battery_compatibility:simpliphi_power
Victron & SimpliPhi Power Batteries
Compatible Victron products
24V and 48V Lithium Iron Phosphate batteries from SimpliPhi (www.simpliphipower.com) are compatible with all 24V and 48V Multis, Quattros, and also all Blue Solar VE.Can, VE.Direct Solar chargers, and BMV Battery Monitors.
The SimpliPhi Power batteries are a drop in replacement for lead acid batteries: battery management and safety disconnects are integral to each battery, and there is no control wiring required or software integration required. Simple integration and a wide operating temperature range make these batteries ideal for off-grid solar and diesel-hybrid systems.
An integration guide with the recommended settings for each Victron product is available from SimpliPhi Power. Contact info@simpliphipower.com for access to download the SimpliPhi-Victron integration guide.
battery_compatibility/simpliphi_power.txt · Last modified: 2024-06-25 12:09 by mvader
