vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2021-12-08 10:39] – [3. Step by step procedure] mvader | vrm_portal:remote-veconfigure [2024-11-13 13:16] (current) – guy_stewart | ||
Line 12: | Line 12: | ||
- A GX Device running Venus OS v2.17 or later (latest official version is preferred) | - A GX Device running Venus OS v2.17 or later (latest official version is preferred) | ||
- | - Two way communication | + | - The '' |
- The [[venus-os: | - The [[venus-os: | ||
- [[https:// | - [[https:// | ||
Line 23: | Line 23: | ||
* To Remote VEConfigure a system connected to the GX device via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. If necessary, first update that interface cable with the [[vrm_portal: | * To Remote VEConfigure a system connected to the GX device via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. If necessary, first update that interface cable with the [[vrm_portal: | ||
+ | * The system protects against accidentally sending settings from one system to another. To that purpose, it will compare the serial numbers of the installed inverter/ | ||
+ | * For systems consisting of multiple inverter/ | ||
In some cases the VE.Bus system will momentarily switched off when changing the configuration. | In some cases the VE.Bus system will momentarily switched off when changing the configuration. | ||
Line 32: | Line 34: | ||
- Check the requirements | - Check the requirements | ||
- Venus OS v2.17 or later | - Venus OS v2.17 or later | ||
- | - Two way communication enabled (see Settings -> VRM Online Portal | + | - The '' |
- | - Two way communication | + | - '' |
- On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
- Click the button and wait | - Click the button and wait |
vrm_portal/remote-veconfigure.1638956362.txt.gz · Last modified: by mvader
