Victron & Pytes
1.1 A GX device is required, eg Cerbo GX, etc
It is essential to use the BMS-Can (500 kbit/s) connection type of a GX device with these batteries for communication of charge and discharge limits, error codes and state of charge.
It is possible to use either the BMS-Can or VE.Can ports with this battery. Depending which one you use will require additional configuration on the batteries side, please see the documentation linked below for instructions.
The minimum supported firmware version is v3.31. It is recommended to use the latest firmware version on new installations and when trouble shooting issues.
Connecting a Pytes battery to the GX device will require enabling DVCC, and disabling SVS and STS.
1.2 All 48V Multis, MultiPlus, Quattros and RS models are compatible
The minimum supported firmware version for VE.Bus models is 469. Minimum supported firmware for RS models is 1.16. Updating to the latest firmware is recommended for new installations, and troubleshooting issues.
These VE.Bus inverter/charger units must be connected to the GX device via the VE.Bus connection port.
In off-grid systems, the control functions of the Battery Management System (BMS) are built into the latest version of the GX device.
1.3 Solar Charger compatibility
All 48V BlueSolar and SmartSolar MPPT Chargers are compatible.
2. Minimum battery sizing
For reliable operation there are minimum numbers of batteries required for different Victron inverters. Please contact your battery supplier for these specifications.
3. Further system integration documentation
Installation and configuration manual with Victron Energy
Victron VE.Configure3 settings with Pytes
Further details about installation and configuration is available from your battery manufacturer.
4. Support
Support for this battery should first come from your battery supplier. Pytes has a service email at ess_support@pytesgroup.com
Support from Victron is limited our online Victron Community page.
