Mono: 9158 kWh
Split-cell: 9511 kWh
Poly: 9113 kWh
Perc: 9471 kWh
Perc-east: 1970 kWh
Perc-west: 1730 kWh
Monitor the AC/DC loads, shore power and generator status, or check the batteries in the blink of an eye. Easily control the shore power input current limit or switch your inverter on, off or set it to charger-only when leaving the boat at the dock. Open the Victron Remote Console to gain complete control over the entire system. All through the intuitive and clean interface.
Our chargers take good care of your batteries onboard. With the MFD you can have detailed insight into all of them: check the state of charge multiple batteries percentage of your service batteries, as well as voltage for secondary batteries used for engine starting, bow thrusters, winches, generator(s), etc. so you never run out of energy unexpectedly.
Victron Energy is now available on Raymarine's Multi Functional Displays (MFDs). And the installation is easy as 1-2-3. Simply connect a network cable between the MFD and the heart of Victron Energy's solution (any GX device) and that’s it! Just tap the Victron icon to enjoy the ease of control that Victron Energy brings on board. Plug and play, no configuration or subscriptions needed.
With a Victron Energy GX device, you always have the perfect control over your boat’s power system, wherever you are. Simply use VictronConnect or the Victron Remote Monitoring (VRM) portal to instantly see how your (critical) power supplies are performing. Change any setting to optimise the system. Follow up on alerts and resolve challenges remotely, by yourself or your Victron Authorised Professional, who is always happy to help you out. We do everything to keep you going. So you can keep doing what you do best.
