venus-os:canvu-gx
CANvu GX Manual
The CANvu GX is a product in the Victron GX Product Family. You can compare features between the CANvu GX and other GX devices here.
The CANvu GX is a device similar to the Color Control GX, and most of it's functionality and features are explained in the Color Control Manual here : https://www.victronenergy.com/live/ccgx:start
CANvu GX:
  • Data Logger & Control Functions
  • Item IP67 All Round Protection
  • USB connection
CANvu GX IO Extender and wiring kit:
Note; this kit needs to be purchased separately and is always needed. Included in the kit is:
  • CANvu GX IO extender
  • Power cable (supply voltage 8 - 32 VDC, 48V systems REQUIRE a suitable power supply or 48VDC to 24VDC downconverter!)
  • VE.Can cable
  • Ethernet cable
Features:
  • VE.CAN bus connections
  • CAN bus connections not isolated
  • VE.Bus connection
  • 3x VE.Direct connection
  • 1 Analogue input
  • 1 Digital input
  • 1 Relay output
  • 1 Ethernet Port
Overview of connections
venus-os/canvu-gx.txt · Last modified: 2020-05-13 11:20 by mvader
