Field test: PV Modules
Total solar yield: --
S
S
S
S
W
Romania
Installation date: 09-03-2020
Irradiance
Mono: 9158 kWh
Split-cell: 9511 kWh
Poly: 9113 kWh
Perc: 9471 kWh
Perc-east: 1970 kWh
Perc-west: 1730 kWh
The GX Touch 50 and GX Touch 70 are display accessories for our Cerbo GX. The five inch and seven inch touch screen displays give an instant overview of your system and allow to adjust settings in the blink of an eye. Simply connected to the Cerbo GX with one cable, Their super slim waterproof design, top-mountable setup and simple installation bring a lot of flexibility when creating a crisp and clean dashboard.
Watch the new video that explains all there is to know about installing the new Cerbo GX & GX Touch 50.
Protected
The GX Touch Protection Covers (not for the GX Touch 50 & 70 Flush) are not just accessories, they are your system’s  guardians. They shield the GX Touch display from water, dust, and even UV light, ensuring its longevity and performance.
Simply mounted
The GX Touch is optimised to more than meet the standards of installer professionals. The screen is simply bolted on top of a dashboard, eliminating the need to create perfect cut-outs (like with the Color Control GX).  It can also be mounted flush or even embossed with the unlaying surface and connected through just one cable, taking away the hassle of having to bring many wires to a dashboard.
Companions
The GX Touch is a companion to the Cerbo GX. This communication-centre allows you to always have perfect control over your system from wherever you are and maximises its performance. Simply connect through our Victron Remote Management (VRM) portal, or access directly, using the GX Touch, an MFD or our VictronConnect App thanks to its built-in WiFi Access Point. This latest addition to the GX-range combines all the best of connectivity, redefining smart power solutions in every way.
Experience the power of VRM
See remote monitoring in action, experience VRM in thousands of real-life installations worldwide or log in to get started.
Downloads & Support
The new Cerbo GX, along with the optional GX Touch 50 display, were announced and demonstrated at METS, November 2019 . Personally I'm a great fan of GX devices, the Color Control GX, Venus GX and more - all being a part of the Victron GX product range . Detailed introductory blogpost by Panbo However, my 6 years personal experience is with the Color Control GX model - so I'd be doing...
Read more
Find a dealer
GX Touch 50 & GX Touch 70
