vrm_portal:troubleshooting_ccgx_vrm_connectivity [2019-05-26 23:00] – [Further debugging VRM communication (advanced)] mvader | vrm_portal:troubleshooting_ccgx_vrm_connectivity [2020-07-21 09:52] (current) – mvader | ||
- | ====== Trouble shooting Remote Console on VRM ====== | + | Moved here: https:// |
- | Looking for how to trouble shoot transmission of data logs to VRM? See chapter 5 in the [[ccgx:start|GX Product manual]]. | + | |
- | Not using a CCGX but a Victron Global Remote or Victron Ethernet Remote? See [[https:// | + | |
- | After enabling the feature in the CCGX setting menu, setting or disabling the password, and then restarting the CCGX, a new Menu Option will show on the VRM website. Click it to open the Remote Console. | + | |
- | - Then restart the CCGX. | + | |
- | - Make sure to update the CCGX to the latest firmware version: v2.11 or newer. | + | |
- | ==== IP Address verification ==== | + | |
- | Remote Console on VRM checks the IP Address for security reasons. | + | |
- | In case all above does not help, it might be that your internet connection very frequently changes its IP-address. And/or that the internet provider routes the different data stream over different of its routers. | + | |
- | Both of which will make the IP verification fail and therefor makes Remote Console fail. To solve this problem, contact your internet provider and/or change to a different internet provider. | + | |
- | Note that it is not necessary for the CCGX to be addressable itself, and/or have a public IP address. Worded differently: | + | |
vrm_portal/troubleshooting_ccgx_vrm_connectivity.1558904426.txt.gz · Last modified: 2019-05-26 23:00 by mvader
