venus-os:canvu-gx
The CANvu GX is a product in the Victron GX Product Family. You can compare features between the CANvu GX and other GX devices here.
The CANvu GX is a device similar to the Color Control GX, and most of it's functionality and features are explained in the Color Control Manual here : https://www.victronenergy.com/live/ccgx:start
CANvu GX:
- Data Logger & Control Functions
- Item IP67 All Round Protection
- USB connection
CANvu GX IO Extender and wiring kit:
Note; this kit needs to be purchased separately and is always needed. Included in the kit is:
- CANvu GX IO extender
- Power cable (supply voltage 8 - 32 VDC, if used on a 48V system, a DC-DC converter must be used to reduce the voltage below 32VDC)
- VE.Can cable
- Ethernet cable
Features:
- VE.CAN bus connections
- CAN bus connections not isolated
- VE.Bus connection
- 3x VE.Direct connection
- 1 Analogue input
- 1 Digital input
- 1 Relay output
- 1 Ethernet Port
Overview of connections
venus-os/canvu-gx.1557489963.txt.gz · Last modified: 2019-05-10 14:06 by lucian
