vrm_portal:remote-firmware-update [2019-08-15 12:22] – [2.1 Requirements] guy_stewart | vrm_portal:remote-firmware-update [2024-11-13 13:12] (current) – [2.1 Requirements] guy_stewart | ||
- | This manual describes how to remotely update firmware. This functionality requires the device to be updated connected to a [[venus-os: | + | This manual describes how to remotely update firmware. This functionality requires the device to be updated connected to a [[venus-os: |
Features: | Features: | ||
Line 10: | Line 10: | ||
- Works from laptop, tablet & phone | - Works from laptop, tablet & phone | ||
- No need to find the right firmware file: the system has all, and will clearly indicate that a newer version is available. | - No need to find the right firmware file: the system has all, and will clearly indicate that a newer version is available. | ||
- | - Works with VE.Direct | + | - For supported |
- | - Works with VE.Can products: MPPT VE.Can Solar Chargers, Skylla-i, and more. | + | |
+ | Demonstration video: | ||
{{youtube> | {{youtube> | ||
Line 20: | Line 18: | ||
==== 2.1 Requirements ==== | ==== 2.1 Requirements ==== | ||
- | * Venus OS v2.17 or later | + | * GX device must be running |
* System must be connected to the internet and communicating to the [[https:// | * System must be connected to the internet and communicating to the [[https:// | ||
- | * The '' | + | * The '' |
==== 2.2 Compatible products ==== | ==== 2.2 Compatible products ==== | ||
Line 28: | Line 26: | ||
Products connected via VE.Direct communication port: | Products connected via VE.Direct communication port: | ||
- | * MPPT Solar Charge Controllers (1) | + | * MPPT Solar Charge Controllers, including MPPT RS (See note 1 below) |
* BMV Battery Monitors | * BMV Battery Monitors | ||
- | * Phoenix Inverters | + | * SmartShunts |
+ | * Inverter VE.Direct | ||
+ | * Smart IP43 Charger | ||
Products connected via VE.Can communication port: | Products connected via VE.Can communication port: | ||
* MPPT Solar Charge Controllers | * MPPT Solar Charge Controllers | ||
* Skylla-i battery chargers | * Skylla-i battery chargers | ||
+ | * Lynx Smart BMS | ||
+ | Victron Energy Multis, Quattros, other VE.Bus-connected Inverter/ | ||
==== 2.3 How does it work? ==== | ==== 2.3 How does it work? ==== | ||
Line 67: | Line 69: | ||
Updating firmware on a BMV that is connected via a [[https:// | Updating firmware on a BMV that is connected via a [[https:// | ||
- | === VE.Bus Products (Multis, Quattros, high power Inverters) | + | === Lynx Ion BMS Series |
- | Remotely updating firmware in VE.Bus products | + | (note that this does not apply to the Lynx Smart BMS) |
- | === Lynx BMS Series === | + | |
Remotely updating firmware of these Lynx series of products is not possible: | Remotely updating firmware of these Lynx series of products is not possible: | ||
Line 77: | Line 77: | ||
Remote updating the Lynx Ion BMS 150A, 400A, 600A and 1000A model is possible. Notes: | Remote updating the Lynx Ion BMS 150A, 400A, 600A and 1000A model is possible. Notes: | ||
- | * The firmware library does not have the files. Download the file from [[https:// | + | * The firmware library does not always |
* Make sure that the [[venus-os: | * Make sure that the [[venus-os: | ||
- | * In case the update fails, it can be retried; just like all other products. But in case of the Lynx BMS, this has to be done within 5 minutes. Otherwise it will will go to sleep mode and a push on the start button is required. | + | * In case the update fails, it can be retried; just like all other products. But in case of the Lynx BMS, this has to be done within 5 minutes. Otherwise it will go to sleep mode and a push on the start button is required. |
Line 90: | Line 90: | ||
=== Step 2. Update process === | === Step 2. Update process === |
vrm_portal/remote-firmware-update.1565864530.txt.gz · Last modified: 2019-08-15 12:22 by guy_stewart
