Eco farming
Grow a sustainable farming business with a power system that grows with it.
Independent energy systems enable a whole new generation of farming. Through providing sustainable power at scale new business opportunities come into reach, even at remote locations where there is no grid present at all. Farming models can now be diversified to even more power dependent applications, such as fish- or poultry farms, vegetable production or even entire food factories. The positive social and economic advantages are substantial and far-reaching.
By replacing generators with solar energy as the primary source of power, power security is increased, maintenance reduced significantly, overall energy costs lowered and way more sustainable, with significant CO2 emission reductions as a result. With Victron Energy the off-grid capabilities are unmatched. Our modular setup means our solutions can scale to stay on par with the rising power demands. Our authorised installers will gladly help you with creating a power roadmap that works for your situation.
Green power
powered by Blue Power
In this example we’re looking at a new greenhouse complex as an extension of an already large off-grid eco-farm. Compared to open field growing, protected cultivation will save a lot of water and the production quantity and quality can be increased. This dedicated power solution provides water treatment and pumping, together with a heat regulation system and artificial lighting. The power demand rises at night, where temperatures drop and the lights need to be powered. Let’s see how this greenhouse can be solar powered 24/7.
Night time energy consumption
30kVA
Day-time energy consumption
80kVA
Peak power requirement
28kVA
In this example
The daily energy consumption is calculated by adding up the sum of all day time consumers and night time consumers. Add all the Watts of the simultaneously used consumers to calculate the required peak power. See other essential considerations below.
Obvious choices
System Design
Considerations
A walk-through of Design Considerations for an off-grid system for an Eco farm.
  • 01
    Why is the Quattro a good inverter for this Off-grid system?
    Our extremely resilient Quattro inverter/chargers have powered the most demanding off-grid challenges for many years, in the harshest of environments. It combines an inverter and charger in one enclosure and has 2 AC inputs. The Pure Sine Wave inverter technology safely powers sensitive electronics such as computers and any load problem free. Thanks to it’s powerful adaptive charger, a Lithium bank can be quickly charged by the ‘grid’. Virtually unlimited power can be offered through parallel operation, three or split phase operation are also possible, meaning over time, your system can grow with your ambitions.
    Inverters convert DC power into AC power. Inverters should be sized to handle the average AC load continuously and should match the expected peak power current of the simultaneous AC loads. See all our inverters/chargers
    The professionals' choice
    3x Quattro 48/15000/200-100/100: Based on a 48V battery bank, three 15kVA Quattro’s are installed in Three-phase and can continuously provide 45kVA with a peak power up to 75.000W, more than enough to power all industrial appliances. The three Quattro's join their charging capacity to a max of 600 Amps. A third party AC-PV solar inverter is added to their AC output. On cloudy days the batteries supplement the power output from the AC-PV through the Quattro. At night, the batteries will take over full supply, powering all loads. This seamless integration based on frequency shifting is enabled by a software assistant on the Quattro, which can be installed in minutes and works with several Third party PV-inverters.
    All our inverters are renowned for their extreme resilience in the toughest of circumstances. For installations installed in high-temperature environments, please consider the temperature derating factor when sizing your system, see the datasheets for more info.
  • 02
    Lithium or lead-acid battery bank for this Off-grid system, in what size?
    There are many reasons why to choose for either technology. But let’s have a quick glance at the cost-effectiveness and the practical differences.
    Cost-effectiveness of Lithium batteries vs lead-acid batteries
    When choosing an off-grid battery bank there is primarily the choice in technology: lithium or lead-acid. For off-grid applications, Lithium has quickly become the new standard in larger (residential and commercial) systems because of performance reasons, but also due to their lower cost-per-cycle. For smaller systems the lower cost-per-cycle situation is also true, however the higher upfront investment led many to consider Lead-acid batteries. Due to a continuous downwards price pressure, the tipping point towards Lithium for small off-grid systems is closer than ever and in some regions already there.
    Practical differences of Lithium batteries vs lead-acid batteries
    Using Lithium in off-grid systems
    Using Lead-acid in off-grid systems
    Lithium is the new standard in larger off-grid systems, because of its reliability, performance in high temperatures, optimal scalability, fast (dis)charging abilities (ideal for solar powered applications) and from an investment perspective: a long cycle life which translates into a lower cost-per-cycle compared to lead-acid. Also, it is relatively ‘maintenance free’, which is often seen as a favourable factor in designing reliable solutions, especially for remote installations. Practically they are way lighter and more compact, ideal for cases with space- or weight restrictions.
    Lead-acid battery types also are a viable option; off-grid installations have relied on them for years and many still do. While they offer a lower initial investment, they do require more discipline by it’s end-users, ensuring the system is closely monitored, isn’t discharged too deeply, fully charged regularly, internal battery liquids filled. When this is taken care of, lead-acid based systems do provide a safe and reliable option. Looking at the total life cycle of a system, lead-acid batteries often have a higher cost-per-cycle and these days, in some regions, even a higher upfront investment.
    Victron Energy offers full flexibility when it comes to selecting an off-grid battery bank of choice. Next to our own range of quality batteries, the choice includes a number of well supported third party Lithium battery manufacturers that can be easily integrated through the use of a GX-device. This flexibility enables our customers to perfectly match their off-grid needs for their unique power situation.
    Check the manufacturer's data sheets for the expected cycle life and see what works in your (business) case. Each manufacturer comes from a different background and each may have it’s pros and cons for your local situation (availability, support, performance in hot/cold climates, installability, pricing, etc). Therefore, feel free to reach out to a nearby Victron Authorised installer and ask for their local know-how.
    Victron Energy is renowned for support of third party Lithium battery manufacturers. Great efforts are spent to ensure a deep and problem free integration with other brands such as FreedomWON, BYD, Pylontech, MG Energy, to work seamlessly with Victron GX equipment. When working with unsupported brands, a Victron Battery Monitor is recommended to pass on accurate state of charge readings to the wider system. Ask your local authorised installer for recommendations. Check the supported brands Ask your local Victron installer
    The professionals' Choice
    Lithium: 60kWh - 6x BYD B-box Lithium battery modules: Considering that the recommended Depth of Discharge will sit somewhere between 10 and 20%, an effective ±50kWh of battery capacity can fully power this greenhouse 24/7. In this example, the day-time energy consumption is 80kWh, the night-time consumers total 30kWh. Since the day-time consumers are primarily powered through the AC-PV solar array, 50kWh of battery capacity is more than enough to assist for cloudy spells and take the installation through the night. Lithium was chosen because of its performance in high temperatures up to 55 degrees, optimal scalability, fast charging abilities and because of its ‘maintenance free’ factor which is welcomed especially at this remote location. When using a third party Lithium bank, a GX device is mandatory. Integrated through a CANbus interface, the GX device is used to set up, manage charge and discharge limits and to exchange error codes and state of charge information.
  • 03
    How much solar works for this Off-grid system, with which MPPT controller?
    Every off-grid system is different and each location may provide unique challenges. Many variables need to be considered such as the day and night time loads, losses, the efficiency of the panels and their geographic location with respect to solar irradiance (the amount of sunlight that will fall on a given spot), the inclination and orientation of the solar panels, shading and dirt or snow causing losses in the array itself. Other factors such as local costs of solar panels, battery banks and solar array cleaning also come into play. This is why every system is different and designing an off-grid system is a local expert's job. However, to get an idea, see the below and explore our basic solar and off-grid calculators.
    Knowing the daily energy consumption, the goal size of the solar array can be calculated. Logically, at a bare minimum, the daily energy consumption should be able to be harvested, stand-alone time included and losses compensated. Also safety margins determined by case-specific influences are relevant. While there are many considerations and methods to calculate with, this one below aims to start to give you an idea.
    Calculating the solar yield
    Every off-grid system is different and each location provides different challenges and a different solar yield, so solar calculations come down to local and practical experience. This is why our global network of Authorised Installers is trained with 45 years of know-how, and are carefully selected for their (local) knowledge and quality of service. Use our DC calculator Use our off-grid calculator Ask your local installer
    Daily energy consumption * (1 + system losses) / average year round solar peak hours * case specific influences = Off-grid solar array size.
    Based on the geographical location and season, the solar irradiance varies. Use our solar calculator to get an idea of your local solar insolation factor.
    A hybrid 30kVA AC-Solar PV combined with 8kVA DC-Solar PV: The power profile of this system is characterised by its relatively large day-time consumption of 80kWh together with a significant night-time power requirement of 30kWh. Power from a 8kVA DC-coupled solar array generating ±32kWh per day is harvested by 2 MPPT SmartSolar MPPT 250/70 VE.Can units to charge the battery bank with an extremely high efficiency of 99%. When the batteries are full, they provide the energy to help power the loads through the Quattro inverter.
    To power the day-time consumers, the overall capacity is boosted by the addition of a 30kVA AC-coupled solar array, harvested by a Fronius 27kW Eco AC-solar inverter, which directly inverts the solar yield to a usable AC current in real-time and helps reduce the unnecessary usage of the battery bank, and thus prolonging battery life. When the solar yield drops, the Quattro seamlessly supplements the AC-inverter with energy from the DC-solar array and/or battery bank. Excess solar from the AC-array is used to charge the battery bank through the Quattro inverter/charger AC input.
  • 04
    When to choose an AC-PV or DC-PV solar array or both?
    There is a choice to make when it comes to the different technologies of converting solar energy into consumable power: DC-or AC coupled solar power, or- in a hybrid model- both.
    DC-coupled solar or DC-PV
    AC-solar coupled solar or AC-PV
    DC solar chargers have a very high 98% efficiency from panel to the battery bank, which makes DC the excellent choice when most energy needs to be stored in the battery banks for the night consumers. Through an inverter such as the Quattro, day time consumers can be powered as well (inverter efficiencies of ±96% need to be taken into account). Victron Energy Solar chargers can bring (fully) depleted battery banks back to normal to automatically resume operations. This is critically important in lithium batteries, where self discharge loads can permanently destroy a battery.
    AC solar inverters have a ±94% efficiency from panel directly to their AC output, which makes them more efficient to directly power heavy daytime-only consumers such as air conditioning or heavy kitchen/ office appliances and thus helps to increase the sustained and total kW power that the system can supply. Using AC-PV as the only charging source for the battery bank is not recommended due to efficiency and fail-safe reasons: AC-PV requires a grid to (re)start, which is why it cannot start itself when batteries are empty.
    The choice between technologies depends on many factors, a main one is when power consumption peaks are expected: during the day or at night (or both). In a good off-grid practice with larger systems requiring significant energy during both the day and night, a hybrid combination of both AC-PV and DC-PV is often used, using each of their advantages. Victron Energy is renowned for the integration capabilities of third party PV-inverter brands such as Fronius.
    The minimum total yield of a DC-PV only array needs to equal the total daily consumption (24h) and its losses, calculating with the average of available sun hours.
    DC-PV only
    DC-PV based solar chargers are way more efficient for charging battery banks, compared to AC-PV.
    During daytime the batteries are efficiently recharged for the night consumers and at the same time daytime consumers are mostly powered with energy from the solar array, through the solar charger and the inverter/charger. When the solar yield is reduced, energy from the battery bank is taken to power the loads.
    For small to medium size systems DC-PV is the go-to standard. They can also power larger off-grid systems, as long as the solar panels and solar charge controllers can be placed in close proximity of the battery bank and the inverters: DC requires thicker cabling and is limited in length due to energy losses. This is not always practical, especially when roof-space is limited.
    In large systems with significant day-time consumers in a system, a Hybrid setup is a good and durable off-grid practice.
    Hybrid: AC-PV and DC-PV combined
    A combination of AC- and DC-PV is used when there are large daytime consumers and a selection of the loads need to be powered through the night.
    AC-PV takes care of the day-time load and uses its excess power to charge the batteries, DC-PV is used for efficient battery charging, its excess power can be used to power the loads. At any time if the load exceeds the power available from the AC-PV inverters, the Quattro inverters provide the difference from battery storage or even the generator can be automatically started.
    For off-grid systems with AC-solar inverters we always recommend to include a DC-array for efficient battery charging, but also to bring the system backup automatically in case the battery bank is completely empty. AC inverters cannot start themselves when there isn’t a grid present. A DC array can charge the batteries, which will reactivate the Victron inverters to create the grid. With a grid present, the AC-PV inverter will also come back online automatically.
    The AC-solar array is sized to power the total of concurrent day-time loads directly such as air conditioning, laundry- and kitchen equipment. The AC-PV inverter is sized to accommodate the average loads. The DC-array is sized to efficiently charge the battery bank which powers the night-time consumers.
  • 06
    How can I (remote) control my system, prevent issues and manage third party battery banks?
    GX-devices are the communication centre of an installation, giving you perfect control over all systems components and maximise their performance, no matter where you are. They are also essential to integrate a third party Lithium battery bank.
    Always in perfect control
    Through our free VictronConnect app and the Victron Energy Remote Monitoring portal or laptop, you can check the system from local and remote. Monitor the battery state of charge, power consumption, power harvest from PV, generator and mains, or check generator tank levels and temperature measurements. Catch potential issues early by programming alerts and alarms in order to prevent definitive system failure.
    To add remote connectivity, the GX device can join an existing WIFI connection. Otherwise, a GX LTE 4G can provide a mobile internet connection for the system and connection to the VRM Portal. It works on 2G, 3G and 4G networks. Smaller systems without GX can do with the GlobalLink 520. It connects 2 VE.Direct enabled devices to VRM without any monthly fees or subscriptions, for the first five years.
    When using a supported third party Lithium bank, a GX device is mandatory, such as the Cerbo GX or inverter/charger models that have GX functionality built in. Integrated through a CANbus interface, the GX device connects to the BMS of the battery bank and is used to set up, manage charge and discharge limits and to exchange error codes and state of charge information. Everything to make the battery bank work perfectly together with the wider Victron Energy system
    Victron Energy is renowned for support of third party Lithium battery manufacturers. Great efforts are made to ensure a deep and problem free integration with other brands such as MG Energy, FreedomWON, BYD, Pylontech, to work seamlessly with Victron Energy GX equipment. Ask your local authorised installer for recommendations. Check the supported brands Ask your local installer
    Cerbo GX, GX Touch and GX LTE 4G The Cerbo GX maximises the performance of your systems components in real-time and keeps them in perfect tune. Its optional GX Touch screen is perfect for systems built into a neat cabinet or a hard to reach place, showing the system status at a glance. The GX LTE 4G ensures the resort’s management and their local Victron installer can receive live alerts from VRM and follow up on warnings.
  • 06
    Does this system require a Generator?
    The system has a fairly large solar array and battery bank to prevent power outages year-round. Since the vegetables will survive without a day of power, it is not seen as business critical compared to a fish-farm for instance. With data insights from VRM this can be closely monitored and if the need for a generator arises, the Quattro’s second AC input ports easily accept AC input power from a generator and auto start/stop rules can easily be set.
It seems like your browser does not support the latest technologies. To see this section properly, consider using a modern browser.
System diagram
for a lithium battery based system
How do the system design considerations translate into a robust system?
Generation
Storage & Conversion
Consumption
Monitoring
AC-Solar array
AC-Solar inverter
Loads
Inverter/Charger
x 3
Battery bank
x 6
DC Solar Charger
x 2
DC-Solar array
VictronConnect
Cerbo GX
GX Touch
VRM
GX LTE 4G
AC devices (single phase)
Every ‘household’ appliance or ‘heavy duty tool’ you would expect at home or at work can also be found in independent energy systems. All these devices need an Alternating Current (230V or 110V) to run.
Some of these devices such as computers can be sensitive to the quality of the inverted power (bad shore- or generator AC-input power can influence this quality negatively). Motor driven or heat generating equipment may require a high start-up current. All our inverters produce a pure sine wave, even when the AC input quality is less good, ensuring that sensitive loads can be powered and enjoy a peak-power of generally 2x of the inverters rated capacity to power even the heaviest of loads, or basically any load, problem free.
A recommendation would be to work with appliances that have an A+ energy rating or ideally higher (A+++) to minimise the use of electrical energy, especially for the larger consumers (Fridge, inverter air conditioners and choose LED lights).
Examples of AC-devices:
  • Heavy duty tools such as a drilling machine or a jigsaw
  • Computers
  • Phone chargers
  • Fridge and freezer
  • Lights
  • Coffee machine
  • Microwave
  • or basically any AC powered device you can think of
Cerbo GX & GX Touch 50
The Victron Energy Cerbo GX is the communication-centre of your systems installation, allowing you to always have perfect control from wherever you are and maximises its performance. The optional GX Touch 50 is a companion to the Cerbo GX, it’s five inch touch screen display gives an instant overview of your system and allows you to adjust settings in the blink of an eye.
Instantly monitor the battery state of charge, power consumption, power harvest from PV, generator, and mains, or check tank levels and temperature measurements. Easily control the shore power input current limit, (auto)start/stop generator(s) or even set quiet periods to avoid starting the generator in the middle of the night. Change any setting to optimise the system, follow up on alerts, perform diagnostic checks and resolve challenges remotely with the free Victron Remote Management (VRM) portal.
The Cerbo GX is an easy to use visual system and turns any power challenge into an effortless experience. Simply connect through our Victron Remote Management (VRM) portal, or access directly, using the optional GX Touch 50 screen, a Multi Functional Display or our VictronConnect app thanks to its added Bluetooth capability.
To successfully integrate a third-party battery bank, a GX-device such as the Cerbo GX is mandatory to manage charge and discharge limits, to exchange error codes and state of charge information with the wider Victron system.
See our GX-devices
GX 4G modules
A GX 4G module will add mobile internet connectivity to your Victron Energy system. When your system is in range of a 4G network, it will send data to the VRM website and you can monitor the system from your smartphone. The module adds GPS tracking, recording your trips and putting up a geo-fence around the installation. You will get an alert via mail when the system travels outside the geo-fence area.
Victron Energy offers multiple 4G modules and the Global Link 520 modem, which operates without any monthly fees or subscriptions, for the first five years and several 4G modules. See our 4G Modems See our Global Link 520
Inverter/Chargers
Inverter/chargers convert DC power from the batteries to AC power, safely powering appliances or heavy duty tools with 230V (or 110V in other markets). Their built in charger uses grid, shore or generator power, using the best adaptive charge algorithms for your batteries of any kind.
All Victron Energy inverter/chargers are developed for professional duty, enjoy a reputation of extreme resilience and are built on decades of field experience in the most demanding conditions. Our extremely resilient inverter/chargers are the best choice when both inverting and charging from AC inputs (such as shore or grid power, generators or AC-PV inverters) are required. Their connectivity options and depth of configuration settings allow the most sophisticated of challenges to be mastered.
Victron Energy inverter/chargers come with a handful of outstanding features:
  • PowerControl: automatically manage battery charging to prevent an overload of the generator or shore power.
  • PowerAssist: uses the battery as a buffer to assist the shore power during peak power demand.
  • Perfect power: sensitive devices run flawlessly on the pure sine wave technology, even when AC input sources aren’t producing a clean AC current, the Victron inverter/charger smooths out these issues, turning bad power into perfect power.
  • UPS function: makes sure shore power can be (un)plugged without causing any interruption thanks to seamless switching.
  • High peak-power: use motorised equipment without overheating and any load problem free.
  • Low self consumption.
  • The built-in charger comes with multiple adaptive charge algorithms to individually charge the starter and service battery, with a great service life as a result.
  • Models with 2 AC inputs ensure power can come from multiple power sources, such as shore-, grid- or generator power.
Our wide range of models makes it easy to efficiently match the right inverter/charger to the requirements. Compact models are available when space restrictions apply. Larger models can power industrial appliances and virtually unlimited power can be provided by Parallel or 3-phase operation. See all our inverter/chargers
Inverters
Inverters convert DC power from the batteries to AC power, safely powering any kind of appliance or heavy duty tools with 230V (or 110V in other markets).
All Victron Energy inverters are developed for professional duty and enjoy a reputation of extreme resilience, even in the most demanding conditions. The built-in Pure Sine Wave technology safely powers sensitive electronics such as computers, their high peak power rating allows high start-up currents from heavy duty tools, so you can power any load, problem free. Their high efficiency and ultra low self consumption ensure the stored energy can be used to efficiently power the consumers, instead of having to calculate with wide margins to compensate for energy losses.
Larger models can power industrial appliances and virtually unlimited power can be provided by Parallel or 3-phase operation. Other models come with built-in chargers (Inverter/chargers) which can be used when charging from shore- or generator AC sources is essential. Whatever you need, our wide range makes it easy to select the right inverter for your application, saving you the cost of having to buy a larger one.
See all our inverters See all our inverter/chargers
AC-PV inverter
AC solar inverters invert energy from Solar arrays directly to a usable AC output. Usually they have a pretty high efficiency from panel directly to their AC output, which makes them more efficient to directly power heavy daytime-only consumers such as air conditioning or heavy kitchen/ office appliances and thus helps to increase the sustained and total kW power that the system can supply.
For off-grid systems with AC-solar inverters we always recommend to include a DC solar array for more efficient battery charging, but also to bring the system backup automatically in case the battery bank is completely empty. AC inverters cannot start themselves when there isn’t a grid present. In a rare case of a depleted battery bank, a DC array can charge the batteries, which will reactivate the Victron inverters to create the grid. With a grid present, the AC-PV inverter will also come back online automatically.
Therefore a combination of AC- and DC-PV is used when there are large daytime consumers and a selection of the loads need to be powered through the night. When the solar yield drops, the inverter/charger seamlessly supplements the AC-inverter with energy from the DC-solar array and/or battery bank. Excess solar from the AC-array is used to charge the battery bank through the AC input ports using the Victron inverter/chargers.
Great efforts are made to ensure a deep and problem free integration with a long list of third party managed AC-PV manufacturers. AC-PV inverters are supported directly after installing a software assistant on our inverters.
Service Batteries
The service battery, also called a house battery or battery bank, stores power for the system's consumers, providing autonomous power especially for moments when input power sources aren’t (fully) available.
Victron Energy offers several battery technologies, all designed for professional performance, reliability and long service life in the most demanding environments. They come with a 2 year worldwide warranty and our datasheets offer a fair picture of the performance and expected life cycles, meaning no investment surprises along the way.
Victron Energy also offers full flexibility when it comes to selecting an off-grid battery bank of choice. A large number of well supported third party Lithium battery manufacturers can be easily integrated through the use of a mandatory GX-device. This flexibility enables our customers to perfectly match their off-grid needs for their unique power situation. When working with unsupported brands, a Victron Energy Battery Monitor is required to pass on accurate state of charge readings to the wider system.
While there are multiple technologies to choose between, the main choice is between lead-acid and lithium which mainly depends on the expectations of the performance, cost-per-cycle and physical aspects (size/weight).
  • Choose Lead-Acid when:
  • Use occasionally
  • Lower purchase cost
  • Weight and space are not an issue
  • Normal charging
  • Choose Lithium when:
  • Intense daily demand
  • Lower cost per cycle
  • Weight and space considerations
  • Super fast charging
The above probably cuts 45 years of battery development expertise a bit short, for more info check our deep dive.
Deep dive: Lithium or lead-acid Check which third-party battery banks are supported See our wide range of batteries
Solar Chargers
A solar charger gathers energy from your solar panels, and stores it in your batteries. Using the latest, fastest technology, our solar chargers maximise this energy-harvest, driving it intelligently to achieve full charge in the shortest possible time whilst maintaining the batteries health, ensuring better performance… and a longer life.
In most cases, the light intensity of the solar panels is changing constantly, which affects their performance. Victron Energy solar controllers use ultra fast maximum power point tracking to squeeze up to 30% more power out of your panels.
Smaller models have an intelligent load-output, preventing damage caused by running batteries 'flat'. Smart models allow the solar harvest to be tracked and analysed through the free VictronConnect app, other connectivity options allow a remote connection through our VRM portal. For larger systems, solar chargers can be synchronized, so they act as one large and very efficient charger. For systems with large series connected PV arrays charging 48 V DC battery banks, high voltage models are available.
See our Solar Calculator to size the solar panels and select a MPPT charger
Solar panels
Solar panels catch the energy from sunlight and forward it to a solar charge controller which stores that energy in the systems battery bank. Adding solar panels to your system means free energy, independence from the grid and allows you to downsize or eliminate the need for noisy, fuel consuming and maintenance heavy generators.
Victron Energy offers a wide range of highly efficient solar panels that have exceptional low-light performance and high sensitivity to light across the entire solar spectrum, making it the perfect choice for any system. Victron Energy solar panels meet the most stringent safety requirements and their limited warranty means no surprises along the way.
See all our solar panels
VictronConnect
All Victron Energy smart products can be monitored and controlled from the palm of your hand. Just connect the VictronConnect App via Bluetooth and you’ll have direct access to the performance data of your system. You can also easily change settings, turn devices on or off and much more.
Non-smart devices with a VE.Direct port can also become smart, through the use of the VE.Direct Bluetooth Smart dongle
It is also possible to monitor and control your system remotely. VictronConnect-Remote functionality enables Victron products with a VE.Direct interface to be accessed remotely through a GX product, via the VRM online portal. This powerful feature allows full product configuration and monitoring from practically anywhere in the world using the VictronConnect app. The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface.
See what the VictronConnect app can do See our GX-devices
VRM - Victron Remote Management
Monitor and manage
Monitor and manage your Victron Energy systems from anywhere and catch potential issues early by setting alerts and alarms. With VRM you are always in perfect control from wherever you are.
VRM works with a GX-device such as the Cerbo GX with internet connection, the GlobalLink 520 or GSM LTE 4-g for smaller systems.
Monitor
Monitor the battery state of charge, power consumption, power harvest from solar, generator and mains in real-time. Optimise the energy harvest and usage with history graphs and detailed analytical reports. Catch potential issues early by setting alerts and follow up on alarms to prevent definitive system failure.
Manage
Easily control the shore power input current limit, switch on the inverter, (auto)start/stop generators or even set quiet periods to avoid starting the generator in the middle of the night. With VRM you can change any setting, follow up on alarms, perform diagnostic checks and resolve challenges from wherever you are.
See all our GX-devices
Ask your local Victron Energy Professional.
Every off-grid system is different and different locations present unique challenges. That is why Authorised Victron Energy Professionals are trained with the highest level of know-how. Their local expertise is vital. All the variables need to be considered with regard to the local climate and local costs of solar panels, battery banks, etc. They feel a great responsibility to always advise the right solution and do whatever they can to provide peace of mind for years to come.
Always feel free to ask your local Victron Energy Professional
Victron Professional standing besides a car with Victron equipment
Why Victron Energy?
It’s not one thing that makes it all work.
Our modular, robust and connected off-grid systems have been proven to deliver unequalled reliability time and time again, even in the harshest of climates. But it’s our unique combination of up-to-date hard- and software, intelligent monitoring Apps, the network of highly trained Authorised professionals and widespread repair centres that turns a Victron Energy system into an unbeatable system, that is Powered by know-how.
Icon of 45 years Victron Energy
Lithium battery
Why Victron Energy?
Reliability powers long service life cycles.
When making power supply investment decisions, calculations purely based on price can be deceptive. Their true performance and expected service life cycle are equally important. Good thing Victron Energy equipment lives up to their specifications, both in terms of performance and expected life cycle (when used as designed). Our 5 or 10 year warranty and fair and fast repair policies mean your investments are protected and under most circumstances, won’t let you down.
Ambulance
Why Victron Energy?
How efficiency translates into great cost-effectiveness.
With battery based power systems, efficiency is always key to providing great levels of cost-effectiveness. From our incredibly efficient SmartSolar Charge Controllers to the way our inverter/chargers can provide a super efficient Energy Storage or off-grid system, or how complete systems are optimised by our GX devices: with a Blue Power system you can be sure that all the details are thought through and that our products live up to their (efficient) specifications. This, combined with our reputation for extreme resilience and expected life cycles, translates into cost-effective solutions, especially when compared to ‘cheaper’ options.
years warranty
Victron professional showing customer the VictronConnect app
Why Victron Energy?
Clean power. New businesses.
By replacing generators with solar energy as the primary source of power, power security is increased, maintenance reduced and overall energy costs lowered to a tipping point where independent energy systems enable a whole new generation of business models. By providing sustainable power at scale new business opportunities are within easy reach, even at remote locations where there is no grid present at all. Fish farms or entire factories and resorts can be started or converted, wherever it is needed. The positive social and economic advantages are substantial and far-reaching and with Victron Energy you can power it all.
Victron professional standing next to Victron equipment in the back of a car
Why Victron Energy?
Backup and off-grid powered by know-how.
Our global network of ±1000 highly trained distributors, installers and service partners are always on hand to help. From stock advice, installation recommendations, after-care and technical support. With the Victron Energy team, their partners and lively community you can always be sure the power of know-how is by your side.
Thanks to our customer feedback loop, data and knowledge sharing, we innovate 24/7. We are powered by know-how, it keeps us going and our users going - ensuring peace of mind in off-grid for years to come.
Check our community See how we achieve peace of mind in off-grid
Motor driven by
Arrow icon
Connect to our
Off-grid know-how Visit our blog
It seems like your browser does not support the latest technologies to see this section properly, consider using a modern browser.
Battery compatibility
See which managed batteries can be seamlessly integrated
Download our Off-grid, Backup and Island systems brochure
Download icon
Energy Storage systems
Check our ESS design and installation manual.
Show more Carret icon
Robust inverter/charger
MultiPlus-II GX inverter/charger with connectivity built in
Technical information
Get your wiring right with Wiring Unlimited
System planner tool
Roughly calculate your solar array, battery sizing and inverter sizing.
SmartSolar MPPT RS 48V
Our latest high-voltage MPPT for large solar arrays is redefining MPPT solar chargers.
Solution examples from our partners
Visit our blog
Ask your local Victron Energy dealer
Do you have a question about a product, or do you wish to have a system installed on-site? Your local Victron dealer is trained to translate your exact needs into robust solutions.
Count on our worldwide service
Thanks to the help of a carefully selected and well trained global network of authorised dealers, our customers can count on a swift service and our large, worldwide repair network that covers even the most remote areas with a fast service.
