battery_compatibility:simpliphi_power
Victron & SimpliPhi batteries
Compatible Victron products
The Freedom Lite range of Lithium Iron Phosphate batteries from SimpliPhi (www.simpliphipower.com) is compatible with all 24V and 48V Multis and Quattros and also all Blue Solar VE.Can and VE.Direct Solar chargers.
The SimpliPhi Power batteries are a drop in replacement for lead acid batteries: control and safety disconnects are all inside the batteries, and there is no control wiring required.
battery_compatibility/simpliphi_power.1496221984.txt.gz · Last modified: 2017-05-31 11:13 by mvader
