCS to make it more concise and consistent with the other UIs.
- Dashboard: Remove EVCS Power detail since it's already displayed at the top of the tile.
- Diagnostics: Remove query limit. Previously limited to 1000 rows.
- Installation overview: Add support for touch interactions to the mini graphs
- Alarm log: Add pagination. Previously limited to 1000 rows
- Firmware update: Fix ID parsing logic resulting in UI issue
- Device List: Fix table overlapping the title of the page on loading
- API: Unify data type of idDataAttribute
- Internal API: Add endpoint for running (specific) MQTT commands from the API
- Venus Security 2024: Add Readonly mode for Realtime communication. Replace usage of `vl` and `tw` with `vrm` attributes.
2024-07-26
- Add Installation: fix bug where installation name wouldn't be applied
- Add Installation: re-apply URL parameters, making it easier to add an installation from e.g. VictronConnect
- Add Installation: redirect to the newly connected installation after successful connection
2024-07-24
- Installation Overview: Option to download .xlsx with all columns, or mimic the UI selected columns
- Groups/Teams: Now able to set admins on a group/team, and change who is owner of the group/team
- Dashboard: Fix for showing minimal dashboard layout when there is only a grid meter
- Device List: New Battery icons
- Advanced: New Battery icons
- Advanced: Fix widgets positioning logic
2024-07-16
- DESS: fix issues with energy provider form
- Dashboard: Pv Inverter line connected to the multi in detail mode
- Installations Overview: Fixed installation name header column doesn't follow you on mobile
2024-07-09
- Dashboard: Show minimal layout when the only configured devices are: Gateway, Grid meter, AC meter
- Dashboard: Fix AC input total not showing
- Dashboard: Fix EVCS showing incorrect device status
2024-07-06
- Advanced: Add Multi-RS Battery Voltage and Current widget
2024-07-05
- General: Added a summer theme
- Display preferences: Added an option to disable custom VRM themes if the default look is preferred.
2024-07-04
- Advanced: Fix the AC In and AC Out charts now showing correctly when data is only present for one of the phases.
2024-07-03
- Device list: Add battery connection information, battery manufacturer and battery family as rows in the table, when known.
- Device list & Advanced: Add support for Parallel battery system
2024-07-02
- Nav bar: Fixed bug where language option in preferences would not get highlighted when selected
- All Pages: Make headers (title and banners) look consistent in all the pages
- Installation overview: Fixed bug where the alarm icon was missing in specific situations
- General settings / Add installation - Improved add/replace GX device flow
- Dashboard: Fixed dashboard flicker for the affected sites
2024-07-01
- Dashboard: Fix broken dashboard for specific custom device names
2024-06-27
- Internals: Allow technicians to use remote console
- Device List: Allow technicians to use Remote VEConfigure and Firmware Update
2024-06-26
- Admin: Installation search results can be exported to an .xlsx file
- Admin: Number of installations that match data attribute search displayed
- Dashboard: Redesign, and styling improvements, minor bug fixes
- Device list & Advanced: Add generic generator icon
- Internals: change MQTT propagation
2024-06-24
- Victron Connect via VRM: Fix realtime updates in Victron Connect for the technician role.
2024-06-18
- Device list: Add EVCS Control Panel button for remotely accessing the EVCS settings.
- Firmware updates: Remove the ID column.
- Alarm rules: Set value limit validation to alarm time.
- Installation overview: Show tooltips in the installation overview minigraphs to clarify their meaning.
- Installation overview: Plot Max load values for the Load charts.
- What's new: improve legibility of text in dark mode
2024-06-17
- DESS: Fix formatting on battery form page
2024-06-14
- API: Fix error on dashboard endpoint when simplified and no data available
2024-06-12
- Advanced: fix invisible dots for specific data attributes used in custom widgets
- What's New (changelog): improve legibility in dark mode
- DESS: allow partial updates to DESS settings & slightly improve error handling
- DESS: remove the limit of 10 for the battery cycle cost input for currencies other than euro
- DESS: Allow support of half hour prices when using fixed price scheduling
- Advanced: fix issue where advanced widgets would not load when the site is accessed as site share without logging in
- Device list: fix fuel cell icons not showing
- Settings Users: Change full control slider for users directly assigned to an installation into dropdown, with 3 options: Admin (full control), Read only (not full control), Technician (new)
- Advanced: For custom widgets with Solar Forecast series, show data in kWh instead of Wh
- DESS: now supports 30 min slots for fixed prices
2024-06-11
- Device list & Advanced: New fuel cell icon.
- Dashboard: Consistently format decimals for both negative and positive values.
2024-06-06
- Languages: add support for the Czech language.
2024-06-05
- Remote console 2: Finalise aspect ratio and cross for specific devices. Refactor and fix rotation issue on chrome for remote console.
- Remote console 2: Fix the issue where the native keyboard would never show up on Android
2024-05-31
- Dashboard: bugfix: Charts on a shared site are now visible again on dashboard and advanced
2024-05-30
- Advanced: Copy Layout Field is now clickable in the whole input text
- Dashboard: Show consumption and battery forecast when available
- Bug fix: Groups name cannot be blank anymore
- Navbar: Use DEA attribute for DESS capability
- Alarms: Improve validation clarity + behaviour on non-chromium browsers in modify/create alarms
- Add icons for Cerbo-S GX and Cerbo GX MK2
- Admin: Added sticky headers to attributes table
- Improvement: Correct keyboard pops up on mobile when logging in, entering numbers, etc.
2024-05-27
- Installations overview: Added a new map that provides fleet managers with more information about the status of their installations at a glance.
2024-05-21
- GUI V2: Aspect ratio of remote console 2 adjusted and cosmetic changes for mobile devices
- Economic reports: now possible to use in calculation to-grid slider that simulates energy sold to grid
- DESS: Move “Start Configuration” to the top of the page
- Installations Overview, Tags, Dashboard, Advanced: Make big tags fit the screen
2024-05-16
- Navbar: Update the link to the Manual
- What's New: minor styling changes
- Dashboard and Advanced: Rework of the date picker including many bug fixes and a small visual update
- DESS formula: Now possible to copy and paste pricing formula. Also possible to use ctrl+v
- Installation Overview Data XLSX Download: Add generator runtime till service
2024-05-14
- Settings: Location; added 'confirm reset' modal when resetting the installation location
2024-05-10
- Advanced: (Restricted) admins can create custom widgets to troubleshoot problems
- Alarms: Fix 'notify after time' field in float alarms on PUT update
2024-05-07
- Firmware upgrade: Adjusted the table styling for updatable devices
- E-Mails: Don't show a “personal message” block if it was left empty
- DESS Settings: Add Green Mode
- DESS Prices: Monitor missing price data + increase timeouts
- DESS: Turn off and don't schedule DESS for sites that are not DESS capable
- DESS: On mobile, when selecting an hour from the static price ranges for sell and buy prices, the hour picker stays inside of screen
- Alarms page: Fix PUT updates (except 'notify after time' field, work in progress)
2024-05-03
- Dashboard: Cap the target SoC line of Dynamic ESS to 100%.
2024-05-02
- Dashboard: Fetch latest widget data when tab becomes active after more than 30 minutes of inactivity.
- Dashboard: Show forecast warning when the location changes more than 10 km
- Advanced: Bugfix - keep high granularity in 'System' widgets after adding Solar Irradiance widget
- Tables in Firebox: Removed scroll when not necessary
2024-04-25
- DESS: Remove check for specific Venus OS verions
- Setup DESS: Improve the margins of the buttons
- Installations Overview: Add temperature column
- Dynamic ESS: Disallow max (dis)charge limits to be zero to prevent mathematical issues
2024-04-11
- Installation overview: Update xls to reflect the installation overview page
2024-04-09
- General: Update the node.js version to 18
- Proxy relay: Update error text, let users know they should have remote support running
- Login: Improve validation + internals
- Installation Settings: Max character limit for installation name
- Dashboard Controls: Delete the [i] tooltip on active SOC limit
2024-04-04
- Dashboard: Fix, show distinct graphs for EVCS(s) on input and output side of multi
- Alarms: Change communication monitoring alarm to be more descriptive (vrm stopped logging)
- Data Download: Improve the speed of data export feature
- Installation users, groups and teams: Fix 'Full Control' setting not toggling upon click
2024-04-03
- Installation overview: Fix map info window bug on cluster click
- Installation overview: Increase map performance for large number of installations when zoomed in
- General: Navbar bug fix
- Dashboard - EVCS historical graph
- DESS - Fix negative values appearing in the graph
- Users: Improve the empty states of the table
- Teams: Improve the empty states of the table
- Installation Groups: Improve the empty states of the table
- Dashboard: Only show Forecast for the Consumption and Solar when checking dates in the Future
- Advanced: Cancel requests when leaving advanced page
2024-03-28
- Update mechanism: Fix edge cases of the update mechanism: do not refresh when the VNC Remote console is open.
- Translations: Add more translation keys for field like “Type here..”, etc.
- Installation overview: Add 2 new column,Running since and Runtime until service.
- Installation overview: Sort the tanks by type.
- Installation overview: Add two warnings: Tank is low and Runtime until service.
2024-03-27
- Android and iOS: there is now a new status widget with chart ranges and the old version as an alternative
- iOS: inform the user when the widget cannot be edited if there is no internet or the user is logged out
- DESS: Show negative value for energy price when below 0 in the Schedule → Energy prices graph
2024-03-21
- DESS: Set battery capacity before turning DESS On
2024-03-20
- Release Dynamic ESS (DESS)
- Remote Console: On mobile, make the “Rotate your screen” text more readable in dark mode.
2024-03-19
- Two-Factor Authentication: Ability to copy the TOTP secret.
- Tags: Fix in mobile view that the tags don't overflow.
- Advanced: Disable/Enable all widgets in Gateway including System Overview.
- Advanced: Disable the option to enable/disable all widgets while in search mode.
- Advanced: Improve cloning of widgets from one installation to another, no longer dependent on matching device instance.
- Advanced: Cloning custom widget also clones y-axis settings.
2024-03-16
- Device controls: Fixed a loading issue for generator controls.
2024-03-14
- Installation overview: Add tanks and temperature sensor data to the xls export
- Emails: Add missing translations for emails that did not have it before.
- Device controls: Added new controls for generator run time until service.
2024-03-13
- General: Fixed multiple bugs with the banners in VRM: banner covering page elements, banners not closing, banner closing button not being clickable. Also made the button area bigger to make closing easier on mobile devices
- Installations overview: Prevent the “Add” button on the installation overview page from overlapping with title text
2024-03-07
- Device list & Advanced: Add All-in-1 device icon.
- Users: Make it possible to remove/unlink any team as an installation owner.
- GUI-V2: Add compileStreaming and fix bug that did not display state in the loader for a brief moment
2024-03-04
- Add menu entry for the new Remote Console (GUI-v2) for users running the Venus OS BETA version.
2024-02-26
- iOS: added option to choose graph range between 'today', 'tomorrow' and 'week' in the large status widget.
2024-02-23
- Login: Prevent unnecessary scrolling.
2024-02-22
- Add error codes to all error messages displayed in the red banners.
- Firmware update: Fix GX version warning
2024-02-21
- Advanced: Add total charged energy to EV charger summary widget
- General: Add delete feature for old VEBus connected devices
2024-02-20
- Dashboard: Translate solarcharger state.
- Controls: Add “Passthrough” mode for MultiRS.
- Site settings: Fix currency styling.
- Internals: Fix translation fallback when translation is not defined in a nested structure.
2024-02-15
- Settings/Users: Added Admin column to Groups and Teams
- Advanced: “Show Range Values” keeps it's status after refresh.
2024-02-14
- Advanced: Fix the bug where tooltips left a scroll on the page.
- Advanced: Make synchronized tooltips work consistently.
2024-02-13
- Advanced: Add new Alternator widgets for usage in combination with Orion XS.
- General: Admins must have 2FA enabled to use the VRM platform.
- General: Prevent disabled buttons from changing the size.
- Venus OS Large, Reporting, Recurring Reports, and Report Templates: Added titles to the pages
2024-02-12
- Dashboard: Add custom name for each individual tracker of devices with multiple trackers. This currently includes Multi-RS, Inverter-RS and MPPT-RS.
- Installation overview: Downloadable reports now include “Service interval (hours)”, “Service warning”, “Runtime until service (hours)”
- Venus OS Large: Add card for the new Node-RED Dashboard v2.
2024-02-09
- Advanced: Add new DC-DC Converter widgets for Orion XS.
- Advanced: Allow users to disable all widgets easily.
- Advanced: Doubled the maximum number of enabled widgets.
- API: Update allowed origins in CORS settings.
- Device list: Added ‘Position’ data attribute to EV Charging Station.
2024-02-05
- Dashboard: Fixed graph breaking on missing data
- General: Improved API field validation error messages
2024-02-02
- Device list: Show and explain 'last updated' time for VE.Bus serial numbers.
2024-02-01
- Device list: Add Mopeka wireless tank sensor.
- Firmware updates: Fix update status modal not closing.
2024-01-31
- Advanced: Data downloads that have an interval greater than 4 hours will be sent by email and not downloaded in the browser
- Device list: Add serial number for DC-DC converters.
2024-01-30
- Advanced: Send email to user to notify when a data download fails
- Device list & Advanced: Add Orion XS icons
- Photos: Don’t stretch the image to the full width of the modal, make the image in modal fit the screen when possible
2024-01-23
- Installation: Add the option to set the currency for your installation
- Firmware updates: Add support for updating Multis and Quattros with dissimilar firmware
- Show a request timeout message when a request times out.
2024-01-22
- Advanced: Fixed state widgets not showing tooltip on hover
2024-01-19
- Dashboard: Fixed installation data graph's time range when the installation has a different timezone from your device.
- Dashboard: Fixed AC inputs being disconnected for no clear reason in the installation overview.
- Dashboard: Fixed installation data error messages when switching to a future time range.
2024-01-16
- General: Fixed navigation bar issue on extra wide devices
- Advanced: Display Wh datapoints as barcharts instead of invisible dots
2024-01-15
- Internal: Changed MQTT subscription model
- Dashboard: Fixed energy flows being bugged when EVs are charging
- Login: Auto-fill the 2FA token when entered
- Accesstokens: Automatically delete old, unused VictronConnect tokens
2024-01-11
- Admin: Make installations overview page faster
2024-01-09
- Admin: Start grafana instance for user instead of installation
2024-01-05
- Internal: Automatically delete outdated access requests to installations
2024-01-02
- Advanced: Last seen in the Widgets dropdown gets periodically updated
- Profile: Require two factor authentication for changing email
2023-12-31
- Event log: Show at what time, for what device and by whom the alarm was cleared.
2023-12-28
- Dashboard: Fix graph today timeframe timezone issues
2023-12-27
- Profile: Send a confirmation email when email address changes
- Add module-level alarms for CAN-BMS batteries.
2023-12-21
- Happy holidays from the VRM team!
2023-12-19
- Dashboard: Fix loading controls
2023-12-18
- Advanced: Fix bug causing widgets to be missing
- MQTT: Use suppress republished option for keepalives
2023-12-09
- Internal: Added testing for access tokens.
2023-12-07
- Admin: Added support for partial search in device lookup
2023-12-05
- IOS: Fixed minor visual issue of extra space in the header
- Internal: Add performance monitoring to the frontend.
- Dashboard: Add “Now” indicator to live feed graph.
- API: Prevent the verification of passwords that are too long to save API resources.
2023-11-30
- Installation: Improve performance of installation pages by removing unnecessary network traffic
- API: Improve security on device information
2023-11-29
- Device list: Added last updated for outdated devices on VE-bus with their type of device
2023-11-28
- General: Added pipeline commands for VRM version. VRM version info displayed in navbar
- Attributes: Added installations attribute button.
2023-11-27
- Advanced: Fixed tap target size for the download report dropdown menu.
- Alarm logs: Fixed tap target size for the alarm logs dropdown menus.
- General: Close dropdown menus when interacting with other elements on the page.
2023-11-21
- Dashboard: Fixed tooltip error when hovering on installation data graph
- POEditor: Pulled translations
2023-11-20
- Advanced: Add warning that changes to widgets will not be permanent when using search mode
- Dashboard: Removed yellow line from the installation data graph
- Dashboard: Added modal explaining the meaning of 'Passthru'
2023-11-14
- Settings: Fixed geofence reset button.
- General: Fixed regression bugs introduced in 2023-11-13 changes related to firmware, remote and node red pages
- Advanced: Fixed visibility issues for the Remote VEConfigure widget
2023-11-13
- Sidebar: Fix bug where user has to scroll top in order to see installations
- General: Check user access settings before serving a page to them and take actions accordingly
- Nodered: Improvements related to the SignalK and Nodered proxy regarding user access and installation capabilities
- Nodered: Display nodered in the navigation only if the user has access to it
- Dashboard: Activate forecast when user clicks on a quickrange in the future
- General: Updated table styling
- Dashboard: Fixed AC Input value having a different value from console for some installations
2023-11-09
- General: Fix deleting user account linked to installations
- General: Fixes to prevent anchor duplication in URLs
- Advanced: Improve the time of the first load of widgets
- Dashboard: Custom device names are now shown in alarm warnings on the red banner
2023-11-08
- Android and iOS: Fixed file download.
2023-11-07
- Notes: Updated notes feature. Fixed headings that were broken and upgraded to new version.
2023-11-03
- Dashboard: Fixed bug causing battery temperature to appear in Celsius for Fahrenheit users
2023-11-01
- Advanced: Fixed legend items alignment of custom widgets
2023-10-31
- Advanced: Fixed the maximum battery percentage for the SOC to 100
2023-10-30
- Advanced: Fixed bug causing difficulties with highlighting the widgets on mobile devices after dragging
2023-10-29
- Dashboard: Fixed bug causing map to be missing from the dashboard weather card
- GX replacement: Get more meaningful errors when a GX replacement fails together with restricting the number of replacements to one.
2023-10-24
- All Pages: Fixed bug in search dropdown component that duplicated values aswell as in some dashboards.
- Installation settings: Better description for reset of Auth Tokens and timestamps information included.
2023-10-23
- Advanced: Added feature that allows non-admin users to edit widgets on advanced page non-persistently.
- Dashboard: Improved availability of the weather information.
- Dashboard: Fixed old forecasts showing after location change.
- Dashboard: Fixed dashboard details not showing when readings are 0 Watts
2023-10-19
- Dashboard: Fixed flicker of forecast and total bars when changing between time ranges.
2023-10-19
- GX replacement: Fixed issue causing error to show when the operation succeeded.
2023-10-18
- Push notifications: Changed the push notifications provider.
- Graphs: Set maximum zoom limit to one data point.
- Advanced: Fixed attributes in custom widgets to be displayed in the correct order.
2023-10-18
- Dashboard: Add consumption forecasting.
- Dashboard: Add padding between columns in the installation overview charts.
- Dashboard: Improve the visualisation of forecasted values and totals.
2023-10-17
- Device list: Add distinct icon for the EVCS NS.
- Admin: Temporarily removed control color versions from the navigation bar.
2023-10-16
- Dashboard: Add warnings about forecasted data accuracy.
2023-10-11
- Dashboard Controls: ESS control has a new battery-shaped slider with an improved design.
- Advanced: Fix temperature widgets not showing chart data sometimes.
- Internal: Make the banner showing info and alert messages appear and disappear without reloading the page.
2023-10-09
- Advanced: Fixed legend overflowing when 6 attributes are used for custom widgets.
- Device list: Update Victron Energy Meter icon.
2023-10-03
- Device list: Don't show “unknown” as a value if the VRM instance is 0.
- Advanced: Improved widget grid mechanics on both desktop and mobile devices.
- Advanced: Remove unnecessary widget scrollbar.
- Advanced: Add spacing between custom widget graph and the edge of the widget.
- Advanced: Better contrast in widget colors.
2023-10-02
- Advanced: Added 6th parameter for custom widgets.
- Device list: Add serial numbers for AC Loads and Grid meters.
- Device list: Add icon for the Victron Energy meter.
2023-09-27
- Controls: Bring back the Active SOC Limit info in the ESS controls.
- Installation settings: Invitation messages cannot contain URLs.
- General: Fix some translations not displaying correctly.
- Installation dashboard: Improve performance by synchronising updates.
2023-09-25
- Dashboard: Fix the issue causing an 'Access denied to this object' error to appear when selecting an installation as a user without full control.
2023-09-22
- iOS: Fix error causing status widgets to not load.
- iOS: Fix error causing 'Unavailable' time in the corner of the widgets despite reachable installation
- Android and iOS: When choosing an installation for a widget, the list loads faster. The widget itself also receives installation data faster.
2023-09-16
- Installation overview: Temporarily hide installation stats on mobile for users with many installations to improve loading times and responsiveness on iOS 17.
2023-09-16
- Advanced: Added “Last seen” and “Last successful authentication” columns in the API access tokens table
2023-09-15
- Device List: Add up to 12 serial numbers for VE Bus devices in serial number of VE Bus with hierarchy of devices (phase master, …).
2023-09-14
- Dashboard: Improve performance by adding an MQTT buffer that limits the number of attribute updates on the installation.
- Dashboard: Fix bug that caused pipes to not be connected on some installations.
- Installation data: Added toggle-able legend for the series of the System overview graph.
- Dashboard: Improve the UX/UI of the controls and add more loading states.
2023-09-12
- Advanced: Fix reduced data resolution when zooming in and the Solar irradiance widget is active.
2023-09-11
- Event log: Capture firmware update failures.
- Event log: Add a more detailed description when a GX device is replaced.
2023-09-07
- Dashboard: Improve the Show/Hide forecast button logic.
- Update detection: Improve the logic for detecting moving between pages.
2023-09-06
- Dashboard: Fix issue causing Multi RS PV charger device details not to update.
2023-09-04
- Dashboard: Added unit (kWh) to Total solar power + made variable more clear.
2023-09-01
- Banner: Fix the link for the data sent from unauthenticated device message.
2023-08-31
- API: Fix retrieving forecasted data from stats endpoint when show_instance=true
- Android and iOS: Generator data has been added to the chart visible in the large view of the status widget
2023-08-30
- Battery monitor, PV inverters, Chargers, Inverters, DC Sources, Alternators, Dc loads, DC systems that are reporting a serial number, now display it in the device list.
- Fix disconnecting from MQTT from an inactive VRM tab in Firefox and Chrome.
2023-08-29
- Android and iOS: Solar forecasts can now be seen in the chart visible in the large view of the status widget
2023-08-28
- Data uploads: Increased file size limit to 200MB and improved performance.
- Dashboard: Extend solar production forecast for up to 7 days in the future.
- Dashboard: Decrease threshold for showing the energy flow animation (from 30W to 10W).
- Dashboard Reports: Fixed issue with downloading report for Pacific/Pohnpei
2023-08-25
- Advanced: Made installation data chart size more consistent and readable.
2023-08-23
- Embed: Fixed issue with loading an embedded dashboard after using an installation sharing link.
2023-08-22
- Dashboard: Add back grid icon missing on some installations.
2023-08-17
- Tags: Added better validation for adding tags with similar names
- Dashboard details: Reduce the precision of voltages for solar chargers to one decimal.
2023-08-15
- Performance: Reduced the number of watchers and improved performance on multiple pages in the web app.
- Dashboard: Add device control widgets for Inverter RS and Multi RS
2023-08-14
- Dashboard: Replace the “Show forecast” tooltip with a more informative modal.
2023-08-11
- Dashboard: Add new system state: Dynamic ESS.
- Beta: Show the “What's new” modal more consistently to beta users when new features are rolled out.
2023-08-08
- Admin: Actions made under impersonation are now logged together with the impersonator's ID visible to administrators in event logs. Added measures to prevent admins from impersonating other admins and restricted admins from impersonating other admins or restricted admins.
2023-08-07
- Controls: Fix EVCS Charging toggle getting stuck when used in combination with Remote Console.
- Overview: Fixed errors being thrown in the console when no tags included in URL.
2023-08-01
- Charts: fix update mechanism in charts to make sure data remains rendered after polling update
2023-07-31
- Dashboard: Fix forecasts not showing for some sites when turning “Two-way communication” off
2023-07-28
- Dashboard: Improve detection logic for when to show the “Show forecast” disabled button.
- Installation data: Improve the UX/UI of the totals cards.
2023-07-26
- Dashboard: Improve the text explaining why the “Show forecast” button is disabled.
2023-07-25
- Admin attributes: Increase limit of data attributes to 2000
- Add installation: Fixed issue that prevented the Multiplus II GX setup from opening on desktop.
2023-07-24
- Installation data: Fixed an issue where the page would jump up when switching graphs.
2023-07-23
- Alarm Logs: Added kebab dropdown menu in alarm logs table, updated clear alarm logs modal
2023-07-22
- Advanced: Fixed widget axis not scaling correctly when changing outputs
2023-07-21
- Dashboard: Show a disabled “Show forecast” button and a tooltip guiding users to set their location.
- Forecasts: Add forecasting for RS devices (Inverter-RS and Multi-RS).
2023-07-20
- Tags: Fix tags not being loaded.
- Installation data: Prevent the “Battery now” dot from lagging behind in time.
- Add installation: Add Ekrano GX
- Device List & Advanced: Fix Cerbo GX using CCGX icon instead of Cerbo icon.
2023-07-19
- Dashboard: Fix the logic for showing the forecast when switching between time intervals and chart types.
- Installation data: Reduce the height of the “System overview” chart on mobile.
2023-07-18
- Dashboard: Persist showing the forecast when checking different time ranges and then coming back to Today's view.
- Dashboard: Prevent the “Show forecast” from being shown briefly when a site doesn't have a forecast.
2023-07-17
- Dashboard: Fixed the grid chart colors for the installation overview in dark mode so it is clear again when it is feeding or pulling from the grid
2023-07-14
- Event log: Fixed bug which caused the event logs to not load on some installations
2023-07-13
- Dashboard: Increase precision by showing one decimal point for kWh values in installation data.
- Dashboard: Always show power per phase for PV Inverters on output.
2023-07-12
- Custom widget: Fix series color being too dark in dark mode.
2023-07-11
- Dashboard: Show warning for rare case in which a Multi RS cannot be shown on the dashboard.
2023-07-10
- Advanced: Add widgets for DC-DC converter, Smart BatteryProtect and Smart Lithium.
- Advanced: Show correct error message when hitting the rate limit.
- Improve handling of upstream data fetching timeouts.
2023-07-07
- Advanced: Further improvements to the behaviour of widgets during modification.
- Dashboard: Fix colors of forecasted bars for dealer whitelables.
2023-07-06
- Advanced: Improvements to stability of widget grid during modification.
- Dashboard: Make the colors of the System overview chart consistent with the other tabs (Solar, Consumption, etc.
- Dashboard: Fix tooltip not showing for certain forecasted hours.
2023-07-05
- Dashboard: Add Solar Production (PV Yield) forecasting.
- Advanced: Add Solar Irradiance widget for Gateway.
- Custom widget: Fix graph tooltip not showing complete legend when creating a new widget.
- Custom widget: Fix Y-axis for some widgets being inconsistent
- Overview: Fix row loading visual bug.
- Overview: using a link with shared tags now gives a popup that some tags could not be used.
- Device list: Unknown serial numbers for e.g. Instant Readout devices is now shown correctly.
- Login: show meaningful error when being ratelimited based on 2FA token.
- Installation settings: added a reset button for sites that used an invalid MQTT password in the past.
2023-07-04
- Advanced Data Download: Fix number formatting.
2023-07-03
- Dashboard: The installation graph now shows the direction of flow more clearly
- Firmware update: Fixed an issue where you would get a “Scan already in progress” error while scanning for updatable devices.
- Advanced: Load correct widgets when search is not active and prevent side effects to layout by search.
- Shared page : It is now not possible to share an installation and then to forge the uri so that you can access unwanted pages (eg alarm-logs as shared user).
- All pages : Every 8 minutes there is a check to verify that a new version has not been deployed, after 5 minutes of inactivity the page will reload .
- Login: redirect to the login page instead of the VRM product page when visiting vrm.victronenergy.com
- Login: change cancel button on login form to “Read more about VRM”
- Dashboard: Decrease the zoom of location widget and location pin to show more of the current site location
- Overview: Remove shared installations from the list of installations
2023-06-29
- Advanced: Prevent error message from disappearing when a download is already in progress for an installation.
2023-06-27
- Dealers: Add whitelabel for Trystar.
- Data exports: Lock first rows and columns of spreadsheet.
- Advanced: Fix expanded widgets automatically shrinking after a short amount of time.
2023-06-26
- Advanced: Remove the Load widget button for state widgets. These widgets load automatically again.
- Android and iOS: The mobile widgets now show when the installation was last reached in the top right corner, rather than when the widget itself was last refreshed
2023-06-22
- Installation users: Make overflow of tables for the installation users more clear on mobile.
- Alarm logs:
- Display a nice message when alarm logs are empty instead of pop up modal.
- Add status of an installation on the page (also for the event logs)
2023-06-21
- Advanced: Data downloads performance improvements to allow for downloading larger files.
- Fix for map behaviour with location query string
- Hover for historical data in dark mode is fixed for all historical graphs except grid
- Devices:
- Added data logging support and icons for Orion-Tr Smart DC-DC charger, Smart BatteryProtect and Lithium Battery Smart.
- Added new icons for Inverter RS Smart, Lynx Smart BMS and Blue Smart IP65 Charger.
- Caching of graphs on installation overview to improve performance.
- Controls: Change order of ESS states to be the same across all platforms
2023-06-20
- Firmware update: Do not prompt users to retry firmware update when encountering a 733 error.
- Production report: Improve accuracy of generator runtime for installations with Venus OS v3.00 or higher.
- Advanced widget grid editing and viewing:
- Identical order of widgets on mobile and desktop
- Warning message when grid is full
- Consistent handling of grids with many widgets
2023-06-19
- Login: Add password viewer
- Economic report & Hybrid report: Show explicit errors when saving a template with invalid arguments
- Maps: Allow for scroll-in with trackpad
- Maps: Set view restrictions on all maps so it looks more like google maps
- Event logs: Improved performances of large event logs (loading time is reduced)
2023-06-15
- My installations: Fixed an issue where the modal window would not close after downloading a production report
2023-06-13
- Device list: Change how MultiRS is detected to improve detection in multi-phase systems using MultiRS
2023-06-12
- Historical data: Fix rounding for the “This year” interval to prevent one extra column on the left.
2023-06-08
- Advanced: Retrieve the state changes one by one instead the of all at once. Fixes the data often not showing up as well as and fixes the related red error message.
2023-06-07
- Restore the update interval of installation to 1 minute. Was previously set to 5 minutes to cope with DB overload.
2023-06-05
- Dashboard: Summary block icon colours are now the same as the legend colours.
2023-06-02
- Fixed being logged out and having to re-login in frequently.
- Dashboard: Removed unnecessary requests for data.
2023-06-01
- VE.Configure & Device Firmware: Fixed an issue where leaving the tab caused the download/upload to stop.
2023-05-31
- Installation overview: Remove DC voltage from table adjustments
2023-05-25
- Fixed bug which caused the “Old data” message to sometimes display on summary widgets even when data was up-to-date
2023-05-24
- Whitelabels: Support for dealers' custom styles
- Android:
- You can open installation in the app by tapping the widget
- Improved the speed of the EVCS actions
2023-05-17
- Various improvements for users that manage fleets of systems:
- ‘Add installation’ button is moved to top of installation overview
- Fleet managers can keep, bookmark and share the position where they were in the map view
- Search bar is better visible in the installation overview
- Installation totals are shown on top of the installation overview
- Active tags can be bookmarked and shared through URL with other user(s)
- You can see how many installations have alarms
- You can reset the zoom in the installation overview map
- The map view now acts as a filter for the installation table when it is open and a user zooms in
- Smaller adjustments e.g. tags are sorted alphabetically, more tags will alter UI to make them better read-able, alarm tags are color-coded, groups, alarms, tags can be filtered on
2023-05-15
- Advanced: Added extra widgets for the Inverter RS Smart Solar.
2023-05-12
- Performance improvement: When navigating away from a web browser tab that has VRM, for more than 10 seconds, the connection for real time data is closed. When users comes back to the tab the connection is immediately re-established.
2023-05-11
- Dashboard: Improve the performance (reduce CPU & memory use) of rendering the real time data updates to the “Detailed” fold-outs on the Dashboard.
- Custom widgets: Fix the legend and series colors being duplicated for the same device type.
- Production report: fix broken generator run hours
2023-05-10
- Improve data reloading when returning to an inactive VRM tab in Firefox and Chrome.
2023-05-09
- Date picker: Remove date rounding when custom ranges are selected.
- Dashboard: Fix showing the correct Local time after coming back to an inactive VRM tab.
- Fix showing the Local time in the correct timezone in all browsers.
2023-05-04
- Internal: Major upgrade of the API framework.
2023-05-03
- Display preferences: fix alignment of the buttons on this page on specific screensizes.
2023-04-28
- General: Update translations
- Login: Add better type validation to login API request
- Installation users: Fix tooltip text explaining that the latest admin can not be removed
2023-04-26
- Add Installation: Remove SHS (PAYGo) device
2023-04-23
- Advanced: Show correct last seen timestamp.
- Advanced: Fix a bug that caused widget icons to overlap on touchscreen devices.
- Advanced: Improve validation on custom widget creation
2023-04-18
- Dashboard: Add generator runtime in generator historical graph
2023-04-13
- Remote console: Fix bug remote console broken height on mobile.
2023-04-04
- Dashboard: Improve readability for dashboard tiles and add font smoothing.
2023-03-30
- Controls: Do not display controls that are not present anymore.
- Dashboard: Make the realtime indicator more reliable.
2023-03-29
- E-Mails: Add the email of the requesting user.
2023-03-28
- Android: Fix charge toggle is not visible when enabled on the EVCS widget
2023-03-23
- Advanced graphs: Fix range values were incorrectly calculated and displayed.
2023-03-16
- Alerts: Make the 'connection offline' notification dismissible for 5 minutes.
2023-03-13
- Production report: Operational run hours now shows how long inverters were powering the AC loads, and generator run hours shows the amount of time the generator was running.
2023-03-10
- Dashboard: Do not interpolate missing data for PV Inverter, AC Loads and Critical Loads.
2023-03-08
- Dashboard: Fix EVCS component covers status label
2023-03-03
- Custom widgets: increased the yAxis allowed range from 5000 to 500000
2023-03-02
- Historical data: Now also shows data about grid, shore and generator usage.
- Controls: Fix scrolling inside the drawer.
2023-02-28
- Custom widgets: Creating and editing custom widgets is now done on a separate page.
2023-02-24
- Settings: The user is now warned before removing his own full control over an installation.
- Settings: It is not possible to remove the last user with full control over an installation.
2023-02-22
- Login: Changing the language before login saves this as preferred language for the account.
- Alerts: Reduce the bottom spacing of alerts on mobile.
- Dashboard: Connect the EVCS tile to Critical loads.
- Advanced: Fix default y-axis max value race condition.
2023-02-21
- Modals: Fixed issue causing some modals to appear outside of the viewport.
- Dashboard: Prevent the page from scrolling when the controls are open.
- Installation users: Remove personal message required indication on invite.
2023-02-20
- Advanced: Fix tooltip sometimes not showing in all charts when hovering.
- Advanced: Only copy active widgets when duplicating a widget layout.
- Advanced: Fix bug causing original custom widget to be modified when editing a copy on a different installation.
- Advanced: Fix location and size of custom widgets without data not being saved correctly.
- Advanced: Added units to the dropdown of custom widget parameters.
2023-02-13
- Event logs: Event logs are now shown in installation timezone, rather than browser timezone.
- Internal: Add debouncing to state graph data fetching.
- Internal: Improve state graph data fetching performance.
2023-02-08
- Advanced: Change .xls data exports to .xlsx
- Internal: Improvements and optimisations in querying timeseries data.
2023-02-07
- Dashboard controls: Allow users to set the EVCS to “Scheduled charging” mode. (requires Venus OS version to be at least v2.93~2)
2023-01-31
- Custom widgets: Allow users to use decimal values for the lower and upper bounds of the scale.
2023-01-30
- Admin: Add pagination the search results on data attribute filtering.
2023-01-27
- Dashboard: Historical data graph now shows the right date and hour when in monthly interval. It also detects quick ranges when going forward with the arrow buttons after going backwards from a quick range.
- Reporting: Fix the style of the floating date picker.
- Advanced: Resolve duplicate attributes for custom widgets.
- What's new: What's new section blue badge does not appear again when deleting local or session storage.
2023-01-17
- Controls: Improved loading state showing more details about connection issues for inverter controls.
- Dashboard: Fix bug where date picker arrow buttons would become unclickable on mobile devices.
- Advanced: Fix the search function for advanced widgets and stop widget rearrangement.
2023-01-11
- Advanced: Stop the keyboard from hiding dropdown selection menus in custom widget creation or editing on mobile devices.
2023-01-03
- Event log: Fix bug causing incorrect state names to be used when switching ESS state.
- Firmware updates: Added support to detect custom firmware version mismatches for VE.Bus devices.
2023-01-01
- Styling: Fix bugs causing the colors in vrm to be wrong for some providers, which would cause graph colors to be different than their labels, and accent colors to not match in different parts of the website.
2022-12-30
- Android: Fix bug where status widget wouldn't show graph or would show it incredibly small after resizing
2022-12-29
- Historical data: Fix wrong date range shown in graph when “previous month” was selected
- Historical data: Fix additional day being shown when selected time range contained a daylight savings time change.
2022-12-21
- Venus OS Large: Show Node-RED link when it is in safe mode.
2022-12-19
- Firmware updates: Allow updating GX devices from VRM.
- Push notifications: Fix duplicated devices in the Other devices list.
2022-12-16
- Advanced: Removed bug causing a second tooltip showing “title” text to show up when hovering a chart in the Custom widget creating or editing modal
2022-12-12
- Installations: Fix map moving when hovering over one of the installations.
- Advanced: Set Y-axis for Humidity between 0 and 100.
2022-12-02
- The blue dot indicating there are new elements in the “What's new” in-app changelog now disappears after the changelog is opened rather than after every element has been viewed.
- Advanced: Modal for editing and creating custom widget will now be shown regardless of screen resolution
2022-12-01
- Add installation: Add Cerbo-S GX
- Installations: Apply filtering by tags to the map view of installations.
2022-11-28
- Controls: Improve Inverter controls by adding a loading state.
2022-11-24
- Advanced: Add GlobalLink summary and graph widget.
- Dashboard: Improve the alignment of the Controls icon.
2022-11-22
- Push notifications: Improve the design and text of the Preferences > Notifications screen.
- Push notifications: Fix edge case causing duplicated devices in the “Other devices” list.
2022-11-21
- Release Mobile and Web Push notifications.
- Firmware updates: Add support for VE.Bus BMS firmware files and update instructions.
2022-11-18
- Historical data: Fix page scrolling to the top when switching between Consumption and Solar.
2022-11-16
- Custom widgets: Show the custom device name in the legend of the widget.
- Historical data: Distinguish between Grid, Shore and generic AC input in the To/From tiles.
2022-11-10
- Custom widgets: Allow customising the Y-axis minimum, maximum and interval count.
- Historical data: Fix bug causing the data not be rendered correctly in the chart.
2022-11-07
- Add Polish language and translations.
2022-10-25
- Internal: Replace _old_ with _deleted_by_user_ for deleted installations.
- Internal: Add idUser to MQTT URL to help debugging.
2022-10-21
- Firmware Update: Fix incomplete serial numbers being logged.
2022-10-18
- Dashboard - Historical data: Add a new Generator tile and show in the chart generator data if it is available.
2022-10-17
- Installation: Fix filtering of installations after deselecting all the tags.
- Reporting: Fix the text color inside the report types cards for dark mode.
2022-10-13
- Event logs: Add new event types: accessing the Remote console and changes made using the controls from the dashboard (input limit, inverter/charger mode, EVCS mode, etc.)
- Event logs: Add actions performed by Victron admins.
- Event logs: Firmware update versions.
- Registration: Add link to the privacy policy document.
2022-10-10
- Preferences: Update the design of the language selection page.
2022-10-07
- Profile: Move Volume unit setting from Profile to Display preferences.
- Internal: Change MQTT headers.
2022-10-05
- Controls: Fix issue which caused the controls to be unavailable for certain relay configurations.
2022-10-04
- Add the Event logs screen to track and monitor important changes made to an installation.
2022-09-27
- Advanced: Add Alternator Speed and Drive widget.
2022-09-21
- Advanced: Add a button to view widgets in fullscreen.
- Dashboard: Improve temperature cards layout and alignment.
- Dashboard: Display Input Current Limit for MultiRS.
- Support new tank types: Gasoline, Diesel, LPG, LNG, Hydraulic oil, Raw water.
2022-09-20
- Location and Geofence: Improve Reset button styling.
2022-09-19
- Controls: Improve the time counters of the generator controls.
2022-09-16
- Remove HotJar analytics.
2022-09-13
- Improve the styling of the What's new modal and allow links.
2022-09-12
- Update links to documentation for adding installations and Node-Red.
2022-09-06
- Dashboard: Position the EVCS tile on input or output.
- Remote console: Fix error screen showing while the remote connection is being established.
- Custom widgets: Show custom widgets even when there is no data for the selected series and time period.
- Require 2FA when resetting the password.
- Internal: Move from Mandrill SDK to Mailchimp SDK for sending emails.
- Internal: Move from Twillio Authy for Twillio Verify for sending 2FA codes.
2022-09-05
- Add the Display preference menu.
- First day of the week used to be only Sunday. Now for all users, existing and new, the first day of the week is set automatically. Users can override the preferred first day of the week in the Display preferences menu.
2022-08-29
- Fix duplication of certain PV inverters in the Device list.
2022-08-23
- Make global announcements bar dismissible.
2022-08-22
- Dashboard: Correctly show PV inverters not wired through phase one.
- Dashboard: Add spark graph for certain PV inverters that did not have one yet.
2022-08-19
- Advanced: Fix solar charger summary widget when there is no data.
- Production report: Fix errors caused by invalid time periods selected. Improve error messages in case of failure or timeouts.
2022-08-17
- Patch the caching and version checking mechanism to work on older Safari browsers.
2022-08-16
- Improve the caching and version checking mechanism.
2022-08-13
- Custom widgets: Prevent y-axis labels from being truncated
- Add cross button to make alarm banners not be fixed at the top of the screen to prevent overlap.
2022-08-04
- Advanced: Fix Hours of AC in for VE.Bus summary widgets with different instance numbers.
- Installation overview: Hide the PAYGo column when no installations are PAYGo.
2022-08-01
- Add 2FA reset flow.
- Improve password policy requirements.
- Require password to update the email address.
- Prevent reusing TOTP tokens.
- Do not allow links in invitations.
2022-07-25
- Add the Ukrainian language and translations.
2022-07-22
- Installation overview: Add sorting installations by voltage and SoC.
- Dealers: Add whitelabels for SO Energy and Puredrive.
2022-07-12
- PAYGo: Add functionality for managing PAYGo installations and tokens in VRM.
2022-07-11
- Dashboard: Improve detailed values displaying on mobile.
- Alarm log: Improve columns width on mobile.
2022-07-08
- Alarm log: Add links to documentation for known alarm codes.
2022-07-01
- Dashboard: Add expandable ESS states to the Battery tile.
- Dashboard: Add MPPT details for Multi RS and Inverter RS.
2022-06-29
- ESS Controls: Design improvements.
2022-06-28
- Device List: Show L2 and L3 PV Inverter devices.
2022-06-21
- Advanced: Fix voltage unit for energy meters in graph legends.
- Advanced: Fix synchronised zooming for the Solar Charger Current widget.
2022-06-20
- Dashboard controls: Add control for EV Charging Station.
- Dashboard controls: Add generator control (requires Venus v2.90).
- Dashboard controls: Allow user to enable Inverter/Charger control from general settings.
- Dashboard controls: Display loading state of the controls.
- Advanced: Switch around Humidity and Pressure series to ensure color consistency.
2022-06-15
- Advanced: Fix calculated Solar Charger PV Current not being displayed sometimes.
- Advanced: Fix graphs showing “No data available” instead of rendering the actual data.
- Translations: Fix reloading english translations upon failure.
2022-06-13
- Dashboard: Improve battery temperature readings. Now the temperature is displayed for more system types that use different methods of reading temperatures.
2022-06-09
- Advanced: Add the ability to edit custom widgets.
- Advanced: Show device names in the custom widget legend.
2022-05-24
- Alarm log: Fix selecting the time range of an alarm when navigating to the Advanced page.
2022-05-23
- Activate Hotjar for web and mobile.
2022-05-17
- Controls: Change ESS translations and order.
2022-05-16
- Advanced: Add icon to custom widgets.
- Dashboard: Improve input limit tile styling.
2022-05-12
- Installation overview: Add a Total row to sum up the power from all installations in the overview.
2022-05-11
- Firmware Update: Change the firmware file format for EV Charging Station from .bin to .evcsup.
- Dashboard: Improve the update frequency of the values from the EV Charging Station tile.
- Improve overall buttons styling and consistency.
2022-05-09
- Advanced: Fix AC Meter showing the MPPT icon.
2022-05-04
- Advanced: Fix “Reset zoom” button not being visible for certain widgets.
- Dashboard: Fix EVCS status for multiple stations combined in one tile.
2022-05-03
- Dashboard: Hide the solar charger status “lollipop” when there is more than one solar charger.
- Prevent keyboard from showing on Android when interacting with dropdowns.
2022-04-29
- Dashboard: Change the design of the controls button.
2022-04-28
- Device list: Add icons for Alternator, DC Source and DC Load.
2022-04-25
- Device list: Allow to separately click on the remote LAN IP addresses.
- Advanced: Improve the grid of the temperature, humidity and pressure chart.
- Advanced: Switch around min and max cell voltage in the tooltip.
- Various styling improvements
2022-04-20
- Dashboard: Improve showing battery temperature for installation with multiple temperature sources.
- Advanced: Fix tag positioning in Firefox.
- Custom widgets: Improve creation modal size and position.
2022-04-19
- Device list: Fix delete device button when a device is expanded.
- Add installation: Add instructions and logic for GX devices requiring the WiFi MAC.
2022-04-15
- Advanced: The tooltip labels for state graphs on the advanced page stay within the graph.
- Dashboard: Make battery states translatable.
- Dashboard: Replace EVCS Max Charge Current with Total Energy.
- Redirect from the VRM landing page to the VRM product page.
2022-04-13
- Move the language settings under the new preferences menu.
2022-04-12
- Dark mode improvements: Safari notch color, modal headers, scroll bars.
- Improve loading translations for slow connections.
- Update translations for all languages
2022-04-10
2022-04-07
2022-04-01
2022-03-31
- Update translations.
2022-03-30
2022-03-23
2022-03-16
2022-03-15
2022-03-14
2022-03-11
2022-03-09
- Add dark mode.
- Add “Preferences” menu.
2022-03-09
2022-03-03
2022-02-25
2022-02-22
2022-02-21
2022-02-18
2022-02-08
2022-02-01
2022-01-31
2022-01-20
2022-01-18
2022-01-17
2022-01-12
2022-01-08
2022-01-07
2021-12-31
2021-12-29
2021-12-24
2021-12-23
2021-12-14
2021-12-13
2021-12-10
2021-12-08
2021-12-07
2021-12-01
2021-11-30
2021-11-29
2021-11-26
2021-11-25
2021-11-24
2021-11-23
2021-11-18
2021-11-16
2021-11-11
2021-11-08
2021-11-05
2021-11-04
2021-11-03
2021-10-19
2021-10-18
2021-10-11
2021-10-07
2021-10-04
2021-09-28
2021-09-27
2021-09-22
2021-09-21
2021-09-20
2021-09-15
2021-09-13
2021-09-08
2021-09-06
2021-08-23
2021-08-19
2021-08-17
2021-08-16
2021-07-05
- Updated translations
2021-06-30
- Improved security
2021-06-21
- Add dutch language option
2021-06-09
2021-05-20
2021–05-17
2021-05-14
2021-05-10
2021-05-03
- Update dutch translations
2021-04-19
2021-04-10
2021-04-09
2021-03-29
2021-03-21
2021-03-18
2021-03-12
2021-03-11
2021-03-08
- Update german translations
2021-03-06
2021-03-04
2021-03-03
2021-03-02
2021-03-01
2021-02-28
2021-02-26
2021-02-16
2021-02-15
2021-02-11
2021-02-10
2021-02-08
2021-02-05
2021-01-25
2021-01-18
2021-01-14
2021-01-13
2021-01-05
2021-01-02
2020-12-24
2020-12-10
2020-12-07
2020-12-04
2020-12-03
2020-11-30
2020-10-11
2020-10-02
2020-10-01
2020-09-29
2020-09-28
2020-09-25
2020-09-22
2020-09-21
2020-09-02
2020-08-21
- Add pulse meter support
2020-08-17
2020-07-29
2020-07-28
2020-07-27
2020-07-14
2020-07-13
2020-07-09
2020-07-07
2020-07-01
- Change PV inverter icon
2020-06-11
- Add fuel cell widgets
2020-05-12
2020-05-05
2020-04-27
2020-04-08
2020-03-18
2020-03-05
2020-03-02
2020-02-13
2020-01-31
2020-01-29
2020-01-17
2020-01-15
2020-01-13
2020-01-07
2019-12-20
2019-12-13
2019-12-12
2019-12-11
- Add altitude to GPS widgets
2019-12-10
2019-11-28
2019-11-21
2019-11-19
2019-11-14
2019-11-11
2019-11-06
2019-10-30
2019-10-25
2019-10-23
2019-09-18
2019-09-16
2019-09-02
2019-08-30
2019-08-27
2019-08-16
2019-08-14
2019-08-13
2019-08-09
2019-08-05
2019-08-02
2019-07-29
2019-07-08
- Added widgets for DC meter
2019-07-03
2019-07-02
2019-07-01
2019-06-27
2019-06-18
2019-06-17
2019-06-14
2019-06-12
2019-06-11
2019-06-06
2019-06-05
2019-06-04
2019-06-03
2019-05-22
2019-05-20
2019-05-17
2019-05-16
2019-05-14
2019-05-02
2019-05-01
2019-04-30
2019-04-25
2019-04-19
2019-04-15
2019-04-12
2019-03-29
2019-03-28
2019-03-21
2019-02-15
2019-01-29
2019-01-26
2019-01-21
2018-12-12
2018-12-10
2018-11-22
2018-10-26
- Renamed username to e-mail
2018-10-19
2018-10-17
2018-10-16
2018-09-28
2018-09-27
2018-09-11
2018-09-06
2018-09-05
- Added tank level widget
2018-09-04
2018-08-29
2018-08-24
2018-08-14
2018-08-03
2018-07-27
2018-07-16
2018-05-23
2018-05-22
2018-05-16
2018-04-19
2018-02-27
2018-02-13
2017-12-18
2017-11-13
2017-10-19
2017-10-04
2017-10-03
2017-09-15
2017-09-12
2017-09-07
2017-08-03
2017-08-02
2017-07-25
2017-07-20
2017-07-12
2017-06-28
2017-06-27
2017-06-19
2017-06-13
2017-06-07
2017-05-31
2017-05-16
2017-04-21
2017-04-13
2017-04-06
2017-03-31
2017-03-29
2017-03-28
2017-02-27
2017-02-15
2017-02-01
2017-01-25
2017-01-24
2017-01-23
2017-01-19
2017-01-18
2017-01-13
2017-01-12
2017-01-11
2017-01-10
2017-01-09
2017-01-06
2017-01-04
2017-01-03
2017-12-23
2016-12-22
2016-12-20
2016 Nov. - New VRM API
2016-09-09
2016-06-07
2016-06-06
2016-06-03
2016-05-11
2016-04-12
2016-03-31
2016-03-11
2016-03-07
2016-02-01
2016-01-15
2015-12-08
2015-12-04
2015-12-02
2015-11-30
2015-11-17
2015-10-30
2015-10-26
2015-10-23
2015-10-20
2015-10-19
2015-10-12
2015-09-22
2015-09-11
2015-09-08
2015-09-03
vrm_portal/change_log.1726652828.txt.gz · Last modified: 2024-09-18 11:47 by aleximb
