7. Technical specifications
MultiPlus-II | 12/3000/120-32 | 24/3000/70-32 | 48/3000/35-32 | ||
PowerControl / PowerAssist | Yes | ||||
AC input | Input voltage range: 187 - 265VAC Input frequency: 45 - 65Hz | ||||
Maximum feed through current | 32A | ||||
INVERTER | |||||
Input voltage range | 9.5 - 17V | 19 - 33V | 38 - 66V | ||
Output in inverter mode (1) | Output voltage: 230 VAC ± 2% Frequency: 50 Hz ± 0.1% | ||||
Continuous output power at 25°C / 77°F (3) | 3000VA | ||||
Continuous output power at 25°C / 77°F | 2400W | ||||
Continuous output power at 40°C / 104°F | 2200W | ||||
Continuous output power at 65°C / 150°F | 1700W | ||||
Maximum feed-in power | 3000VA | ||||
Peak power | 5500W | ||||
Maximum efficiency | 93 % | 94% | 95% | ||
Zero-load power | 13W | 13W | 11W | ||
Zero-load power in AES mode | 9W | 9W | 7W | ||
Zero-load power in Search mode | 3W | 3W | 2W | ||
CHARGER | |||||
AC input | Input voltage range: 187 - 265VAC Input frequency: 45 - 65Hz Power factor: 1 | ||||
Charge voltage 'absorption' | 14.4 / 28.8 / 57.6V | ||||
Charge voltage 'float' | 13.8 / 27.6 / 55.2V | ||||
Storage mode | 13.2 / 26.4 / 52.8V | ||||
Charge current house battery (4) | 120A | 70A | 35A | ||
GENERAL | |||||
Auxiliary output | Yes (32A) Default setting: switches off when in inverter mode | Yes (50A) Default setting: switches off when in inverter mode | |||
External AC current sensor (optional) | 50A | ||||
Programmable relay (5) | Yes | ||||
Protection (2) | a - g | ||||
VE.Bus communication port | For parallel and three-phase operation, remote monitoring and system integration | ||||
General purpose com. port | Yes, 2x | ||||
Common Characteristics | Operating temp.: -40 to +65 °C (-40 - 150°F) (fan-assisted cooling) Humidity (non-condensing): max 95 % | ||||
ENCLOSURE | |||||
Material & Colour | Steel, blue RAL 5012 Protection category: IP22 Pollution degree 2, OVC3 | ||||
Battery connections | M8 bolts | ||||
AC connections | Screw terminals 13 mm² (6 AWG) | ||||
Weight | 20 kg | 19 kg | 19 kg | ||
Dimensions hxwxd | 546 x 275 x 147 mm | 499 x 268 x 141 mm | 499 x 268 x 141 mm | ||
STANDARDS | |||||
Safety | EN 60335-1, EN 60335-2-29, IEC62109-1, IEC62109-2 | ||||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3, IEC 61000-6-1, EN 61000-6-2, EN 61000-6-3 | ||||
Uninterruptible power supply | Please consult the certificates on our website. | ||||
Anti-islanding | Please consult the certificates on our website. | ||||
MultiPlus-II | 12/5000/220-50 | 24/5000/120-50 | 48/5000/70-50 | ||
AC input | Input voltage range: 187 - 265VAC, Input frequency: 45 - 65Hz | ||||
Maximum feed through current | 50A | ||||
INVERTER | |||||
Output (1) | Output voltage: 230VAC ± 2% Frequency: 50Hz ± 01% | ||||
Continuous output power at 25°C / 77°F (3) | 5000 VA | ||||
Continuous output power at 25°C / 77°F | 4000 W | ||||
Continuous output power at 40°C / 104°F | 3700 W | ||||
Continuous output power at 65°C / 150°F | 3000 W | ||||
Maximum feed-in power | 5000 VA | ||||
Peak power | 9000 W | ||||
Maximum efficiency | 95% | 96 % | |||
Zero-load power | 15W | 18W | |||
Zero-load power in AES mode | 11W | 12W | |||
Zero-load power in Search mode | 3W | 4W | |||
CHARGER | |||||
AC input | Input voltage range: 187 - 265VAC Input frequency: 45 – 65Hz Power factor: 1 | ||||
Charge voltage 'absorption' | 14.4V | 28.8V | 57.6V | ||
Charge voltage 'float' | 13.8V | 27.6V | 55.2V | ||
Storage mode | 13.2V | 26.4V | 52.8V | ||
Charge current house battery (4) | 50A | 120A | 70A | ||
GENERAL | |||||
Auxiliary output | Yes (32A) Default setting: switches off when in inverter mode | ||||
External AC current sensor (optional) | Yes | ||||
General purpose comunication port | Yes, 2x | ||||
Common characteristics | Operating temp.: -40 to +65°C (-40 - 150°F) (fan-assisted cooling) Humidity (non-condensing): max 95% | ||||
ENCLOSURE | |||||
AC connections | Screw terminals 13mm² (6 AWG) | ||||
Weight | 33kg | 30kg | 30kg | ||
Dimensions h x w x d | 702 X 345 X 152 mm | 607 x 330 x 149 mm | 565 x 320 x 149 mm | ||
STANDARDS | |||||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, EN 61000-6-2, EN 61000-6-3 | ||||
MultiPlus-II | 48/8000/110-100 | 48/10000/140-100 | 48/15000/200-100 | |||
PowerControl / PowerAssist | Yes | |||||
AC input | Input voltage range: 187 - 265VAC, Input frequency: 45 - 65Hz | |||||
Maximum feed through current | 100A | |||||
INVERTER | ||||||
Input voltage range | 38 - 66V | |||||
Output (1) | Output voltage: 230VAC ± 2% Frequency: 50Hz ± 0.1% | |||||
Continuous output power at 25°C / 77°F (3) | 8000VA | 10000VA | 15000 VA | |||
Continuous output power at 25°C / 77°F | 6400W | 8000W | 12000 W | |||
Continuous output power at 40°C / 104°F | 5500W | 7000W | 10000 W | |||
Continuous output power at 65°C / 150°F | 4000W | 6000W | 7000 W | |||
Maximum feed-in power | 8000VA | 10000VA | 15000 VA | |||
Peak power | 15000W | 18000W | 27000 W | |||
Maximum efficiency | 95% | 95% | 96% | |||
Zero-load power | 29W | 38W | 55 W | |||
Zero-load power in AES mode | 19W | 27W | 39 W | |||
Zero-load power in Search mode | 3W | 4W | 6 W | |||
CHARGER | ||||||
AC input | Input voltage range: 187 - 265VAC Input frequency: 45 - 65Hz Power factor: 1 | |||||
Charge voltage 'absorption' | 57.6V | |||||
Charge voltage 'float' | 55.2V | |||||
Storage mode | 52.8V | |||||
Charge current house battery (4) | 110A | 140A | 200A | |||
GENERAL | ||||||
Auxiliary output | Yes (50A) | |||||
External AC current sensor (optional) | 100A | |||||
Programmable relay (5) | Yes | |||||
Protection (2) | a - g | |||||
VE.Bus communication port | Three-phase operation, remote monitoring and system integration | |||||
General purpose com. port | Yes, 2x | |||||
Common characteristics | Operating temp.: -40 to +65°C (-40 – 150°F) (fan-assisted cooling) Humidity (non-condensing): max 95% | |||||
ENCLOSURE | ||||||
Material & Colour | Steel, blue RAL 5012 Pollution degree 2, OVC3 | |||||
Pollution degree 2 | OVC3 | |||||
Protection category | IP 22 | |||||
Battery connections | Four M8 bolts (2 positive and 2 negative connections) | |||||
AC connections | Bolts M6 | |||||
Weight | 41.2 kg | 48.8 kg | 80 kg | |||
Dimensions h x w x d | 642 x 363 x 206 mm | 677 x 363 x 206 mm | 810 x 405 x 217 mm | |||
STANDARDS | ||||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2 | |||||
Emission / Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | |||||
Uninterruptible power supply | Please consult the certificates on our website. | |||||
Anti-islanding | Please consult the certificates on our website. | |||||
