vrm_portal:remote-veconfigure
VRM: Remote VEConfigure (DRAFT!)
1. Introduction
This manual describes how to remotely change settings in VE.Bus Inverters, Multis and Quattros. A feature called Remote VEConfigure.
This functionality requires the device to be updated connected to a Venus device (CCGX, Venus GX, or other).
This (new) way of Remote VEConfigure replaces the previous mechanism, that used VE.Power Setup. See here for the manual of the old procedure. Note that, once updated to the new Venus version, it is no longer possible to use the old procedure.
Requirements:
- Venus OS v2.12 or later
- System must connected to internet and communicating to the VRM Portal.
Details:
- Remote VEConfigure works for both single unit systems as parallel and three phase systems.
- Remotely changing Assistant configuration is possible.
- VE.Bus firmware versions 416 and 417 can not be configured remotely
- Remote configuring firmware version 418 or later requires the CCGX or Venus GX to run v2.10 or later
- To Remote VEConfigure a system connected to the CCGX via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. Note that it is possible to first update firmware in the interface cable, and then remotely configure the VE.Bus system.
2. Procedure
Step 1. Go to Remote VEConfigure on the VRM Portal
add screenshot once last changes have been done.
Step 2. Download the file to your computer
Step 3. Modify the configuration
Step 4. Upload the configuration to the system
3. Trouble shooting
4. Disqus
vrm_portal/remote-veconfigure.1511533990.txt.gz · Last modified: 2017-11-24 15:33 by mvader
