Blue Smart IP22 Charger
Features
  1. Bluetooth setup and monitoring (Using VictronConnect)
    Equipped with integrated Bluetooth; enabling quick and simple setup, advanced configuration, comprehensive monitoring and firmware updates via the VictronConnect app and a Bluetooth enabled device (such as a mobile phone or tablet).
  2. VE.Smart Network compatible
    VE.Smart Networking capability allows multiple chargers to operate in unison with synchronised charging, and receive accurate battery voltage (Voltsense), charge current (Current-sense) and battery temperature (Temp-sense) data from a compatible battery monitor (such as a BMV, SmartShunt, Smart Battery Sense or VE.Bus Smart Dongle) to further enhance the charge cycle.
  3. Integrated charge presets
    Integrated charge presets (selected via the MODE button or VictronConnect app) combined with adaptive charge logic are well suited for most common battery types; such as LiFePO4, AGM, Gel and flooded lead-acid. Advanced configuration with specific user defined settings is also possible using VictronConnect.
  4. Multi-stage charge algorithm
    The multi-stage charge algorithm is specifically engineered to optimise each recharge cycle and charge maintenance over extended periods.
  5. Adaptive absorption
    Adaptive absorption monitors the battery’s response during initial charging and intelligently determines the appropriate absorption duration for each individual charge cycle. This ensures that the battery is fully recharged regardless of the discharge level or capacity and avoids excessive time at the elevated absorption voltage (that can accelerate battery aging).
  6. Temperature compensation
    Charge voltage is automatically compensated depending on the ambient temperature; this ensures that the battery is charged at the optimal charge voltage regardless of the climate and avoids the need for manual settings adjustments. Temperature compensation is not required and automatically disabled when in LI-ION charge mode.
  7. High efficiency
    The Blue Smart IP22 Charger range is up to ~95% efficient; resulting in lower power usage, less heat generated and cooler operation
  8. Durable and safe
    1. Engineered to provide years of trouble-free and dependable operation in all usage conditions
    2. Protection against overheating: output current will be reduced if the charger temperature increases above 40°C (linear derate from 100% at 40°C to 20% at 60°C)
    3. Protection against output short circuit: If a short circuit condition is detected the charger will shut down
    4. Protection against reverse polarity connection: If the charger is incorrectly connected to a battery with reverse polarity the user replaceable fuse will blow
  9. Silent operation
    Charger operation is totally silent whilst the cooling fan is off; the cooling fan is only activated when it is necessary during demanding periods. If the NIGHT or LOW current mode is activated; the maximum output current is reduced to 50% of nominal and the cooling fan will remain off.
  10. Lithium Ion compatible
    Compatible with Li-ion (LiFePO₄) batteries; when the integrated LI-ION charge mode is selected the charge cycle settings are altered to suit.
    If the charger is connected to a battery where under voltage protection (UVP) has tripped, it will automatically reset UVP and start charging; many other chargers will not recognise a battery in this state.
    Warning: Do not charge Li-ion batteries if the battery temperature is below 0°C.
  11. Storage stage
    An additional stage to extend battery life whilst the battery is unused and on continuous charge.
  12. Recondition stage
    An optional stage that can partially recover/reverse lead acid battery degradation due to sulfation; typically caused by inadequate charging or if the battery is left in a deeply discharged state.
  13. Configurable output current
    A fully configurable setting that limits the maximum charge current to a reduced level; beneficial when charging lower capacity batteries with a high current charger.
  14. Recovery function
    The charger will attempt to recharge a severely discharged battery (even down to 0V) with low current and then resume normal charging once the battery voltage has risen sufficiently; many other chargers will not recognise a battery in this state.
  15. Power supply mode
    A specific mode to use the charger as a DC power supply; to power equipment at a constant voltage with or without a battery connected.
