battery_compatibility:pytes
battery_compatibility:pytes [2024-06-18 22:38] guy_stewartbattery_compatibility:pytes [2024-10-25 07:50] (current) guy_stewart
Line 9: Line 9:
 It is possible to use either the BMS-Can or VE.Can ports with this battery. Depending which one you use will require additional configuration on the batteries side, please see the documentation linked below for instructions.  It is possible to use either the BMS-Can or VE.Can ports with this battery. Depending which one you use will require additional configuration on the batteries side, please see the documentation linked below for instructions.
-The minimum supported firmware version is v3.31. It is recommended to use the latest firmware version on new installations and when trouble shooting issues.+The minimum supported GX firmware version is v3.31. It is recommended to use the latest firmware version on new installations and when trouble shooting issues
 +The minimum supported Pytes firmware version is 1.10.18. This is displayed at v18.1 on the GX device and VRM.
 Connecting a Pytes battery to the GX device will require enabling DVCC, and disabling SVS and STS. Connecting a Pytes battery to the GX device will require enabling DVCC, and disabling SVS and STS.
Line 21: Line 23:
 {{:battery_compatibility:cleanshot_2024-06-18_at_22.36.55.jpg?400|}} {{:battery_compatibility:cleanshot_2024-06-18_at_22.36.55.jpg?400|}}
-=== 1.2 All 48V Multis, MultiPlus, Quattros and RS models are compatible ===+=== 1.2 CAN-Bus wiring between the battery and GX Device ===
 +Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018.
 +Plug the side which is labeled Battery BMS into the Battery BMS. Plug the side labeled Victron VE.Can into the [[venus-os:start|GX device]].
 +Then plug a [[https://www.victronenergy.com/accessories/ve-can-rj45-terminator|VE.Can terminator]] in the other VE.Can socket on the [[venus-os:start|GX device]]. Two VE.Can terminators are included with the package of the [[venus-os:start|GX device]] as an accessory, only one is used. Keep the other one as a spare.
 +More information about the cable can be found in [[battery_compatibility:can-bus_bms-cable|its manual]].
 +Without properly connecting this cable, the battery will not show up on the display of the [[venus-os:start|GX device]].
 +It is important to ensure this connection and display of the battery on the [[venus-os:start|GX device]] display before attempting firmware updates or settings changes on other devices if they depend on the power supply from the battery. DO NOT attempt to operate the battery cells normally without connection to the BMS.
 +=== 1.3 All 48V Multis, MultiPlus, Quattros and RS models are compatible ===
 The minimum supported firmware version for VE.Bus models is 469. Minimum supported firmware for RS models is 1.16. Updating to the latest firmware is recommended for new installations, and troubleshooting issues. The minimum supported firmware version for VE.Bus models is 469. Minimum supported firmware for RS models is 1.16. Updating to the latest firmware is recommended for new installations, and troubleshooting issues.
Line 31: Line 48:
 In off-grid systems, the control functions of the Battery Management System (BMS) are built into the latest version of the [[venus-os:start|GX device]]. In off-grid systems, the control functions of the Battery Management System (BMS) are built into the latest version of the [[venus-os:start|GX device]].
-=== 1.Solar Charger compatibility ===+=== 1.Solar Charger compatibility ===
 All 48V BlueSolar and SmartSolar MPPT Chargers are compatible. All 48V BlueSolar and SmartSolar MPPT Chargers are compatible.
Line 45: Line 62:
 ===== 3. Further system integration documentation  ===== ===== 3. Further system integration documentation  =====
-{{ :battery_compatibility:ebox_series.pdf |Installation and configuration manual +{{ :battery_compatibility:pytes_battery_brief.pdf |}}
-with Victron Energy}}+
 +{{ :battery_compatibility:pytes_battery_datasheet.pdf |}}
 +{{ :battery_compatibility:pytes_e-box_series_user_manual_v3.6.pdf |}}
 +{{ :battery_compatibility:pytes_ebox_manual.pdf |}}
 +{{ :battery_compatibility:pytes_lv_lfp_batteries_integration_with_victron.pdf |}}
 +{{ :battery_compatibility:pytes_pi_lv1_user_manual_v1.3.pdf |}}
 +{{ :battery_compatibility:pytes_v5_v5a_user_manual_v1.3.pdf |}}
-{{ :battery_compatibility:pytes.pdf |Pytes Victron Guide}}+{{ :battery_compatibility:pytes_victron_ve_configure_setting_with_pytes_48v_batteries.pdf |}}
-{{ :battery_compatibility:victron-configure3-setting-with-pytes.pdf | Victron VE.Configure3 settings with Pytes}}+{{ :battery_compatibility:pytes_victron_ve_configure_setting_with_pytes_51.2v_batteries.pdf |}}
-{{ :battery_compatibility:pytes_ebox_manual.pdf | Ebox Series manual}}
 Further details about installation and configuration is available from your battery manufacturer.  Further details about installation and configuration is available from your battery manufacturer.
 +Improvements CVL (Charge Voltage Limit) regulation were added to Pytes firmware versions 1.10.18. Earlier versions will still connect but are not supported, and may charge/discharge cycle when at 100% state of charge.
 ===== 4. Support  ===== ===== 4. Support  =====
battery_compatibility/pytes.1718743097.txt.gz · Last modified: by guy_stewart
