drafts:updater-error-codes
9.4 Error codes
In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product.
In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible. Sometimes you may need to remove the Bluetooth pairing information from your device in order to be able to reconnect with your product.
In the following list, you can check possible errors and descriptions.
Check chapter 10.3 of this manual for Troubleshooting firmware updates. When asking for help, make sure to always mention the error code.
VE.Direct products
Error Description
D3 No VE.Direct product(s) found.
D4 Unknown error occurred. Try again and check the product settings once updated.
D10 Error closing com port.
D20 Could not start updating, no updatable product found.
D26 Updating failed, communication lost. The product might be unusable. Check connection and power supply.
D29 Could not start updating, the firmware file is corrupt.
D31 Updating failed, the product is unusable. Try again and check the product settings once updated.
D32 Could not start updating, entering boot mode failed.
D33 Could not start updating, the firmware file is not found.
D90 Could not start updating, the firmware is not for this product.
D91 Could not start updating, an unknown product was found.
D92 Updating failed, erasing firmware failed. The product might be unusable. Try again and check the product settings once updated.
D93 Error starting firmware after updating. Power cycle (off/on) your product and if that does not help
try updating again, and check the product settings once updated.
D94 Product updated successfully, but an error occurred reading the previous settings. Check the product settings.
D95 Product updated successfully, but an error occurred restoring the previous settings. Check the product settings.
D96 Updating failed due to version mismatch. Power cycle (off/on) your product and if that does not help try
D97 Dup executable too old.
D98 Firmware file is not a valid dup file.
D99 Product updated successfully, but an error occurred restoring the settings. Check the product settings.
D100 Cannot migrate settings because the application is not active. Manual action required.
Blue Smart Charger, SmartLithium, and VE.Direct Bluetooth Smart dongle
Error Description
B1 Error reading file.
B2 Victron BLE service not found. Please remove the product from the list of paired devices and retry.
B3 Dfu BLE service not found. Please remove the product from the list of paired devices and retry.
B4 The product disconnected unexpectedly. Perhaps the bond information is no longer valid? Please remove
B5 A write to the device failed.
B6 The product did not activate its bootloader - although it should have.
B7 The product did not disconnect - although it should.
B8 Timeout waiting for access to the Victron BLE service.
B9 Timeout waiting for access to the Dfu BLE service.
B10 Timeout waiting for a response.
B11 Timeout while writing to the product. Perhaps a pairing dialogue is shown? Please retry.
B12 Device was no longer found. Perhaps out of range? Please retry.
B96 An internal error occurred (Opcode not supported). Please send a service report to Victron Energy.
B97 The requested encryption is not supported by the product. Please send a service report to Victron Energy.
B98 An internal error occurred (Data size exceeds limits). Please send a service report to Victron Energy.
B99 The product could not store the firmware in its memory. Please retry, and if the problem persists, please contact Victron Energy.
B100 An internal error occurred (CRC error). Please send a service report to Victron Energy.
B101 An internal error occurred (Data length error). Please send a service report to Victron Energy.
B102 An internal error occurred (Not allowed). Please send a service report to Victron Energy.
VE.Bus Products
Error Description
V2 No product detected. Please check all the cable connections and try again.
V3 An unexpected timeout was triggered. Please check all the cable connections and try again.
V4 Incomplete vff file. Nonce missing. Please make sure you selected a valid update file and try again.
V5 Incomplete vff file. EEPROM lines missing. Please make sure you selected a valid update file and try again.
V6 The vff file contains more eeprom data than supported. Please make sure you selected a valid update file and try again.
V7 The calibration map in the file exceeds the device calibration map. Please make sure you selected a valid update file and try again.
V8 Device calibration data size bigger than expected. Please make sure you selected a valid update file and try again.
V9 Bootloader did not respond to bootloader setup. Please check all the cable connections and try again.
V10 Bootloader response to version request failed.
V11 Incompatible bootblock. Function version invalid.
V12 Incompatible bootblock. Version invalid.
V13 Bootloader did not start after bootblock update.
V14 Incompatible bootblock type.
V15 No or unexpected response to target id query.
V16 No or unexpected response to eeprom read action.
V17 No or unexpected response to calibration map query.
V18 The supplied firmware contains new unsupported calibration values.
The updater does not know how to handle them.
V19 No response received to eeprom write command. Please check all the cable connections and try again.
V20 Invalid response received to eeprom write command. Please check all the cable connections and try again.
V21 No response received to code write command. Please check all the cable connections and try again.
V22 Invalid response received to code write command.
V23 The MK2/MK3 did not respond. Please check all the cable connections and try again.
V24 The connected product does not match the specified model in the file.
V25 The hardware revision specific eeprom defaults data is corrupt.
V26 Updates can not be performed with a VEBUS BMS connected.
V27 Updates can not be performed with a DMC connected.
V40 Failed to start Update. could not allocate memory. Malloc error.
V50 Failed to start Update. File open error. Please check the file location and access permissions.
Make sure you selected a valid update file and try again.
V51 Failed to start Update. File write error. Please check file location and access permissions.
V52 Failed to start Update. File read error. Please check file location and access permissions.
V53 Failed to start Update. File checksum error. File corrupted or not a valid VFF file.
V54 Failed to start Update. File has an incompatible version number.
V55 Failed to start Update. File section not found. File corrupted or not a valid VFF file.
V56 Failed to start Update. Format error. File corrupted or not a valid VFF file.
All other products (XUP update files)
Error Description
X3 Invalid updater state. Please try again.
X4 Firmware not for Product (Id). Please make sure you selected a valid update file and try again.
X5 Updater (version) too old.
X6 Communication Error. No Callback handler connected. Please check the connection and try again.
X7 Communication Error. Vreg ack-ed with an unexpected error. Please check the connection and try again.
X8 Update (xup) file format not supported. Please make sure you selected a valid update file and try again.
X9 File Error. No Instance Blob could be found in the update file. Please make sure you selected a valid update file and try again.
X10 File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.
X11 File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.
X12 File Error. No Firmware Version for instance found in the update file. Please make sure you selected a valid update file and try again.
X13 Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.
X14 Communication Error. The instance could not be reached. Please check the connection and try again.
X15 Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.
X16 Failed to Begin Update. Please check the connection and try again.
X17 File Error. No/invalid Firmware data found for instance in the update file. Please make sure you selected a valid update file and try again.
X18 Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.
X19 Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.
X20 Update Error. Invalid instance# in Update Data Ack. Please check the connection and try again.
X21 Update Error. Invalid ack on final Update Data. Please check the connection and try again.
X22 Verification Error. Invalid Firmware Version Ack. Please check the connection and try again.
X23 Verification Error. Invalid UDF Version Ack. Please check the connection and try again.
X24 Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.
X25 Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.
X26 Verification Error. Invalid instance field in UDF Version Ack.
X27 Failed to verify Minimum Firmware Version.
X28 Failed to verify Firmware Version. Please check the connection and try again.
X29 Failed to verify UDF Version. Please check the connection and try again.
X30 Failed on Minimum Firmware Version verification. Please check the connection and try again.
X31 Failed on Firmware Version verification. Please check the connection and try again.
X32 Still in Bootloader Mode after the update. Please try again.
X33 File Error. No Product Id found in the update file. Please make sure you selected a valid update file and try again.
X34 File Error. No VE.Direct baudrates found in the update file. Please make sure you selected a valid update file and try again.
X35 File Error. No Xup Format Version found in the update file. Please make sure you selected a valid update file and try again.
X36 File Error. No Minimum Updater Version found in the update file. Please make sure you selected a valid update file and try again.
X37 File Error. No Firmware (product) Version found in the update file. Please make sure you selected a valid update file and try again.
X38 File Error. The update file does not match XML standard. Please make sure you selected a valid update file and try again.
X39 Communication Error. Vreg Ack timeout. Please check the connection and try again.
X40 Communication Error. No product found. Please check the connection and try again.
X41 Communication Error. Comm port error. Please check the connection and try again.
X42 Update Error. Failed to set baudrate. Please check the connection and try again.
X43 Update Error. Update in progress on another interface.
X44 Update Error. Invalid instance# in Ack. Please check the connection and try again.
X45 Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.
X46 Update Error. Vreg Ack error. Please check the connection and try again.
drafts/updater-error-codes.txt · Last modified: by evandromr
